Power commander program and lights dont agree - Wrist Twisters
post #1 of 5 Old 05-31-2015, 01:40 PM Thread Starter
So I put my yosh pipes back on for my track day tomorrow, and went to change the map back in my power commander. I reset the throttle position, and now when I crank the throttle it shows 100% in the program, but only lights 8/10 lights on the actual unit... I'm pretty sure I remember it going to 10/10 in the past. Any ideas?
post #2 of 5 Old 05-31-2015, 03:19 PM
redline919's Avatar
Isn't that the fuel to air ratio? Are you referring to when you first turn it on or after it zeros out?
redline919 is offline
post #3 of 5 Old 05-31-2015, 04:33 PM Thread Starter
When you key on it sweeps up and down, and if you use the buttons to adjust the ratio it shows up there. But when you crank the throttle up and down the light goes up and down with the throttle.
post #4 of 5 Old 05-31-2015, 04:48 PM
redline919's Avatar
Yup that's what mine does . I just checked it
post #5 of 5 Old 05-31-2015, 06:02 PM
redline919's Avatar
Actually mine only goes about halfway up when you crack on the throttle. Now you have me wondering if I'm running lean
