Loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever...
I use a large syringe (no needle) and a rubber hose that fits over the bleeder screw nipple and the syringe tip. Fill the master cylinder, pump pump pump the lever, crack the bleeder nut loose and draw the syringe, tighten the bleeder nut, refill the MC with the fluid from the syringe (if clean), and repeat.
You can get the large syringe from a drugstore for alot less than a vacuum pump and you have more draw control over the line air evacuation.
I gotta tell you, I've bought two vacuum bleeders over the last 10 years, and have thrown both of them away in frustration. I just don't think you get anywhere near as good of a bleed with them as you do the old fashioned way. Yep, it's a pain in the ass, but I'd rather have brakes that work better than do something the convenient way.
If you combine the mity-vac, and normal bleed it works way better (plus vacuuming out the old fluid from the resi vs. pulling it through the system).
The big ear syringes for a buck are great, but the DOT eats the seal so after a use they don't last well for next time.
Dont be a cheap@ss order a pair of SpeedBleeders from the link above, you will be so thankful in the long run!!!
The ONLY thing the MV is any good for is evacuating fluid for a line change, thats it!
You know what's funny? This is the first site that anyone has actually agreed with me about the MityVac. Anywhere else, it's like I had ****ed their sister or something.
hmmmm guess ya just have to be smarter than the MITY-VAC to use it correctly. lol
i will NEVER do it the ol fashion way EVER AGAIN !!! i pull 2-3 resys thru the lines and then crack the banjo at the master after reassembly of everything.
Related Threads
678.5K posts
10.2K members
Since 2006
