Scorpio Install - Wrist Twisters
post #1 of 19 Old 10-07-2013, 04:41 PM Thread Starter
Tool & Die
morrow919's Avatar
Scorpio Install
Before I start the install, does anyone have any pointers about where to locate this Scorpio alarm that came in the mail this afternoon? Curtousy of HeliMech, thanks man.
'07 Hornet - Candy Glory Red
morrow919 is offline
post #2 of 19 Old 10-07-2013, 05:55 PM
I removed a plastic tab from the l/h side of my undertail, making a flat spot. Thats where my alarm is installed. Try to keep the antenna away from metal, and be careful it is redicously loud if activated indoors!
post #3 of 19 Old 10-07-2013, 06:00 PM Thread Starter
Tool & Die
morrow919's Avatar
Hummm. That's where my PCIII is. Lol
Wheres your PCIII then?
post #4 of 19 Old 10-07-2013, 06:04 PM
I have a corbin seat so I have LOTS more clearance under the seat, I run my PC3 right on the center frame spine. I can get some pics in the morning but I know from helping another member install his PC3 at my place, the OEM seat sucks for pan clearance and you can't set things up the way I have them...... we tried.
post #5 of 19 Old 10-07-2013, 06:32 PM Thread Starter
Tool & Die
morrow919's Avatar
Well thanks for the input anyway. Maybe someone can chime in that has a stock seat with a PCIII and alarm.
post #6 of 19 Old 10-07-2013, 06:52 PM
If you can't find a spot under the seat, you could upgrade to a Shorai battery and use the extra space instead of using spacers. Without the padding you're suppose to use, there's a ton of space in the battery box to slide it into.
post #7 of 19 Old 10-08-2013, 04:44 AM Thread Starter
Tool & Die
morrow919's Avatar
I hate to do that, I just bought a new battery last season. Besides, with my recent 9er upgrades, I'm kinda tapped out at the moment.
post #8 of 19 Old 10-08-2013, 04:47 AM
The scorpio unit is small and should be easy enough to hide in the tail somewhere.
Can u post a pic of your current under seat area/setup?
post #9 of 19 Old 10-08-2013, 05:11 AM Thread Starter
Tool & Die
morrow919's Avatar
Yeah. I'll go out to the parking lot on break and snap a pic. I asked in another thread, but do you think I need to get a distribtion block for the grounds. I've already got two grounds added at the battery, the alarm will make it three. I'm thinking the only issue is space.?
post #10 of 19 Old 10-08-2013, 05:54 AM
I know I had a tough time even adding a second set of leads to my battery. Had a connection for a battery tender on it from the previous owner, and wired in a battery charger for my iron butt... it took me a solid half hour and some gentle forcefullness to get the battery back in. I would suggest adding a distribution block. I'm assuming if you're talking about doing it for the ground that your battery goes in ground first? mine was in positive first when I got the bike...
post #11 of 19 Old 10-08-2013, 06:04 AM
You don't need a distribution block for additional grounds.
Just use the frame. The frame is the primary grounding circuit for tge entire machine. I have a bunch of aftermarket accessories and have drilled tapped and bonded two different ground points fwd and aft.
The steel frame is easy to tap and work with, good wall thicjbessr and very sturdy.
post #12 of 19 Old 10-08-2013, 06:09 AM Thread Starter
Tool & Die
morrow919's Avatar
My battery is in Positive post first too. It's just a pain trying to stack several grounds on it. I thought about grounding to the frame, but wasn't sure. Usually the easiest solution is the best, drill...tap and done. Do you happen to know the wall thickness of the frame off hand, or remember what size tap you used for the ground screws?
post #13 of 19 Old 10-08-2013, 06:23 AM
The wall thickness is decent. You get at least 2-3 threads cut.
I use the same stainless bolts i sell with the PAIR plates. Not 100% sure on thread and pitch.... maybe m6x1.25.
post #14 of 19 Old 10-08-2013, 06:40 AM Thread Starter
Tool & Die
morrow919's Avatar
Cool. I believe ive got a tap close to that size. Heres the pic under my seat. Nothings permanently placed. Im picking up some velcro this afternoon and routing the wires under the frame to permanently place the PC and alarm.
post #15 of 19 Old 10-09-2013, 07:16 AM
abadacus's Avatar
I hope you have more luck than me.. I have an i800 that I just dont use anymore because is constantly throws out false alarms...
Thr RFID auto on/off didn't work either..
Just as aerodynamic airplanes are simple and streamlined, a motorcycle--which manages to balance an engine and a seat between two wheels--has a mechanical integrity, with intertwining pipes, chains and springs, that is fascinating to behold - Peter Plagens
abadacus is offline
post #16 of 19 Old 10-09-2013, 08:06 AM Thread Starter
Tool & Die
morrow919's Avatar
I hope so too. Sorry to hear about your luck with the 800. So far it seems to work fine, i just need to relocate the proximity sensor so that it picks up well from both sides of the bike. Right now it picks up real well from the front, back, and on the clutch side but not too good on the break side. I havent tried the auto arm and disarm yet, havent been able to get the transever to activate it. Im going to take a closer look at it at lunch.
post #17 of 19 Old 10-09-2013, 08:30 AM
Nice man, good to hear its working well. I know the units history and its was always treated well with minimal use. Previous owners bike lived in heated underground parking 99% of the time.
Did you wire in the lights to flash? Hows the noise level?
post #18 of 19 Old 10-09-2013, 10:05 AM Thread Starter
Tool & Die
morrow919's Avatar
Yep. The blinkers flash when arming and disarming. The volume is really good. I relocated the proximity sensor under the tail instead of next to the frame and it works great now. However I cant get the auto arm and disarm to work. Unfortunately scorpio was no help. The guy told me that its an old model that never had that feature! What the heck is this then?
post #19 of 19 Old 10-09-2013, 10:08 AM Thread Starter
Tool & Die
morrow919's Avatar
O, and heres a pic of where I've got everything routed.
