I'm installing power outlet on bike... - Wrist Twisters
post #1 of 11 Old 05-08-2013, 05:05 PM Thread Starter
Man and Machine
Callinmeupward's Avatar
Hey, I'm installing a power outlet, wondering were the best place to put a ground is.
I don't want it on the batteries ground...
Callinmeupward is offline
post #2 of 11 Old 05-08-2013, 05:08 PM Thread Starter
Man and Machine
Right here ? The hinge bolt?
post #3 of 11 Old 05-08-2013, 05:10 PM Thread Starter
Man and Machine
Or on this bolt for this box(whatever it is, bank angle sensor?)
post #4 of 11 Old 05-08-2013, 05:55 PM
rpcraft's Avatar
Those are probably ok but I just went ahead and grounded it directly to the battery and ran the power from it as well. I don't leave anything plugged into the bike unless I ride it so I figured that was the easiest way to not cause some weird short or something.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #5 of 11 Old 05-08-2013, 06:02 PM
I get my fused 12v from the hot post on the starter relay, for my ground I drilled and tapped a bolt hole into the side of the main frame.
My battery charge harness & power block run off these connections.
This makes battery changes/maintainence easier & drilling and tapping the steal frame is pretty straight forward.
post #6 of 11 Old 05-08-2013, 06:08 PM Thread Starter
Man and Machine
And if the hot wire is going from the starter relay than that means it could only have power if starter has power.....
post #7 of 11 Old 05-08-2013, 06:55 PM
rpcraft's Avatar
Well, I need to correct myself. When I park the bike and walk away for the day I do not leave stuff plugged in but when I am camping at times I'll leave my phone or GPS plugged in to charge for a little while and that is why I hooked mine up hot. That way it would not be as much of a draw as having to have the key on.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #8 of 11 Old 05-08-2013, 07:04 PM
Just took another look. My battery charger is on the 12v constant terminal of the starter relay.
My power supply/distribution block is spliced into a heavy wire that feeds the ignition circuit.
post #9 of 11 Old 05-08-2013, 08:31 PM
rpcraft's Avatar
Just curious but where are you planning on putting your outlet? I kinda attached mine to the throttle cables with some zip-ties. Pretty Janky but it works and unless you really look it's not noticeable?
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #10 of 11 Old 05-08-2013, 08:53 PM Thread Starter
Man and Machine
Well the power outlet for mine will be tucked away. I'm actually looking to just plug in a cell phone car charger and then run its cord up towards the handle bars, over the top of gas tank and into a tankbag...
When not in use it will have a place that I can tuck it away till needed of course.
post #11 of 11 Old 05-08-2013, 08:54 PM Thread Starter
Man and Machine
And yours I think is cool right there...
