New bars = bad master cylander issue - Wrist Twisters
post #1 of 10 Old 07-12-2015, 02:53 PM Thread Starter
Queens919's Avatar
Hello all,
Recently joined the group and has happy to get a lot of ideas for my 02 919.
I recently put some of them in to practice and while most were as easy as described I ran into one issue.
I changed the stock bars to a no rise drag bar and everything is ok except for the position of the master cylinder. Because of the size & the position of the brake lines I cannot get this to be in any sort of ergonomic position.
Advice? Thanks in advance for the help.
As you can see from the pic the right side is not in line with the left. It also through a if the mirror too.
I'm all ears.
Queens919 is offline
post #2 of 10 Old 07-12-2015, 03:01 PM
You could swap out your master cylinder for one which has a radial-mount layout [ie piston runs at right angles to bars, not parallel] and a remote reservoir, which might allow you a bit more space and flexibility.
K1w1Boy is offline
post #3 of 10 Old 07-12-2015, 03:38 PM Thread Starter
Queens919's Avatar
Thanks - I will start looking into that tonight. I appreciate your help.
post #4 of 10 Old 07-12-2015, 04:03 PM
No problem - it might be a matter of mixing and matching your componentry to end up with what you need in terms of fit on your pabars and feel at the lever.
M/c piston size is an important component in the latter part. I've ended up with a Gixxer radial m/c of 19mm driving some CBR600 calipers [bolt-on to the 919, same mount points] to get more bite and retian good feel.
Search the old threads for excellent brake information from the participants here - "master cylinder" a good search term.
Here's some of the stuff I've accumulated:
GSXR600/750 '04-'07 - OEM Radial Master Cylinder, 19.05mm
GSXR600/750 '08-'10 - OEM Radial Master Cylinder, 17mm
Yamaha R6/R1 - '5 newer - OEM Brembo Radial Master Cylinder, 16mm
RC-51/fireblade Front Brake Information
929-SP1 - Master Cylinder 19mm, Caliper pistons 34/32mm
954-SP2 - Master Cylinder 17mm, Caliper pistons 32/30mm
SP1 Brake Rotor Thickness 4.5mm
SP2 Brake Rotor Thickness 5.0mm
Other Information
2003-2004 CBR600RR mc 11/16” (17.4625 mm)
caliper pistons 32mm/30mm
2000-2001 CBR929RR mc 19mm
caliper pistons 34mm/30mm
2002-2003 CBR954RR mc 11/16” (17.4625 mm)
2000-2001 RC51 mc 19mm
caliper pistons 34mm/32mm
2002-present RC51 mc 11/16” (17.4625 mm)
1999-Present CBR600F4(i) mc 5/8” (15.87mm)
Stock VTR Master Cylinder 14mm
caliper pistons 30mm/27mm
Updated list:
the 919 has caliper pistons sized 30mm and 27 mm and a M/C of 14mm.
a SP1 RC51 has caliper piston sized 34mm and 32mm and a M/C of 19mm
a SP2 RC51 has caliper pistons sized 32mm and 30mm with a M/C of 17.5mm
929 caliper pistons are 34mm and 30mm with a M/C of 19mm
954 Caliper pistons are 32mm and 30mm with a M/C of 17.5mm
K1w1Boy is offline
post #5 of 10 Old 07-13-2015, 07:34 AM
Let's be practical here.
Sure, you could spend considerable time and money to get the bars to work by replacing all the front brake components. While you're at it you might as well install braided brake lines as well.
Or replacing the master cylinder with a 17.5mm radial unit from a Honda CBR1000. The angle problem will be solved, but there will not be a mirror mount. This is typical of most radial master cylinders.
Or obtain a set of risers to get the bars high enough to allow a proper angle for the master cylinder. Search Amazon.com for handlebar risers for lots of choices.
Or the least expensive approach is to obtain a different bar that frankly will be more comfortable than typical drag bars on rides much longer than a 1/4 mile. The biggest problem with straight drag bars is they are relatively wide, and with no pullback at all will require a very unnatural bend at the wrists to ride. Add to that the zero height above the mounts which will inevitably put much of your weight on your hands, making long rides very uncomfortable. Preferably something like this:Amazon.com: Emgo Superbike Handlebars - Chrome: Automotive
post #6 of 10 Old 07-14-2015, 04:45 PM
bartsitarski's Avatar
Let's be practical here. Sure, you could spend considerable time and money to get the bars to work by replacing all the front brake components. While you're at it you might as well install braided brake lines as well. Or replacing the master cylinder with a 17.5mm radial unit from a Honda CBR1000. The angle problem will be solved, but there will not be a mirror mount. This is typical of most radial master cylinders. Or obtain a set of risers to get the bars high enough to allow a proper angle for the master cylinder. Search Amazon.com for handlebar risers for lots of choices. Or the least expensive approach is to obtain a different bar that frankly will be more comfortable than typical drag bars on rides much longer than a 1/4 mile. The biggest problem with straight drag bars is they are relatively wide, and with no pullback at all will require a very unnatural bend at the wrists to ride. Add to that the zero height above the mounts which will inevitably put much of your weight on your hands, making long rides very uncomfortable. Preferably something like this:Amazon.com: Emgo Superbike Handlebars - Chrome: Automotive Rob
Plus one
-Michael Jordan
bartsitarski is offline
post #7 of 10 Old 07-17-2015, 11:09 AM
If you really want a low bar go with Renthal Ultra Lows. Tons of members have used them without issue.
post #8 of 10 Old 07-17-2015, 11:12 AM
I have a set of Renthal lows for sale.....
post #9 of 10 Old 07-17-2015, 01:18 PM
For reference (comes in black and other colors-not my pic).
post #10 of 10 Old 07-17-2015, 03:15 PM
redline919's Avatar
+1 on the Ultra lows. So much more comfortable. Actually makes the bike feel like it easier to maneuver. Looks pretty good also.
redline919 is offline
