Request Advice: Rhino bar ends v. Motovation bar ends - Wrist Twisters
post #1 of 11 Old 10-24-2010, 11:51 AM Thread Starter
Hey Riders,
I wanted your advice on the better bar end. I have a Honda 919 (2007), which gets buzzy at the higher RPMs. I've heard that weighted bar ends can help reduce the vibrations. The two names I've heard most often are Rhino brand and Motovation brand.
Anyone ever tried either, to see if they are about the same, or different? The Rhinos are $59.99 for a set of two. The Motovations are $179.98 for two. Obviously a big difference. Comments comparing both (or either) would be appreciated.
Thanks
Rhino:
Rhino Motorcycle Products
Motovation:
Honda Bar End Weights / Sliders - Most Hondas
rjk555 is offline
post #2 of 11 Old 10-24-2010, 11:57 AM
I think most people would agree that it is better to replace the OEM bars first. They seem to make most of the buzz.
post #3 of 11 Old 10-24-2010, 12:39 PM
The factory bars have a rubber mounted dampener plus the external bar ends. Rather serious effort to damp things out right from the factory. Steel being a very "bright" material is part of it. Bright meaning it transmits vibration very well. I doubt that different bar ends will help you with the stock bars. Try aluminum bars with bar ends.
post #4 of 11 Old 10-24-2010, 01:10 PM
It looks like the Motovation pieces are designed to work with the factory inserts, they appear to have the funny "stepped" inner end on them.
I like the Rhino axle slider units, I wonder which ones could be adapted for the 9er
post #5 of 11 Old 10-24-2010, 01:54 PM
Throttlemeister throttle lock and bar end, the heavy version, all the way.
post #6 of 11 Old 10-24-2010, 02:08 PM
If you are running stock bars with the stock bar weights I doubt there is any advantage in changing them - you'd be better off putting on some new grips with thicker rubber as the stock ones are silly thin.
I found the stock bars offered very good vibe dampening - well in the two days they stayed on my bike! worlds weirdest bend IMO!
Alloy bars will alter the vibe but without bar end weights it will still be there. You are on the right track looking at stainless steel weighted bars - don't be fooled by any of the pretty coloured alloy ones - they offer nothing in vibe reduction due to their light weight.
I've got alloy ultra lows, bar end mirrors and I made some stainless steel bar end weights from a piece of 30mm round solid - machined to 35mm long, bored for the bolt and rubber retainer like other end weights, I find the bars are vibration free.
post #7 of 11 Old 10-24-2010, 06:26 PM
arctic954's Avatar
Renthal ultra lows plus CRG mirrors/weights...... Feels great ......vibration & bend.
But then again....just came off a ktm supermoto....anything feels smoother than a single at 80.
arctic954 is offline
post #8 of 11 Old 10-25-2010, 09:54 AM
Don't waste your money. A set of Renthal bars is a better way to go than either of those alternatives. I put on a Renthal bar with Rizoma grips and endcaps and feel nothing. No buzz. There are no weights and no internal dampeners. Just the naked bar and the alloy Rizoma grips and caps.
DennisKirk.com - Search Results
$64 for silver gray or gold
2015 Ducati Monster 1200S
FlyCatcher is offline
post #9 of 11 Old 10-25-2010, 01:12 PM
Ditto that, although I got the Rizoma bar with risers and ends. Now, how about that left footpeg?
post #10 of 11 Old 10-25-2010, 06:20 PM
Bawahahahahaha
yep - that is the only vibe I get too! I think it is drive train/output related and there to stay - if it was a British or European bike it would be applauded and called 'character'.
post #11 of 11 Old 10-29-2010, 04:51 AM Thread Starter
Thank you everyone for your input. Will look into new bars.
rjk555 is offline
