Mivv X-Cone DB Removal - Wrist Twisters
 2Likes
  • 1 Post By dahaunted
  • 1 Post By mcromo44
post #1 of 11 Old 09-04-2014, 05:24 PM Thread Starter
Just installed my mivv x-cones slip on exhaust on my 02 honda 919. I can't seem to find how to remove my baffles, can anyone help? It looks like there are rivets on it?
onevince is offline
post #2 of 11 Old 09-04-2014, 05:54 PM
LackOfCharismaCanBeFatal
vukmang's Avatar
drill the rivet with the hand held drill, bit should be same diameter as the rivet, taking the db is always easier from the back side while the can is still off the bike. do that with a wooden stick and a rubber hammer.
at least thats how i do my cans...
cheers!
lack of charisma can be fatal
vukmang is offline
post #3 of 11 Old 09-04-2014, 06:35 PM
cheers!
I'm with this, up until the point of the wooden stick. My dB killers basically fall out as the rivet is the only thing holding them in. I don't think Mivv considered a light press-fit and another method of attachment (rivet)
post #4 of 11 Old 09-04-2014, 08:02 PM Thread Starter
So I am only doing this to the one rivet on the part that is sticking out? Right? Not the 4 that are around the body of the can? In one picture I took a pic of the body rivets (two are shown in th picture) and the other two are a pic of the the inside and outside of the rivet on the part that is sticking out of the part of the can that I am referring to as the "body"
onevince is offline
post #5 of 11 Old 09-05-2014, 05:26 AM
Yes, just the one rivet at the back of the can inside the lip. There might be a corresponding hole underneath the can (maybe a rubber plug covering it) that allows you to re-secure the baffle with a small bolt/nut.
Different bike but same concept:
I cut my baffles down to get a bit more growl.
post #6 of 11 Old 09-05-2014, 05:51 AM
It may just be time for a new tire
post #7 of 11 Old 09-05-2014, 05:57 AM Thread Starter
Yes, just the one rivet at the back of the can inside the lip. There might be a corresponding hole underneath the can (maybe a rubber plug covering it) that allows you to re-secure the baffle with a small bolt/nut. Different bike but same concept: I cut my baffles down to get a bit more growl.
So you put them back in after cutting them?
onevince is offline
post #8 of 11 Old 09-05-2014, 07:20 AM
Yup, they are now removable by just taking out that small nut/bolt.
I take them out when I go to the track. Way too loud for the street, I make Harley riders pee their panties and women swoon from the sidewalks into traffic.
Not a safe situation.
post #9 of 11 Old 09-05-2014, 07:21 AM
Old pic - this was the ending to that tire, I believe:
post #10 of 11 Old 05-14-2020, 12:32 PM
dahaunted's Avatar
Thumbs up MIVV Xcone DB Killer comparison
For anyone interested, MIVV also makes an alternate "racing" DB-Killer with an outlet of 35mm (compared to the 25mm original).
The part number is #50.DK.020.0 and I got it from Italy's EM LINEAMOTO https://emlineamoto.com/en/50-dk-020-0.html.
I thought the original DB killer was too quiet, and without it just TOO DAMNED LOUD!
These alternate db killers are on the expensive side ($50 each), but I think the sound was pretty good. Alot more rumbling, but not too obnoxious.
I did a short video comparison if anyone's interested:
https://youtu.be/N_FJDg2CR00
mcromo44 likes this.
Honda Hornet (919) CB 900 F (2003)
Suzuki Bandit GSF 1250n (2008) *SOLD*
Vespa GTS 300 HPE (2019) *SOLD*
Triumph Storm 1700cc (2012) *SOLD*
Triumph Bonneville T-120 (2016) *SOLD*
Zundapp KS50 Super Sport (1979) *SOLD*
dahaunted is offline
post #11 of 11 Old 05-14-2020, 12:49 PM
Interesting.
The sound of the 35s struck me as being akin to my Yosh TRSs which have nominal 42 mm exits that are slightly downturned from the centreline of the cans.
The 35s sound good.
Also interesting how MIVV designs the exit fittings by using a significant downturned inlet.
dahaunted likes this.
