Portable alternative to center stand? - Wrist Twisters
post #1 of 15 Old 10-16-2010, 05:33 AM Thread Starter
Question Portable alternative to center stand?
I've been looking for a portable alternative to the center stand. Something compact and lightweight that I can store under the seat. Nothing heavy duty, just a "in case of emergency" stand that I can use if I'm on a ride and have a problem that needs the rear wheel raised for repair, chain lubing or possible removal.
I've found a few alternatives but nothing that really looks like what I want. They're either designed for spools only or they're a little expensive.
I'm not a good fabricator or I'd make my own. I guess if I was in a bind I could always look for an appropriate piece of wood on the road or something similar.
I was wondering if anyone had seen any other alternatives to what I've already found.
Here's what I got so far...
PackJack - Home - Small & affordable but requires either swingarm spools, which I don't have, or using the axle nut, which prevents removal of the wheel.
Portable Motorcycle Jack - Honda Hornet 599 919 CB600F: eBay Motors (item 380278756343 end time Oct-20-10 12:49:45 PDT) - another good option but $75 is a little steep for me.
Tour Prop Motorcycle Stand - another good option and is affordable but they don't really tell you much about it. Seems like you set it in place and adjust the center piece like a turnbuckle. Looking at the pictures I'm not sure about it. I'll have to ask them how it works.
Quick Stand - another affordable option but again, designed for spools only.
I know there's a lot of creative thinkers here so thanks for any ideas.
garyb900 is offline
post #2 of 15 Old 10-16-2010, 06:26 AM
Is this something like what you mean?
https://www.wristtwisters.com/f86/sha...ick-24125.html
post #3 of 15 Old 10-16-2010, 09:35 AM
919 aka Hornet 900
Mr T81's Avatar
^When I went to the mountains with the guys a couple months ago, Z1-jockey was carying a wooden stick with I'm. Cut to the proper length it work pretty well, we all used it to lube our chains.
Mr T81 is offline
post #4 of 15 Old 10-16-2010, 05:22 PM
BrokeRecord
What's wrong with a centerstand?
brokerecord is offline
post #5 of 15 Old 10-16-2010, 05:59 PM
^^+1, might add a bit of weight and not look "cool" but they're functional...
post #6 of 15 Old 10-17-2010, 10:44 AM
I'll take the centre stand over a lean stand anytime and everytime. But I'd never leave it on for a Track Day.
post #7 of 15 Old 10-17-2010, 12:21 PM
I can see your point, more weight and could cause a problem in the turns.
post #8 of 15 Old 10-21-2010, 11:44 AM Thread Starter
https://www.wristtwisters.com/f86/sha...ick-24125.html.
Yes, Shadow, that would do the trick, Thanks! I hope you don't mind my using your idea. I scrounged around my basement and made a similar item.
garyb900 is offline
post #9 of 15 Old 10-21-2010, 11:47 AM Thread Starter
Nothing wrong with a centerstand. I've always had them on my bikes and like them but I also have a T-rex front and rear stand for home use and I just got a wild hair up my butt and started thinking about aesthetics and the weight savings.
garyb900 is offline
post #10 of 15 Old 10-21-2010, 07:38 PM
Nope, I don't mind a bit! Happy trails and easy chain maintenance my friend!
post #11 of 15 Old 10-22-2010, 10:52 AM
BrokeRecord
RE:
My neighbor had a CBR1000. We built up a conglomaration of barbell plates, wood blocks, and a floor jack to change new tires. One tug too many on the axle nut, and all hell broke loose. A sound that made women and children cry with fright. When the dust settled, we had turn signals, mirrors, and scratches every where. Mine and his next bike had centerstands.
I don't mind losing that .00031 seconds in my 1/4 mile times, from the extra weight.
post #12 of 15 Old 10-27-2010, 12:14 AM
meh, its not the weight or times that's a concern with the center stand, its when you carry too much lean angle (at the track) and it decides to dig in and lift the rear. Can be a bit hairy.
davehirt is offline
post #13 of 15 Old 10-28-2010, 04:02 PM
The only reason why centerstands have such a bad reputation is by and large the foot pedal arm has to go under low mounted exhausts, obviously not a problem on a 919, or for my '88 Hawk either. My '02 has had a OEM centerstand on it since about a week after I bought it. Since then I've bevelled the left footpeg until most of the underside is ground down (and yes, I do hang off in corners) and no part of the stand has come anywhere near the ground, even when I tipped it over in a parking lot.
It's not what you know that will cause you trouble -- it's what you know that ain't so!
post #14 of 15 Old 10-28-2010, 05:16 PM
^^Good to know it ain't so...
post #15 of 15 Old 11-09-2010, 06:40 PM
I would've gotten the PackJack, but the shipping/handling damn near equals the cost the item! I agree that the Cycle Machines Works Portable Jacks at $75 isS$$$. I also looked at your mentioned Anderson Tour Prop stand, like you said there's no info on that one. The DIY seems like the smarter option.
genie is offline
