Please educate me about PCIII - Wrist Twisters
post #1 of 17 Old 03-02-2011, 03:32 AM Thread Starter
Dead Wrong
Effe's Avatar
Hey everyone,
I have been modifying my bike for a while now and I just bought a PCIII from ebay (180$ good price I think), to be very honest I have no idea what it does other than what I heard from people around. Some say it does nothing important for its price, others say it is a must have for all fuel injected bikes.
Please educate me...
Effe is offline
post #2 of 17 Old 03-02-2011, 07:07 AM
My basic understanding is this. On a bike like the 919, Honda spent about 5 minutes tuning the ECM. That results in uneven, poor fuel mappings. This can cause a multitude of minor inefficiencies none of which are going to stop your bike from running. Some of the things riders have improved with a PCIII is the stink, low speed throttle modulation, uneven power through the RPM range and others.
I think the most important thing it improves is low speed throttle response and smoothing your power curve. Any bike will need different amounts of fuel for different RPM and throttle position. The PCIII allows you to custom tune your fuel map for peak efficiency. That being said, to take full advantage of its capabilities you should get the bike dyno tuned by an expert. The next best thing to do is get a map from someone who has the same setup as you. This includes pipes, airbox mods and anything else that could affect the stoichiometric ratio - fuel/air.
If anything stated above is inaccurate chime in please.
Results vary from bike to bike. Some can get a pretty decent increase in power simply by custom tuning the map. Others notice nothing at all.
2015 Ducati Monster 1200S
FlyCatcher is offline
post #3 of 17 Old 03-02-2011, 10:36 AM
Originally Posted by Effe View Post
Hey everyone,
I have a fairly decent compilation of info I have put together for myself and others.
If you want it, send me a PM with an e mail address that will accept PDF file type attachments, and I will e mail it to you. Others on this website have asked for it, and some different map files are included as part of it.
post #4 of 17 Old 03-02-2011, 04:50 PM
I can vouch. He sent me some maps as well; I even sent my map back after I had it dyno'd (I have a 900RR header setup with custom Scorpion can).
And $180 is a decent deal, but you just missed out: Osiris (on here) just picked his up for $105. Also on ebay. Just three days ago.
And FlyCatcher pretty much summed it up. For my bike it leaned it out a hair (the Dyno guy did this) and smoothed the throttle out. Seemed I had a bit more power down low and not quite that jerky snap that came on at about 4800 RPMs.
post #5 of 17 Old 03-02-2011, 07:57 PM
I just sent a pile of stuff out to the 5 that have asked for it so far.
post #6 of 17 Old 03-03-2011, 12:19 AM Thread Starter
Dead Wrong
Effe's Avatar
Thanks a bunch... These will help. Engine has to run when I map/remap the thing?
Effe is offline
post #7 of 17 Old 03-03-2011, 06:45 AM
To install a different map into a Power Commander on a 919, you just have to connect your laptop to the P C with the USB patch cord, and turn your key on to the run (ignition) position. The engine does not need to be running.
post #8 of 17 Old 03-03-2011, 07:07 AM
firedave's Avatar
Thanks mcromo44!
2016 Honda Africa Twin
1998 Kawi ZX9R (Sold)
firedave is offline
post #9 of 17 Old 03-03-2011, 08:51 AM
If you have the 9Volt adapter, you can also hook that up to the back of the unit with a 9v battery. You can then see the PC via your computer and USB cable and save and upload maps to it.
I had to do this once as my battery was mostly dead and it was late at night, so I didn't want to wake the little ones. Besides, you won't know a lick of difference in the maps until you take her out and open her up. I never noticed any difference at idle.
Don't forget to set your throttle position! You do have to do this with the bike key ON, but NOT started. There is a menu option in the software to do this; then all you do is, starting from no throttle, is open her all the way to 100% and then let go. That's it.
post #10 of 17 Old 03-03-2011, 10:08 AM
Excellent points, especially the reminder on the Throttle Positioner synching.
post #11 of 17 Old 03-04-2011, 12:30 AM Thread Starter
Dead Wrong
Effe's Avatar
Thanks for the tip, what does the throttle positioning do? I have to do this after installing the maps or before?
Also this is out of topic but I found a great deal on a pair of brand new Carbon Delkevic cans. 300$... Since it is US made, I feel like trusting the quality. I watched some videos of it on a Hornet and they sound just the way I want. Have any opinion, knowledge or experience on Delkevic anyone?
I wanted to but D&D (decent price) but so many people said it is horrible so I decided not to.
Effe is offline
post #12 of 17 Old 03-04-2011, 04:41 AM
Carp Killer
Wallybanger's Avatar
lol Fuck! I bet you bought the one I was watching! Should have bid on it when it was 175 I guess. the guy relisted it twice before it sold.
Wallybanger is offline
post #13 of 17 Old 03-04-2011, 07:34 AM
Synch the PC III to the T P first.
Think of it this way.
The basic map is in the ECU which the T P is connected to.
The PCIII is a piggy back device.
It does not hold a map, and instead holds a map adjustment.
So when you ECU is ready to send a pulse width signal to the fuel injectors, the PCIII makes a small adjustment to the pulse width signal.
The ECU map is a co-ordinate map based on a matrix of % Throttle Opening X RPM.
The PCIII adjustment is written into a matching co-ordinate map.
Now think of the two maps as two grids that have to be perfectly aligned with one another, just like two pieces of graph paper stacked so the lines are exactly matched.
When you synch the PCIII to the T P, it's just like the graph paper analogy I described above.
To give you an idea of what can happen if you don't, here is a real world example. Engine at 2 % throttle opening, RPM @ 1500. PCIII Closed Throttle Position error of + 3 %. What happens is that the PCIII will alter the ECU 2 % x 1500 RPM output with a 5 % x 1500 RPM based pulse width adjustment, and the fueling will be wrong for the actual engine condition.
My 919 was out 2 %.
My son's 600 GSXR was out 5 % !
post #14 of 17 Old 03-04-2011, 10:54 AM
mambomonster's Avatar
I am a little frustrated with my PCIII so I suppose I have to take it to be tuned. I tried two different maps with stock exhaust and now I'm playing around with my new Leo Vince pipes. The issue I have is the nose dive on deceleration. All of the maps seem to increase that. The stock (or "zero" map) allows a smooth deceleration and I don't have to be so careful. With a map loaded I have to really ease off gently to avoid the nose dive. I buy into the benefits of the PCIII - is the nose dive just the trade off of getting better over all fueling?
mambomonster is offline
post #15 of 17 Old 03-04-2011, 02:11 PM
Hmmmm, you should not be having this occur.
In terms of 1st gear low RPM low throttle opening :
-Mine ran like crap with stock cans and no PC III.
-Mine ran like crap with the stock PC III map and the Yosh twin TRSs.
-Once I did the TPS synch, and had a decent baseline map in it, it was a different world. (the baseline map was LDH's V-4 Moriwaki based map, and in my opinion is THE definitive baseline map for 919s with stock headers and twin slip ons)
-Once set up as such, I can walk it down to below 1,000 in gear, use no clutch, and just use throttle for control.
So, maybe yours is not synch'd and/or you don't have a decent map in it.
BUT
There is also the nature of the stock 919 chassis. It's a high Centre of Gravity design with mush for front springs and very light damping. Add to that mix a fairly high compression engine with high leverage due the overall fairly short gearing of the bike. It's a perfect recipe for being a dive meister pogo stick special, be it from front brakes and/or shutting off the throttle abruptly.
So, if you have a stock front end, in particular - stock springs, all that is surely also part of what you are feeling and not liking.
(My front end is re-sprung and re-damped.)
post #16 of 17 Old 03-06-2011, 08:05 AM
Thanks for the insight. Yesterday I reset the throttle position again just to be safe and then loaded LDH's Sato map (the one called 919satonew2) from his zip file.
The nose dive seems less pronounced now, but it is still there sometimes. What I'm getting now is popping in the Leo Vince cans on decel - not sure if that's normal for the open pipes or a PCIII issue. Once I figure out what pipes I'm going to stay with I'll be off to find a dyno.
post #17 of 17 Old 03-06-2011, 08:51 AM
Are you familiar with the Map Compare feature in Tools of the PC software ?
In any event, do a Map Compare of the two maps to get a feel for what the differences are, they are significant, especially up to 40 % throttle opening.
My TRSs pop loudly and randomly from high RPM sharp throttle roll offs and track day type downshifting. It sounds wonderful ! The straight through design must surely be a major part of it, if not all of the reason.
