Economical Aftermarket cans?? - Wrist Twisters
post #1 of 4 Old 10-22-2019, 07:06 PM Thread Starter
thegutterpoet's Avatar
I may well have to replace the damn cans on my 05 919...the baffles might now be enough to pass the RWC here! And if so, I wonder if there are any cheap-ish options - just to get through the RWC?
Also, would stock cans fit the Y pipe used for the danmotos?
I recall advice of anything 51mm fitting?
Two of these would do the trick?
https://www.ebay.com.au/itm/Stainles...B/323502094645
https://www.ebay.com.au/itm/51MM-Mod...B/293289482955
https://www.ebay.com.au/itm/38-51mm-...r/173669501921
https://www.ebay.com.au/itm/Universa...m/312765950039
Then just a case of likely paying the grease merchant to mount?
Any other similar options that will likely fit fine?
thegutterpoet is offline
post #2 of 4 Old 10-22-2019, 11:49 PM
The Danmotos use the OEM Y pipe. The Danmotos have their own link pipes. So maybe try and find a pair of stock cans. They will pass a road worthy, easy to fit and are usually quite cheap. I see them on eBay, Gumtree etc. Try local wreckers.
I got an almost mint pair, very low kms...
post #3 of 4 Old 10-22-2019, 11:50 PM
Ya didn't stay away long. Now where did I leave that pitchfork.
post #4 of 4 Old 02-12-2020, 03:35 PM
draco880's Avatar
eBay has been my friend in this regard, but my bike is a Franken-bike to begin with.
draco880 is offline
