Jake Wilson 919 sprocket clearance - Wrist Twisters
post #1 of 17 Old 05-25-2010, 07:01 AM Thread Starter
If any one is interested, JakeWilson.com is clearing out 41 tooth sprockets for the 919 @ $10.50ea.
RMA Rear Steel Sprocket 41 Tooth | Jake Wilson
2015 Ducati Monster 1200S
FlyCatcher is offline
post #2 of 17 Old 05-25-2010, 10:03 AM
Ballaholic
hornet919's Avatar
thats what, 2 teeth down from stock?
hornet919 is offline
post #3 of 17 Old 05-25-2010, 10:49 AM Thread Starter
Right. Stock is 16/43
Never heard of anyone trying a 41 rear, but for 10 bucks...
It will give you more top end at the cost of less acceleration.
post #4 of 17 Old 05-25-2010, 01:29 PM
CG
catonsvilleguy's Avatar
Will reduce RPM at any given speed/gear combination but will probably REDUCE top speed on a stock 919.
The 919 would need more horses to push that much taller gearing to redline in top gear.
catonsvilleguy is offline
post #5 of 17 Old 05-25-2010, 01:33 PM
Ballaholic
hornet919's Avatar
yeah good point. iv been considering going 1 up in the rear as i dont do a whole lot of highway riding, and 1 tooth up shouldnt really raise the rpms too much
post #6 of 17 Old 05-25-2010, 01:49 PM Thread Starter
Theoretically in gearing it will go faster. In real life, I would like to see the result. Unfortunately I don't have a place to do top end runs, let alone multiple runs to compare various gearing. I've never even been remotely close to redline in 6, so I have no idea if the bike struggles or not. I know my 85 Nighthawk S struggled to reach redline in top gear so it maxed out at 135 with about 1000 more RPM left. Damn wind resistance....
post #7 of 17 Old 05-25-2010, 05:53 PM
I've been running a 41 Stealth/Supersprox on the rear for quite some time now. It's almost the same as running a 17 on the front. 17/43 = 2.53 vs. 16/41 = 2.56 I think for what I do, it's perfect.
Professional
post #8 of 17 Old 07-03-2010, 06:56 AM
I just put a 17 on the front and it seems perfect. First gear is now a lot more usable. I checked my speedometer with my GPS before and after. Before I was reading about 5 to 6 mph more than the gps at 60 mph and after i'm reading about 1 mph faster at 60 mph. Slower than 60 its right on. I can tell a little difference on acceleration, but not enough to matter. I've never had the bike over about 115. At that speed its hard to hang on. Haven't checked the mpg yet, but expecting to get better. Before I was getting anywhere from 42 to 53 mpg, depending on riding conditions. I mostly use it for riding to work 37 miles each way or around town. The wife won't ride on it, too much like a crotch rocket. We use the HD low rider on the weekends. Basically, i'm much pleased with the change. Change out took about an hour.
tennesseecanefan is offline
post #9 of 17 Old 07-04-2010, 02:39 PM
Madmotor's Avatar
Going down 1 in the back seems like the way to go so that you don't lose the rubber damper on the stock front sprocket. Do you think the stock length chain (which already seems long) will work with the smaller sprocket in back?
Madmotor
'06 919
Madmotor is offline
post #10 of 17 Old 07-04-2010, 03:35 PM
It will. You''ll want to watch your adjustability. I went to a 41 tooth in the rear
and easily dropped 2 links to a 112, still leaving me forward and back movement of the axle.
(my) experience is: better streetability. it seems to launch slower but feels as if it builds faster.
Definite drop in the rpms. keeps me out of the buzz-zone easier. no more 125 though. the thing really has to work up that high.
the taller gear also feels as if my mpg has gotten worse. but I have yet to run a full tank and the numbers.
Lemonhead is offline
post #11 of 17 Old 07-05-2010, 01:14 PM
Because, I've heard that the chain is already too long, I chose to go to the front sprocket. I haven't felt any issues that the rubber damper would eliminate. I don't do any hard acceleration from a stand still. I didn't want to have to remove any links. As far as the mpg. I think that will be hard to determine, unless you have a route with the exact mileage. With the speedometer being electronic, I assume the odometer works off it. The rpm's vs speed didn't seem to change, and I wouldn't think it would if the speed sensor in inside the motor/transmission. That being said, I would assume the mpg numbers will look a little worse, while in reality the mpg should be better due to the lower rpm at an actual adjusted speed, say 60 mph. Any way it feels better on the highway and I now know the speedometer is almost dead on, so maybe I'll avoid a ticket.
post #12 of 17 Old 07-24-2010, 07:01 AM
CG has it right.
Drop teeth off the rear and lower top speed will be the result.
Top speed is where the hp matches the overall resistance, almost entirely wind.
Adding teeth moves the engine down on the hp curve so that the hp will match resistance at a lower speed.
For max actual attainable top end, the ideal gearing is either stock or one more tooth on the rear.
post #13 of 17 Old 08-13-2010, 01:19 PM
I've hit 155 in sixth gear at redline on a stock 919. It was a long time ago, but I'm pretty sure my power commander wasn't hooked up, now were my Sato's installed. Pretty sure you could get more top speed if these were in and you went down one tooth in the back. Personally, going over 120/130 is reckless...
det5lonewolf is offline
post #14 of 17 Old 08-13-2010, 01:23 PM
Because of the inherently optimistic speedo error your 155mph indicated was more realistically 131mph in the real world...
post #15 of 17 Old 08-13-2010, 06:13 PM
155 is many MPH past what is possible for 919 hp without a good full sport fairing.
And the speedo is high on all of them, worse on some.
The tachs also over read.
post #16 of 17 Old 08-13-2010, 07:31 PM
blur
drewvir's Avatar
just pee in his cheerios boys
drewvir is offline
post #17 of 17 Old 08-13-2010, 07:44 PM
CG has it right.
This is true. With a 41 my bike is faster on top-end in 5th, than it is in 6th.
Professional
