rear flat rack for 919 options? - Wrist Twisters
post #1 of 6 Old 09-09-2014, 07:27 PM Thread Starter
Just got the bike... have seen the mounting stuff for hard luggage, but am really looking for some sort of flat deck that can cover the passenger seat out to the tail. just so i can lash down a small lunchbox type cooler or a rectangular flat bag.
All I'm seeing are racks that mount at the grab handle and then stick out the ass-end of the bike.
Carphunter is offline
post #2 of 6 Old 09-10-2014, 02:06 AM
Lido's Avatar
That cause that's all there is unless you custom fab, but the givi is a good starting point very sturdy.
Lido is offline
post #3 of 6 Old 09-10-2014, 02:43 AM
Curmudgeon
semi_gray's Avatar
I use a Ventura rack. It's pointed forward most of the time, but it can be mounted either over the rear portion of the seat, or over the rear toward the tail.
919 Ventura link
semi_gray is offline
post #4 of 6 Old 09-10-2014, 05:14 AM
919 Ventura link
Same here. Works great.
post #5 of 6 Old 09-10-2014, 11:49 AM Thread Starter
did you guys get the one with the sport type or the pack type? is the only attachment point for the L bracket on a 919 the grab handle bolts... or am i not seeing some other part of the assembly?
THanks
post #6 of 6 Old 09-10-2014, 01:54 PM
Curmudgeon
semi_gray's Avatar
THanks
Sport type.
Shorter hoop.
The grab handle is removed and replaced with two brackets that attach to the sub-frame via (4) 8MM Socket Head Cap Screws.
These are plenty strong.
The only thing I don't really care for is where the bracket passes through the bodywork, a foam "gasket" is provided which looks like hell and is pretty much useless.
I started to design a better solution, but soon learned to live with it.
