customized aztec8 dual 4" headlight lights - Wrist Twisters
post #1 of 17 Old 06-13-2011, 02:07 PM Thread Starter
MSF blacksheep
Ferris Bueller's Avatar
I recently shoved 4300k hid projectors with white halos in my aztec8 headlight housings. The lights maintain the high/low function and i ran a toggle switch to kill the headlights so i can ride around win just the halos lit.
Ferris Bueller is offline
post #2 of 17 Old 06-13-2011, 02:13 PM
Blue919Guy's Avatar
Very cool! When I put HIDS in my Dominators I tried fitting projectors inside with no luck, pretty innovative install and I may adapt something like this with some CNC trim rings around the projector. Cool!
Blue919Guy is offline
post #3 of 17 Old 06-13-2011, 02:20 PM Thread Starter
MSF blacksheep
Blue guy - here is a pic of what it looked like before i painted them. They obviously stick out of the housing but i used 1" wide foam weather stripping inside the aztec8 front ring to seal the projectors in. I had to trim the projector housing a little to allow the frog ring to lock back onto the bucket.
post #4 of 17 Old 06-13-2011, 02:24 PM
You need a smiley face on that sucker!!!
post #5 of 17 Old 06-13-2011, 02:42 PM
dude, way cool!!! how much?
more info on how to install the projectors, wiring, etc. very cool project, need more info.
post #6 of 17 Old 06-13-2011, 03:00 PM
Nicely done! Any way you can take a picture of the light spread (shoot down the road from the bike)? And like PVster said, details on price and where to purchase?
Also, a piece of hot-tub wire tubing covers those cables up nicely. I believe it's MarylandMike that has pics from his install way back.
post #7 of 17 Old 06-13-2011, 04:11 PM Thread Starter
MSF blacksheep
I ordered them from easy-motorcycle. Shipping was kinda slow as they were shipped out of china.
H4 9003 HID bi-xenon projector kit angel eye Hi/Lo H1/H7 9006 [G3-projector] - $159.99 : easy-motorcycle.com supplies
As for wiring, there is a crap ton of wires behind my fly screen now. It obviously has 2 ballasts, 2 angel eye relays, a high low controler and i added a toggle. I ran a power and ground from the battery wit an inline fuse to the toggle then to the controller. Ran the angel eyes on the running light wires in the front turn signal circuit. And then just plugged everthing else in their respective plugs. I will get pics of low and high beam down a road and against a building tonigt.
post #8 of 17 Old 06-13-2011, 08:46 PM Thread Starter
MSF blacksheep
My g/f says she could ride in front of me and not have a head light.
post #9 of 17 Old 08-02-2011, 12:22 PM Thread Starter
MSF blacksheep
Update
Took the flyscreen and projectors out the other day for a few reasons.
1. One of the ballasts fried
2. One of the angel eyes got hit with a rock and broke
3. The fly screen didn't do much for wind and moved the headlights forward too much
4. I probably save 5 lbs taking out the 2 ballasts, 2 projector lenses and housings, the 5 miles of wire needed, the fly screen with brackets, and the headlight bracket extentions
5. In a spirited night ride i find it harder to see far through a turn with brighter headlights due to your eyes having to deal with a larger difference in light.
post #10 of 17 Old 08-02-2011, 12:36 PM
I think it looks a lot better like that anyway. Nice looking bike.
Ottawa919 is offline
post #11 of 17 Old 08-02-2011, 12:41 PM Thread Starter
MSF blacksheep
Me too and thank you
post #12 of 17 Old 10-10-2012, 06:56 AM Thread Starter
MSF blacksheep
So I'm in the mood for a new headlight because the aztec8 lights aren't that bright and the glass is starting to fog(not from moisture). So I have narrowed my options to the 599, mt03, or 1125cr headlight. I don't want to run hids because I haven't had good luck with them and I ride so much that having to order replacement parts would keep me off the bike and this is no bueno. So far the pros and cons are:
599 + better light than stock, easy install, cheapest option
- looks stock
Mt03 + looks great, not too expensive
- requires different gauges to look right, mounting mod required, very common
1125cr + looks mean, not very popular
- costs a lot, mounting looks difficult, needs different gauge to look right
What do you guys think?
post #13 of 17 Old 10-10-2012, 07:37 AM
TEXAN
MF1VE's Avatar
If it were me, I'd go 599. The 599 headlight is unbelievably bright, or at least that's how it seemed to me the last time I rode a 599.
MF1VE is offline
post #14 of 17 Old 10-10-2012, 08:13 AM
Don't forget the LED option.
My vote is LED unit or 599 unit.
post #15 of 17 Old 10-10-2012, 09:00 AM
+1 for the 599.
post #16 of 17 Old 10-10-2012, 03:35 PM Thread Starter
MSF blacksheep
Ordered the 599 from the local dealer. They hook me up so got a decent price. So as far as wiring goes, I'm just planning on hooking the low beam bulb to existing the low beam circuit and hooking both bulbs up on the existing high beam circuit. Any for seen problems with that?
post #17 of 17 Old 10-10-2012, 08:10 PM
Check out this thread for all the info you need regarding the 599 set up: https://www.wristtwisters.com/forums/...ight-8592.html
Rob posted a beautiful wiring diagram specifically for people such as yourself who wanted to wire it in rather than use the easern beaver harness.
