new bars - Wrist Twisters
post #1 of 14 Old 07-05-2009, 08:28 PM Thread Starter
TACOS ROCK!!!
hooligan1's Avatar
new bars
hello all its been a while working a lot, any way im planning a new mod going to install some renthals 7/8 road bars, anyone have these i know there a litle wider i just want to make sure thay wont bump the tank when fully turned.and any in put will be apprechied thanx.
Wheelie's Happen !
hooligan1 is offline
post #2 of 14 Old 07-09-2009, 01:54 PM
I have a set of the Renthal "Ultra Low" on my bike with barend mirrors, and they don't hit the tank.
StreetFighter919 is offline
post #3 of 14 Old 07-09-2009, 03:02 PM
Vehicle Abuse Specialist
WheelieTime's Avatar
Renthal's???? Get some real handlebars!!!
WheelieTime is offline
post #4 of 14 Old 07-09-2009, 03:40 PM
Greg
May Man's Avatar
Anyone else notice apehangers are making a comeback after 30 years in the closet/garage/shed ?
May Man is offline
post #5 of 14 Old 07-09-2009, 03:44 PM Thread Starter
TACOS ROCK!!!
hooligan1's Avatar
will my new handlebars be pre drilled if i dont cut them i like the look of the ultra lows but i want to stay close to stock i was liking the renthal high road bar seem to be close to the stock bar a little bit lower and a little bit wider.
Wheelie's Happen !
post #6 of 14 Old 07-09-2009, 06:16 PM
High bars will work, but they won't be pre drilled, which is okay, it's not hard at all
03 DRZ 400
05 VFR 800A
05 GSXR 1000
04 Honda 919
00 Honda Shadow ACE
Epicsoldier is offline
post #7 of 14 Old 07-10-2009, 06:50 AM
I didnt drill my rizoma's since i wasnt sure if I would want to cut them later or not so i filled of the tabs inside the controls. In order to stop any movement of the controls i put small pieces of rubber hose on the inside of the controls. Now I am free to make changes to the bars as I would like.
post #8 of 14 Old 07-10-2009, 07:07 AM
Definately, I want to see someone with a set on a 919. Better yet on a wheelie with apehangers.
post #9 of 14 Old 07-11-2009, 08:45 PM
I have the Renthal mids and love them
More comfortable than the crappy stockers, look better and cuts down on the vibes even without barends
They don't come drilled nut it is a piece of cake and takes about five minutes even if you measure three times before you drill
gegarner is offline
post #10 of 14 Old 07-21-2009, 02:15 AM
78mikey810's Avatar
has anyone cut an onch or so off the ends? from the bars feeling too wide?
78mikey810 is offline
post #11 of 14 Old 07-21-2009, 04:53 AM
Total Awards: 17
no need to measure too many times, wrap a couple of wraps of electrical tape around the bar, put controls back on and tighten screws than remove controls. Tabs will leave nice print in the tape showing you exactly where to drill.
zaq123 is offline
post #12 of 14 Old 07-21-2009, 05:28 AM
speaking of handlebars. There is a new motorcycle shop in town so I stopped in yesterday. They carry a ton of on- and off-road stuff. I asked if they had any Renthal road bars and they said no. Then he looked up the specs and cross-referenced them to an off-road bar. The Pro-Taper RM Bend bars are the same except the sweep back. There is a 1.5 degree difference (the road bars are more swept). I might jump on them and give them a shot. they are only $45.
post #13 of 14 Old 07-24-2009, 12:58 PM
Lovin the Vanilla Ice
Igneale's Avatar
RM? Is that the Ricky Carmichael bars? I have a set in the basement I pulled of a dirtbike. Let me know how they work, I may try the same.
Two wheelin for the feelin.
Igneale is offline
post #14 of 14 Old 07-24-2009, 10:34 PM
You will have to drill yourself, but if you are going with Renthal High bars there will be no problem with hitting the tank. My Ultra lows have clearance.
