Headlights - Wrist Twisters
post #1 of 6 Old 04-24-2012, 07:51 PM Thread Starter
Headlights
What dual headlight options have been explored by other users?
Looking at these "Dominators" on ebay and not wanting to commit to anything that will be a PITA to mount.
And as far as dual lights of this style these seem to be the only ones around.
NoGorbac is offline
post #2 of 6 Old 04-24-2012, 08:23 PM
they should go on rather easy as they are the same width as the stock headlight... you will run into a problem with what to do with all the wiring that was stored in the headlight bucket however.
post #3 of 6 Old 04-24-2012, 08:29 PM
919Rev's Avatar
Exactly...
I installed the Dominators on my 919 when I had it. Fitment was easy. Hiding the wiring was not.
When I die I want to die peacefully in my sleep like my grandfather did....not screaming in horror like the passengers in the backseat of his car.
919Rev is offline
post #4 of 6 Old 04-25-2012, 12:21 AM
What?
2002-919's Avatar
Plus i think I read that the extra load on the wires at the headlight switch can cause problem. Maybe that was just an isolated incident...
2002-919 is offline
post #5 of 6 Old 04-25-2012, 02:53 AM
Mounting isn't an issue, like ND4 says they're direct bolt-on. Even uses stock bolts. The wiring is the problem, if it's not already pre-wired, you'll need to get an H4 Y splitter. You'll also need to get creative with the extra wiring that's inside the stock bucket. I have mine tucked into a small leather pouch underneath the headlights. Some have used cylinder shaped cable covers that looked decent. MDToneys setup is the only one I've seen without anything underneath the headlights to hold the extra wiring. I'm assuming he's got it back into the engine area some or somehow got it behind and up more towards the headlights.
As for stock cables having problems with 2 bulbs, it is an issue. You also don't need 2 bulbs to get the stock cables to crap out, just to show how crap of a design they are out of the factory. The best solutions is a dual H4 harness from Eastern Beaver Company (in Japan) which draws power directly from the battery as opposed to using the stock cable. I don't have that and I had the start switch resoldered already and clean the hi/low switch every other oil change with WD40.
*edit: check out FlyNCycle, they usually have the best prices on dominators. You can get them in chrome or black and they come with the Y splitter already in place.
post #6 of 6 Old 04-25-2012, 09:39 AM
As already mentioned, swapping the stock headlight for the Dominators is extremely quick and easy - but you have to get creative with the wire routing to make it all fit. Even then, it's still a tight squeeze. I pulled a few inches of the wiring back towards the battery and pushed it under the backbone, where the emissions hoses used to be. I still had to wrap the excess back and forth under the top triple clamp to make it fit.
Why in the hell did Honda include so much excess wiring for the headlight????
I've bought a couple sets of Dominators from FlyNCycle - no issues. Fast shipping and the connector is plug & play.
