Mid priced Lay-Down Crusier Bike Plate Mount - Wrist Twisters
post #1 of 5 Old 07-10-2009, 07:00 AM Thread Starter
"VonZipper"
JBLee's Avatar
I started my Lay Down plate project with the Kuryakyn curved plate holder #9157 (Curved License Plate Frame for Slimline Low-Profile Tombstone Taillights)
Kryakyn
I like the size and weight of it, it's one beefy beast of a plate holder, and the rounded edges suited the lines of the Roadliner better than the square plate frame I was currently using. Dremel in hand ( I love my Dremel and I'm not ashamed to admit it ) I removed the factory mounting tab and sanded the left over area flush with the mounting plate using my table sander. This part of the plate mount will be at the bottom of the installation. Then I took the factory plate mount and used it as a template to drill the three mounting holes through the Kuryakyn backer plate so that I could use the factory screws to mount the plate holder to the fender. I used those round stick on rubber "Feet" that are a little over 1/4" thick and about an inch in diameter and attached them to the downside of the plate mount for protection and spacing against the fender. I used 6 of them 3 at the top and 3 at the bottom. Then I mounted the piece to the fender using the factory screws and blue locktite. I tightened the screws just tight enough to compress the rubber spacers a bit. I then used the rubber spacers as a stand off between the license plate and the mounting plate due to the fact that the factory screws stuck up above the plane of the mounting plate, again I used six spacers and kept them close to the factory mounting screws to keep the license plate from hitting them. Then I put the license plate into the top piece of the frame , screwed the frame to the base and BAM!!! A solid, sturdy, awesome-looking Lay Down License plate! All for around $70.00. If you are decent with a drill and a Dremel and don't mind a bit of fabricating you can save $50.00 or so over the Baron's and Rivco products and still have a pretty nice looking mount. On a one to ten difficulty scale I'd rate this project a 4...and the result a 9! ( It would have to have a good looking gal modeling the finished project to get a 10). Jim
If you have a Ten Dollar Head, get a $10.00 Helmet.
JBLee is offline
post #2 of 5 Old 07-10-2009, 07:21 AM
Lovin the Vanilla Ice
Igneale's Avatar
Very clean.
Two wheelin for the feelin.
Igneale is offline
post #3 of 5 Old 07-10-2009, 09:12 AM
So, Satan's our mascot?
SuedeGopher's Avatar
Really fits the style of the bike - nice add.
SuedeGopher is offline
post #4 of 5 Old 07-10-2009, 09:40 AM
Unbannable
Super Sneaky Steve's Avatar
That's a fancy bike! Change those rear turn signals so they arn't so pointy and you got a winner.
Super Sneaky Steve is offline
post #5 of 5 Old 07-10-2009, 11:17 AM Thread Starter
"VonZipper"
JBLee's Avatar
I got them as a Birthday gift from Madonna, we share the same Birthday, she wanted to give me something that would remind me of her and all the good times.
JBLee is offline
