Renthal streetfighter bars(with pad) - Wrist Twisters
post #1 of 5 Old 03-20-2012, 01:10 AM Thread Starter
GreyHornet919's Avatar
Hey guys I have seen a few of you with these bars and I really like the look. I want to order a pair,but before i do can a owner tell me what else i would need to install? also how hard is the swap?
thanks.
GreyHornet919 is offline
post #2 of 5 Old 03-20-2012, 02:20 AM
I have those bars and did the swap, it's very easy. Just gotta be careful when drilling the holes in the new bars......measure thrice drill once. I'm very happy with the bars, fashion and function.
deebz is offline
post #3 of 5 Old 03-20-2012, 04:36 AM
mercenario27's Avatar
The stock handle bars have holes predrilled in them for the the tabs in the throttle tube and blinker assembly. I just cut off the tabs.
Current
2006 Honda CB900F 919 Hornet
Sold
1996 Suzuki GSF750 Kan.of.tuna
1985 Honda VF700 Intercepter
1997 Suzuki DR650
mercenario27 is offline
post #4 of 5 Old 03-20-2012, 08:24 AM
The trick I used was put the control pod on as best you can and get it in the right position for your feel (don't got too far forward on the throttle side, your brake lever still has to fit under the throttle cables).
Once you have it in place, pull the bottom plate off, the one with the pin. Keep the top in place and don't move it!
Put a dab of water or spit on the pin, then put it back in place. Wherever it touches the bars, you'll now have a dab of water/spit right where you want to drill. Grab a pencil or whatever and mark that spot. Then drill.
This is what I did and it was spot on, both sides. Plus, no movement.
post #5 of 5 Old 03-21-2012, 11:57 AM Thread Starter
stock clamps are correct size? Im sure i can figure out how to remove the controls, but how do you get throttle of?
thanks again guys
