Delvic 900rr header convertion - Wrist Twisters
post #1 of 31 Old 03-25-2015, 10:48 AM Thread Starter
Mxhonda215's Avatar
So I know what you all are thinking. "This guy is beating a dead horse". I realize that there are TONS of thread with ridiculous amounts of information and questions about the 900rr exhaust swap. I'm going to create another. Hopefully it helps anyone out there who's looking to do this mod. Even more importantly, seeing as this is an ongoing project, I hope that some of you have some valuable insight for me. Plus everyone loves to show of pictures of their bikes
After dropping the stock headers
Mxhonda215 is offline
post #2 of 31 Old 03-25-2015, 10:53 AM Thread Starter
Mxhonda215's Avatar
With the mufflers pulled off. I decided to change the oild while the headers were out of the way.
post #3 of 31 Old 03-25-2015, 10:55 AM Thread Starter
Mxhonda215's Avatar
All jacked up with the rear shock disconnected to remove the Y-pipe.
post #4 of 31 Old 03-25-2015, 10:57 AM Thread Starter
Mxhonda215's Avatar
A comparison between the stock headers and the Delvic 900rr headers
post #5 of 31 Old 03-25-2015, 12:12 PM Thread Starter
Mxhonda215's Avatar
Forgot to take pictures of the headers after they were installed (mostly). I'll post more soon
post #6 of 31 Old 03-25-2015, 12:15 PM
Dragon Slayer
oak1971's Avatar
I had to stretch mine to get it to fit on the exhaust manifold. This and the power commander really woke my bike up.
2002 SuperHornet 919 - In a continuously variable state of modification.
1974 CB360- awaiting restoration money
Past Bikes:
1981 XL 80
1984? Nighthawk 650
1992? Zephyr 1100
1991? ZX-11
1999 ZRX 1100
1984 V45 Magna
2001 GSXR 750
1985 Shadow 1100
oak1971 is offline
post #7 of 31 Old 03-25-2015, 12:20 PM Thread Starter
Mxhonda215's Avatar
I saw a few pictures the showed the 4 individual header pipes being different distances apart from each other. Luckily mine seemed pretty close to stock. Still had to wrestle with it for an hour or so to get it mounted up
post #8 of 31 Old 03-26-2015, 05:54 PM Thread Starter
Mxhonda215's Avatar
The freshly arrived Two Brothers M-2 muffler for 96-99 GSXR 600/750
post #9 of 31 Old 03-27-2015, 07:06 AM
that's snazzy looking
post #10 of 31 Old 03-27-2015, 07:49 AM
That should work out great!
One word of caution ..... watch out for your rear brake line.
Pulling the lower shock bolt & letting the swingarm drop down with the weight of the rear wheel on it .... while jacking the bike like that can put all kinds of strain on the fwd fitting of the rear brake line.
I destroyed a braided rear line on mine once rushing to pull the rear shock and not paying attention.
post #11 of 31 Old 03-27-2015, 08:00 AM Thread Starter
Mxhonda215's Avatar
Hmm, I didn't think of that at the time. I only dropped the swing arm barely enough to remove the y-pipe, so I don't think there was a ton of stress on it, but I will definitely double check it
post #12 of 31 Old 03-27-2015, 08:30 AM Thread Starter
Mxhonda215's Avatar
Header installed. Looks like I still need to work with it a bit to get it to sit properly
post #13 of 31 Old 03-27-2015, 08:38 AM
gibbonater's Avatar
Attachment 101042
Attachment 101050
Can't wait to see that mounted. Looks good!
Bikes:
2004 V-Rod (sold)
2004 CBR600F4i (sold)
2003 RC51
2010 Triump Scrambler (sold)
2003 CB900F
2004 CBR 600rr
Non Bikes:
2007 JK Sahara
2005 CTS V (sold)
2006 Audi S4
gibbonater is offline
post #14 of 31 Old 03-27-2015, 01:00 PM
Attachment 101090
Just rotate the pipe down a bit more, that should bring it away from the rearsets a bit. It helps to mount the can temporarily as you'll see the final position.
You may have to fab a bracket up to connect the inside mid-pipe to the frame and help pull it away from the bike a bit.
I had to. I just had the guy that ceramic coated my headers also weld a small mounting tab on the mid-pipe for that very reason.
post #15 of 31 Old 03-28-2015, 10:53 AM Thread Starter
Mxhonda215's Avatar
I'll mess with it today. Hopefully I can get enough wiggle room when I loosen up the header flanges
post #16 of 31 Old 03-29-2015, 08:42 AM
BockHawk's Avatar
For those of you who have used the GSXR 96-99 pipe, any chance you could tell me the measurement between the bolts on the flange? It seems like it's way the hell easier to find an OEM pipe from one of those for a reasonable price than a pipe from the 900RR. I just want to make sure it fits the 900RR header I'm using before making a purchase.
2002 919 40,000 miles
BockHawk is offline
post #17 of 31 Old 03-29-2015, 08:53 AM Thread Starter
Mxhonda215's Avatar
Unless you know something that I don't, the only part of the GSXR 750 exhaust that will fit is the muffler and that's only when you're using the 900rr headers
post #18 of 31 Old 03-29-2015, 01:12 PM
...the only part of the GSXR 750 exhaust that will fit is the muffler and that's only when you're using the 900rr headers
I think that's exactly what his last sentence says, if you read his use of pipe as meaning muffler:
"It seems like it's way the hell easier to find an OEM pipe from one of those for a reasonable price than a pipe from the 900RR. I just want to make sure it fits the 900RR header I'm using before making a purchase."
K1w1Boy is offline
post #19 of 31 Old 03-29-2015, 01:47 PM Thread Starter
Mxhonda215's Avatar
Oops, my mistake
post #20 of 31 Old 03-29-2015, 01:48 PM
BockHawk's Avatar
KiwiBoy is dead on. I intend to confirm that the silencer/muffler/pipe will fit my 900RR header. I already have a Yosh pipe for the 900RR, but I want something quieter. In lieu of a 900RR pipe, I'd purchase one for a GSXR since they're more readily available.
BockHawk is offline
post #21 of 31 Old 03-29-2015, 02:46 PM
I ended up with a partially severed RR header, so had to find something to mate up with it under the engine via a sleeve arrangement, and eventually got a stock GSXR exhaust to do the job. It tucks up under the footpeg quite well, and even the stock heatshield ended up in the right place.
K1w1Boy is offline
post #22 of 31 Old 03-29-2015, 04:10 PM
The Instigator
Ditch's Avatar
^ Fook me that's cool! Any more install pics?
Ditch is offline
post #23 of 31 Old 03-29-2015, 04:24 PM
Nice! Wonder what the vfr12k muffler would look like...
post #24 of 31 Old 03-29-2015, 04:41 PM
Yes I've got a few more pics - what did you want to see? The build process, or the finished product? When I was doing the orig low mount install, I was working with an R1 pipe - I never got to grips with its blunt-ended look, so that's when I went looking for something else and found the GSXR stocker. So the header install pics all have the R1 muffler - adding the GSXR part was just a matter of getting an interested muffler shop guy to weld me up the right OD/ID adaptor at the right angle and it was all done.
Orig build and later mods here:https://www.wristtwisters.com/forums/...ons-47377.html
K1w1Boy is offline
post #25 of 31 Old 03-30-2015, 10:58 AM
BockHawk's Avatar
So...any takers on measuring the distance on those bolt holes for the GSXR muffler flange?
BockHawk is offline
post #26 of 31 Old 03-30-2015, 02:11 PM Thread Starter
Mxhonda215's Avatar
About 3" from the center of each hole
post #27 of 31 Old 03-30-2015, 02:38 PM
BockHawk's Avatar
Beauty! Thanks Mxhonda!
BockHawk is offline
post #28 of 31 Old 03-30-2015, 08:53 PM
Hard to get a pic that shows how the final version sits relative to the pegs, wheel and swing arm - this one might give a better idea:
K1w1Boy is offline
post #29 of 31 Old 03-31-2015, 05:15 PM Thread Starter
Mxhonda215's Avatar
Here it is. Two Brothers M2 black series mounted. I still need to figure out if I want to cut the muffler down or keep it stock length
post #30 of 31 Old 03-31-2015, 05:28 PM
Attachment 101610
Looks pretty nice! How does it sound?
post #31 of 31 Old 03-31-2015, 05:58 PM Thread Starter
Mxhonda215's Avatar
Pretty good aside from the sputtering caused by the pair valve (yeah, I still haven't removed them). I wouldn't mind in being a little louder, though
