MIVV X-Cone Map - Wrist Twisters
post #1 of 6 Old 07-11-2012, 07:03 PM Thread Starter
diloret2's Avatar
MIVV X-Cone Map
I recently got MIVV X-Cones from a member on here and found this on their site...
Exhausts HONDA - CB 900 HORNET - SPORT - Silencers - MIVV
There's a map right on their site, but it says for the European version of the 919.
My question is would this work on a US version 919? Is there a huge difference in the PCMs for US & EURO and such?
Thanks!
diloret2 is offline
post #2 of 6 Old 07-11-2012, 07:19 PM
Thanks!
I don't know what the differences and don't think you need to worry about it.
You have a USA bike with slipons, it's that basic.
Try the map, try other maps.
If you want some reassurance, do a map compare of it with the PC software against the many maps floating around via this site.
I think the PCMs are likely the same.
Do a part number comparison to find out for sure.
post #3 of 6 Old 07-11-2012, 07:23 PM Thread Starter
diloret2's Avatar
PCM model numbers are the same! Good call!
Maybe I'll give it a shot.
diloret2 is offline
post #4 of 6 Old 07-12-2012, 08:15 AM
Honda usually gives every unique selling region it's own ECU mapping I would be very surprised to find that they use the same mapping in the US Spec ECU versus the UK Spec ECU, but I suppose it could happen...
post #5 of 6 Old 07-12-2012, 03:03 PM Thread Starter
diloret2's Avatar
That's true, and loking at the Dyno Jet Commander manual, there's also an extra harness for the European version of the 919, so it is probably different. Oh well, it was worth a shot.
diloret2 is offline
post #6 of 6 Old 07-12-2012, 09:53 PM
If the ECUs are the same, then the above does not make sense and is highly suspect.
