Second Hand PC3 - Wrist Twisters
post #1 of 19 Old 04-01-2012, 11:04 PM Thread Starter
nate919's Avatar
Second Hand PC3
So I have the opportunity to grab a second power commander 3 USB. However I have no experience with any PC's at all. So I'm a little uncertain. I have read the installation instruction on the website and it looks pretty straight forward. The one I'm buying doesn't have the cd that comes with them new, or the mini USB, but I figure I can download the software, and a mini USB is cheap to buy. I haven't done any mods, but when I do a set of pipes I intend to add a PC, and maybe have it dyno'd. Besides I hear that even on a stock bike a PC makes a big difference. Around town I did find the throttle a little jerky. So my questions are:
1) Is buying a second hand power commander smart, or should I save and get a new one?
2) are there any vital components, leads etc that I'll need excluding the USB?
3) currently the map is for a set of after market cans, is it easy to change the map using the software on a computer?
Any other in put would be greatly appreciated. Clearly I'm a noob on this subject so all input is welcome!
Thanks WT!
nate919 is offline
post #2 of 19 Old 04-02-2012, 12:14 AM
Thanks WT!
I can confirm that part. I have a stone stock bike, in terms of pipes etc, and would not give up my PC iii for the world. I'm reminded of its value (in smoothing the throttle) every time I shift gear, and certainly every time I have to trickle along in traffic - which is all the time. Totally worth it, even if you never rev it past (a number I won't reveal here) and couldn't give a monkey's about pure peak hp numbers.
Lots of maps loose in WT-land, choose one, run it, change it etc. easiest thing in
the world.
You will need the PC software, which came to me on a disk, and you will need a laptop or netbook or something to run it on. Beyond that, couldn't be simpler, assuming you know your way around basic computing.
Over to you, blue.
K1w1Boy is offline
post #3 of 19 Old 04-02-2012, 02:29 AM Thread Starter
nate919's Avatar
Over to you, blue.
Sounds very tempting so far! I ride everyday in the city so it would be worth my while i think. Im pretty handy with computers. My question is but my laptop battery is rooted, and I don't have a power source near my bike, I live in an apartment building. So do I need to take my laptop to my bike, or can I take the pc to my laptop upstairs. I'm in the process of saving for a new laptop but I'm getting a Mac and I'm pretty sure the software isnt Mac compatible.
nate919 is offline
post #4 of 19 Old 04-02-2012, 02:55 AM
If you're going to get the bike dyno-ed, you might as well pay for the service for them to tune it and get a custom map. They'll configure it optimal settings for your setup and riding conditions.
I don't see the problem with removing the Power Commander to load a different map considering it will come loaded with the previous owners map. It doesn't lose programming when it's disconnected from the bike
post #5 of 19 Old 04-02-2012, 02:57 AM
Hi, in short do it! At least you then have the flexibility of altering the map should you make further changes on top of the PC optimising your bike from the get go.
The PC does , if I remember correctly, need power to upload maps. Use a 9v battery with the lead supplied as your power source then fit the PC. My suggestion, hope it helps.
Mark
hornet641 is offline
post #6 of 19 Old 04-02-2012, 02:59 AM Thread Starter
nate919's Avatar
Yeah that's what I was planning on doing. A tune and custom map down the track. But I was holding off till I got my pipes. So my thinking was I can get this pc and load a map for a stock bike, then down the track get it tuned and a custom map. Is that how it works, or am I missing something? Thanks for input!
nate919 is offline
post #7 of 19 Old 04-02-2012, 03:05 AM
Total Awards: 17
you could always use it with stock pipes as 919 set up to run lean with OEM setup hence stink. How much are you getting it for (if you don't mind)?
zaq123 is offline
post #8 of 19 Old 04-02-2012, 03:16 AM Thread Starter
nate919's Avatar
The guy wants $90. So I figure it's not a lot, and it cant harm can it?? As you can see I have no idea about EFI adjustments. Also I'm one of the lucky ones that doesn't havent any stink. I can ride all day and me, nor my pillion, smell at all!!
nate919 is offline
post #9 of 19 Old 04-02-2012, 03:20 AM
Total Awards: 17
you have it, smell your jackets after the ride. $90 -buy it NOW if it's in working condition.
zaq123 is offline
post #10 of 19 Old 04-02-2012, 03:22 AM
Not to mention $90 in Australia, where everything motorcycle-wise is bloated in price
post #11 of 19 Old 04-02-2012, 03:25 AM Thread Starter
nate919's Avatar
I'm so sure neither of us smell at all, and I have a textile jacket which I thought would trap the smell. I ride to uni and on cold days and wear my jacket all day and it doesn't smell at all. Confused! $90 isn't much but im a poor student lol!
nate919 is offline
post #12 of 19 Old 04-02-2012, 03:25 AM Thread Starter
nate919's Avatar
Yeah tell me about! Its a joke!!!
nate919 is offline
post #13 of 19 Old 04-02-2012, 03:27 AM
You have one of those sought-after 919s with no stink. I on the other hand have the exact opposite and I shower daily, sometimes 2x a day
post #14 of 19 Old 04-02-2012, 03:31 AM
Total Awards: 17
hear you on being a student part, been there myself. If you want get it, you should refer it to some aussies here, on WT
zaq123 is offline
post #15 of 19 Old 04-02-2012, 03:33 AM Thread Starter
nate919's Avatar
Before I bought it I was thinking I would have to do the header conversion to fix it, because it would really bother me. But I can ride in the city, so no draft to blow it away, then sit in lectures all day with my jacket and jeans on and I don't smell a thing, and no one has said anything, maybe they are just polite!!
nate919 is offline
post #16 of 19 Old 04-02-2012, 03:36 AM Thread Starter
nate919's Avatar
Yeah for sure, if I don't get it I'll pass it to someone here definitely!
nate919 is offline
post #17 of 19 Old 04-02-2012, 01:55 PM
Ginger-prick
EatDirtFartDust's Avatar
I'm in the market for a second hand pciii if anyone reading this happens across one...
2007 Honda 919.
EatDirtFartDust is offline
post #18 of 19 Old 04-03-2012, 01:10 PM Thread Starter
nate919's Avatar
Bump, any more input to be had? ☺
nate919 is offline
post #19 of 19 Old 04-03-2012, 01:37 PM
If you want to buy new, I believe I read on one of the threads that LordDuckHunter ships down under. He offers them to members at a very competitive price and if you were to compare to local prices (from what I gather everything is ridiculous there), you'd still be ahead.
