Renthal bars for 919 vibration damping - Wrist Twisters
post #1 of 11 Old 01-09-2014, 06:23 AM Thread Starter
Garcia242's Avatar
I take it the general consensus is that the Renthal bars are great for damping the vibration my hands suffer from around the 4500rpm on the 919. I tried the Throttlemeister, and while I like it, it doesn't do much to cure the vibes. Even with the extra heavy bar ends.
So now I'm considering Renthal bars, for both looks and vibration damping. But I don't think the Meister will fit the Renthals. Smaller ID right? Can anyone confirm that?
Thanks
Garcia242 is offline
post #2 of 11 Old 01-09-2014, 07:06 AM
yes, the renthals do have a significantly smaller ID than stock and most other bars. This is the same reason they help so much with vibration as they are much thicker than a lot of other bars. Some people have drilled out the ends to add bar end mirrors or vibranators, and I don't see there being a huge obstacle to doing this with the throttlemeister... the only possible problem would be weakness in a tip over or crash, and even then, it's as thick as a stock bar would be, so it shouldn't be a huge issue.
post #3 of 11 Old 01-09-2014, 07:18 AM
The Instigator
Ditch's Avatar
Mine came with a throttlemiester and I never used it, so I sold it. After I took it off and with nothing at all in there the vibs went away by 80%. I'm starting to thing the "heavier is better" is a scam by the bar weight manufacturers. Seems to be all about matching the engine's vib frequency to me. Which is what the renthals to btw.
Ditch is offline
post #4 of 11 Old 01-09-2014, 08:04 AM Thread Starter
Garcia242's Avatar
Yeah I don't really use my Throttlemeister all that much. So I think I might be seeing an upgrade in the near future.
Thanks
my name is steve
i live in a box
my favorite color is clear
post #5 of 11 Old 01-10-2014, 01:50 PM
rpcraft's Avatar
I use a throttle boss for distance riding but a crampbuster is pretty much the same thing. You can get them on Amazon and the prices range from around 3 to 15 bucks depending on the style you get. They work great for extending your hand and being able to avoid cramps from holding the throttle closed or tightly.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #6 of 11 Old 01-10-2014, 03:31 PM
These work pretty good too. Just holds the throttle in position while you stretch your hand. They won't hold your speed if you hit a hill.
Go Cruise throttle control
post #7 of 11 Old 01-10-2014, 07:44 PM
The Instigator
Ditch's Avatar
^ Yup that's what i got. Works great but you do have to get used to something being next to your thumb.
Ditch is offline
post #8 of 11 Old 01-12-2014, 02:28 PM
Pierre-Marc
isn't that called your index finger?
mx463 is offline
post #9 of 11 Old 01-14-2014, 05:51 PM
The Instigator
Ditch's Avatar
Thumb is what seems the most intrusive.
Ditch is offline
post #10 of 11 Old 01-15-2014, 04:18 AM
Tool & Die
morrow919's Avatar
TWSS!
'07 Hornet - Candy Glory Red
morrow919 is offline
post #11 of 11 Old 01-15-2014, 10:55 PM
The Instigator
Ditch's Avatar
lol
Ditch is offline
