stabiliser - Wrist Twisters
post #1 of 18 Old 03-31-2011, 06:22 PM Thread Starter
stabiliser
So there is one thing i noticed about the 919 and that it has no fork stabiliser at all , is this of any concern with cornering !!!!?.
On my other bike i bought one of these and it really improved it , are the 919s perfectley fine without one or would this be a nice upgrade?
Honda CBR 919 (CB 900 F) 2002-2007, Honda - SuperBrace - The Ultimate Fork Stabilizer
hangster is offline
post #2 of 18 Old 03-31-2011, 06:41 PM
It's fine without it. Plenty of flex elsewhere in the frame already, stiffening up the front forks might not be wise.
post #3 of 18 Old 03-31-2011, 06:45 PM
If you want to waste money on something that is not needed and will do nothing on a regular basis, buy a steering damper for a 919.
919s are rock steady with gentle geometry, and even if you manage to upset them, for example coming down from a wheelie with the front wheel off centre for the forward velocity line, it will sort itself out fast all by itself. On the track, they simply are not needed.
Nor does it need a fork brace like the link goes on to display. In fact, highly rigid fork braces are bad news, as any fork that needs a brace is a flexi fork, and unless the brace has some give, you get mega stiction when the forks are flexing because they do not flex symetrically and a good fork brace will have designed in flex to accomodate that. That fork brace is a real good example of a Poser Piece.
post #4 of 18 Old 03-31-2011, 06:46 PM
arctic954's Avatar
LOL.....thats what I thought he was asking.
You didn't look at the link.
... He's asking about a Fork Brace, not a steering damper.
arctic954 is offline
post #5 of 18 Old 03-31-2011, 06:55 PM
I've seen them too and thought they would be a nice bit of 'bling' - debatable if one is required on the 919 and if it is not a perfect fit it may introduce additional unwanted binding between the seals and fork legs.
Having said that, I made one years back for a Kawasaki with a flexi front end and it cleaned it up a lot. But that was the early 80's with long 35mm forks and front ends have improved a lot since then.
post #6 of 18 Old 03-31-2011, 07:03 PM
arctic954's Avatar
I had a Fork Brace on my XR650R. The bike was a road-only supermoto.....the brace made a huge difference. On the XR at 100mph...... you could feel them move.
I don't however feel as though the forks flexing are a major issue with the 919.
Like always though --- I'm always hesitant to DIS anything, until I've tried and tested it. If I knew someone that had one..... I'd try it out for sure. But to be a test monkey for $150....um, I'll pass.
post #7 of 18 Old 03-31-2011, 07:13 PM
What was the total fork travel and fork tube diameter on the XR ?
The point being a long travel fork changes the equation, as do thinner tubes, and in combination, net a noodley front end.
post #8 of 18 Old 03-31-2011, 07:16 PM
I have a fork brace on my XR650L, also makes a big difference. But totally different set up than the 919, it's simply not necessary on that bike.
post #9 of 18 Old 03-31-2011, 07:16 PM
arctic954's Avatar
absolutely....... it was that long travel suspension that caused the issues with the XR on the road.
post #10 of 18 Old 03-31-2011, 07:29 PM
Stiffness varies with tube diameter to the 4th power and length to the 3rd power.
So you don't need much of an increase in length to dramatically reduce its rigidity and increase its deflection for any given load.
post #11 of 18 Old 03-31-2011, 08:34 PM
I'm getting that printed on a T-shirt!
post #12 of 18 Old 04-01-2011, 02:10 AM
schrock86's Avatar
schrock86 is offline
post #13 of 18 Old 04-01-2011, 02:16 AM
post #14 of 18 Old 04-01-2011, 05:10 AM
arctic954's Avatar
Been there, done that, got the T shirt. Being a porn star gets old after a while.......
Sent from my turbo charged iPhone using Tapatalk
post #15 of 18 Old 04-01-2011, 07:14 AM
Gets censored
Dont wanna start an "oil" type argument but..... while I agree the brace is at the very least a poser piece and worst case accually could cause an issue I disagree about the stabilizer/damper. I had some serious head shake issues out of my 9er under hard acceleration, and as you stated when coming down crossed up. I put an Elcheapo damper from a gsx-r on it and when the shake started it calmed it down right away. I personally will have a damper on my bike if possible always, I hate head shake! Never been through a full blown slapper but Ive seen em.... no thanks.
brian is offline
post #16 of 18 Old 04-01-2011, 07:26 AM
Head shake is not nice.
No one likes it, nor should they.
Generally, a properly set up dampener will deal with it.
Full blown slappers are a heart in mouth event, had one once (eons ago on my Norton), never want one again.
post #17 of 18 Old 04-01-2011, 06:25 PM
arctic954's Avatar
I would like to see opinions from those that HAVE put a damper on their 919's.
I have about 2 weeks worth of 'shake down' rides on my 919 with the Ohlins damper. Sure, I agree it's probably not needed unless your in an extreme case in which your probably F'd anyway..... But there is NO DOUBT a solidness added to the front end of the bike with a couple gentle clicks (as long as you don't over do it). I find that I'm not fighting the bike as much at higher speeds (+100) over semi-rough pavement......I'm also not getting the bars jerked away from me while accidentally hitting rougher pavement. (the Ohlins has a damping circuit that stiffens up the damper during a hard jerk)
I'll admit though.....I'm an aggressive rider, and I like my bikes setup to turn pretty quick.
I would however encourage anyone to try it first before shooting it down.....
post #18 of 18 Old 04-01-2011, 06:43 PM
I think a damper could easily be quite useful for the setup you use.
Steepened front ends change the equation.
You've dropped your front in relation to the rear, and not by just a bit.
I've tried to keep mine at the same height in relation to the rear which I have raised.
And your comments about just a few clicks and not going to stiff is spot on.
I've had some front end stuff show on mine at the track, but nothing bad enough.
I'll bet if I rode yours, I get off and say too nervous a nellie for me, while you'd get off of mine and say too much hard work on the bars to get stuff happening fast enough.
