new plugs and wires - Wrist Twisters
post #1 of 14 Old 07-08-2011, 12:40 PM Thread Starter
MSF blacksheep
Ferris Bueller's Avatar
new plugs and wires
Just installed new ng iridium plugs and ngk race wires. Everything works great and looks even better. Pics of new wires and old plugs included. Notice the brown on the 4th cylinder plug. Any ideas what's wrong?
Ferris Bueller is offline
post #2 of 14 Old 07-08-2011, 01:00 PM
Wasn't torqued down properly, allowing exhaust gases to blow by?
post #3 of 14 Old 07-08-2011, 01:02 PM Thread Starter
MSF blacksheep
That's my guess. I've stripped stuff out before so i tend to under tighten sensitive parts. I hope that's all it is. I did tighten the new plugs a little tighter.
post #4 of 14 Old 07-08-2011, 01:47 PM
wish there were plug wires in another color than red!
post #5 of 14 Old 07-08-2011, 02:15 PM
Not being able to tell if it's wet or baked and fused, my guess is that it is either extruded thread lube from when the plugs were put in, or valve cover area leakage into the spark plug well past the seal.
post #6 of 14 Old 07-08-2011, 02:16 PM
Where did you get those boots and wires ?
Are the boots and/or wires resistance type or not ?
post #7 of 14 Old 07-08-2011, 03:53 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
That would be my guess.
Doc
ST-DocLizard1 is offline
post #8 of 14 Old 07-08-2011, 04:02 PM
Serial Monogamist
Total Awards: 21
If you don't have a torque wrench, I have always gone with 180 degrees from hand tight on a new plug/crush washer. Ninety degrees on a used plug.
Spark Plug Installation Instructions
Doc
post #9 of 14 Old 07-08-2011, 04:04 PM Thread Starter
MSF blacksheep
Ordered them from the local shop. They use parts unlimited. I don't know if they are resistor type or not. The use the same cr8ehix-9 plug as the stock wires.
post #10 of 14 Old 07-08-2011, 06:07 PM
can you wipe the "brown stuff" off the 4th plug... often times its just a lil oil that seeps down the spark plug tube from the valve cover... nothing to worry about.
also i woulda stuck with standard plugs... proven to produce more power in the long run, as the iridium tips tend to round making it harder for a spark to form.
post #11 of 14 Old 07-08-2011, 06:43 PM
I think whenever such an effect occurs, it's all or primarily a function of ground wire erosion, seeing as the centres last so much longer thus the grounds erode away a much greater amount before changeout time.
Also, I think that whenever such an effect occurs, it's only at full load, in other words full throttle.
post #12 of 14 Old 07-08-2011, 06:45 PM
What about the boot covers to seal off the spark plug wells at the top of the valve cover ?
post #13 of 14 Old 07-08-2011, 07:14 PM
+1, lots of stuff can build up in there over time...
post #14 of 14 Old 07-08-2011, 07:23 PM
you would be surprised... those center electrodes on irridiums round off pretty quick. LDH has done some dyno testing. on the subject if im not mistaken.
and yes, you are gotta make sure you have the lil caps that cover the spark plug hole there.... dont want stuffs gettin down in there.... theres probably weep holes but even then... every type of OHC setup has caps that cover those holes for a reason.
