PCIII USB install help - Wrist Twisters
post #1 of 29 Old 10-05-2013, 07:23 AM Thread Starter
Tool & Die
morrow919's Avatar
Im trying to install the PCIII I picked up recently. im a bit confused at this point in the instructions. Im I missing the auxiliary wire?
'07 Hornet - Candy Glory Red
morrow919 is offline
post #2 of 29 Old 10-05-2013, 07:26 AM Thread Starter
Tool & Die
morrow919's Avatar
post #3 of 29 Old 10-05-2013, 07:45 AM
Nope u have eveything u need. I don't have the pc3 manual in front of me, but that Fig.F is not required.
#1.Splice in the grey wire.
#2. Plug in the jumper harness.
#3. ground the black wire.
That's it easy as 123. Enjoy.
post #4 of 29 Old 10-05-2013, 08:15 AM Thread Starter
Tool & Die
morrow919's Avatar
So where does the "connection from pciii" plug if I dont have the "supplied auxiliary wire"? Sorry if im being a bit dense.
post #5 of 29 Old 10-05-2013, 08:28 AM
IIRC, there was one wire that is only used on european models. The instructions tell you this in unclear terms, re-read the instructions and look for it.
post #6 of 29 Old 10-05-2013, 08:33 AM
Figure G. Steps 11 & 12 are for european models only.
The connection from PC3 plugs into the license plate wiring harness. (not 100% sure on this)
Pull all the connectors out of that silly looking opaque sleeve. Inside there will be a small 2 pin connector that looks like the ones off the PC3.
Disconnect the OEM cannon plug and install one end into ine side of the PC3 connector, and the other end into the other side.
It is a plug and play jumper harness used to supply the PC3 with ignition on 12v, without hacking into the wiring.
Hopefully that makes sense.
post #7 of 29 Old 10-05-2013, 08:39 AM Thread Starter
Tool & Die
morrow919's Avatar
I think I see now. Ill get back into it when I finish mowing my lawn. I appreciate the input and ill let you guys know if I run across any other questions. Thanks again.
post #8 of 29 Old 10-05-2013, 08:53 AM
The red wire with the male and female connestors is the tail light connection
voodooridr is online now
post #9 of 29 Old 10-05-2013, 10:08 AM
Be sure to sych the PC3 to the ECU.
Also, there's a tonne of good PC info in the DropBox
post #10 of 29 Old 10-05-2013, 10:52 AM Thread Starter
Tool & Die
morrow919's Avatar
How do you sync them? Im using my phone, not sure if I can get to the drop box info. Also, do you guys think bulb grease will work here in place of dielectric grease?
[color=gray]Sent from Motorcycle.com Free App[/555color]
post #11 of 29 Old 10-05-2013, 10:59 AM
One patches their PC3 to a PowerCommander software loaded computer and goes from there.
Get to a device that will let you access the DropBox, as some of the info is video tutorials.
It's not a simple description, but it is easy to do.
Get to the DropBox, get to the Power Commander Files then the McRomo44 Compilation.
It's all there, plus lots more info.
post #12 of 29 Old 10-05-2013, 11:12 AM Thread Starter
Tool & Die
morrow919's Avatar
Okay all the plug n play stuff is in place what about this gray wire is it not used?
post #13 of 29 Old 10-05-2013, 11:14 AM Thread Starter
Tool & Die
morrow919's Avatar
Where is the link to the drop box? Its been a long while since ive checked it out.
post #14 of 29 Old 10-05-2013, 11:54 AM
post #15 of 29 Old 10-05-2013, 11:59 AM
The grey wire gets spliced into the red/yellow wire on the grey ecu connector.
post #16 of 29 Old 10-05-2013, 11:59 AM Thread Starter
Tool & Die
morrow919's Avatar
Well crap! The link doesn't seem to work. Dropbox says it can't find the page.
post #17 of 29 Old 10-05-2013, 12:07 PM
Edited the link. Works from my Android?
post #18 of 29 Old 10-05-2013, 12:15 PM Thread Starter
Tool & Die
morrow919's Avatar
Cool. Thanks heli.
post #19 of 29 Old 10-05-2013, 12:20 PM
I'm pretty sure the sycing they're talking about is syncing the pcIII to the tps... It's under one of the windows in the power commander software.
post #20 of 29 Old 10-05-2013, 12:41 PM
Yes.
post #21 of 29 Old 10-05-2013, 01:15 PM Thread Starter
Tool & Die
morrow919's Avatar
So do I need to click reset then?
post #22 of 29 Old 10-05-2013, 01:20 PM
Click reset, and then move the throttle from closed to wide open a few times.... This lets the pc3 know where closed and open are as a value of the output of the tps
post #23 of 29 Old 10-05-2013, 01:21 PM
It doesn't need to be running, just keyed on... Wide open in neutral might be bad...lol
post #24 of 29 Old 10-05-2013, 01:21 PM
Yes you need to reset and sync the TPS to the PC3.
You don't have to have the engine running, just key turned on and ecu/pc3 powered up.
Twist the trottle to full wide open, then while holding it there hit reset to sync. Then do the same for fully closed throttle.
post #25 of 29 Old 10-05-2013, 02:08 PM Thread Starter
Tool & Die
morrow919's Avatar
Cool. Thanks guys. Any other advice?
post #26 of 29 Old 10-29-2013, 09:52 PM
No 10
insideleft's Avatar
I just spoke to a shop about buying a commander and was informed I'd also need an 02 Eliminator - anyone heard of this thing - cost around $44.00.
IL
No10
insideleft is offline
post #27 of 29 Old 10-30-2013, 12:14 AM
IL
There is no O2 sensor on the 919. Get a new shop.
See previously hashed thread on topic below.
https://www.wristtwisters.com/forums/...ler-26244.html
post #28 of 29 Old 10-30-2013, 04:00 AM
Tell them OK, but that you want the old sensor back once they remove it.
post #29 of 29 Old 10-30-2013, 08:08 AM
"I love the way your foul little mind works!"
