CRG levers - Wrist Twisters
post #1 of 25 Old 08-20-2013, 07:18 PM Thread Starter
CRG levers
Does anybody know if the CRG lever blades (just the part your fingers touch) are interchangeable right to left? The SP2 master cylinder I got has one of the original style CRG levers on it but it has the standard length lever, if they're interchangeable I can just order a shorty clutch lever and swap them right to left since I want long clutch and short brake
Thanks
post #2 of 25 Old 08-20-2013, 07:29 PM
Ginger-prick
EatDirtFartDust's Avatar
They are different.
Clutch lever is made to pull a cable, brake lever is made to push a button/cylinder.
2007 Honda 919.
EatDirtFartDust is offline
post #3 of 25 Old 08-20-2013, 08:28 PM Thread Starter
not the whole lever, just the blade part. the part the red adjuster is mounted to
It looks like the actual lever blades are universal and interchangeable but I'm looking for conformation
post #4 of 25 Old 08-20-2013, 08:30 PM
Edfd is right. Even that part is different.
...on my Droid.
post #5 of 25 Old 08-20-2013, 08:35 PM Thread Starter
How are they different? it's perfectly symetrical, exact same markings on the to as the bottom like it was meant to go on either right or left, where's LDH when you need him?
post #6 of 25 Old 08-20-2013, 08:37 PM
Originally Posted by EatDirtFartDust View Post
They are different.
See above. The clutch lever has a cable pull built into it, the brake lever does not, and actually sticks out farther where it pushes on the m/c piston, if I recall correctly.
...on my Droid.
post #7 of 25 Old 08-20-2013, 08:41 PM Thread Starter
all of the cable actuation and M/C push rod actuation is accomplished by the billett piece that bolts to the perch, the lever blade then bolts to the bike specific actuator block
post #8 of 25 Old 08-20-2013, 08:48 PM Thread Starter
This is the piece in question
not the bike specific adaptor
post #9 of 25 Old 08-20-2013, 08:58 PM
Yoshis=me smiling
NH919's Avatar
I don't know about the levers but sweet emblem next to it. Go fins!
02' 919
85' cb450 (wife's)
78' cb550 project
84' z50r son's
09 trx90 daughter's
NH919 is offline
post #10 of 25 Old 08-20-2013, 09:27 PM Thread Starter
Yeah, lets hope Dustin Keller is the last major injury for the season
post #11 of 25 Old 08-20-2013, 09:31 PM
Yoshis=me smiling
NH919's Avatar
Yeah. I wasn't to keen on what the guy said who hit him. Went low because he was afraid of getting fined. An injury like that can end a career. Sorry to derail your thread.
02' 919
85' cb450 (wife's)
78' cb550 project
84' z50r son's
09 trx90 daughter's
NH919 is offline
post #12 of 25 Old 08-21-2013, 05:50 AM
Don't know if this helps any, but this is off of my 599, probably a similar setup:
There are differences in where they attach to the perch.
...on my Droid.
post #13 of 25 Old 08-21-2013, 06:29 AM Thread Starter
I understand how they mount to the perch,I understand the differences between a hydraulic actuated master cylinder and a cable actuated clutch, the part that mounts to the perch isn't even part of this question, I'm questioning the part that mounts to the part that mounts to the perch, the lever, the blade, the part you wrap your fingers around.
This part
It is removeable, it is symectrical, lazer etched exactly the same on the top as it it is on the bottom implying it was meant to be used on either side once attached to the motorcycle specific adaptor that is bolted to the master cylinder or the clutch perch.
post #14 of 25 Old 08-21-2013, 07:08 AM
do you have crg levers now on both? or just one?
post #15 of 25 Old 08-21-2013, 08:31 AM Thread Starter
Just one, the RC51 master cylinder i HAVE has one of the standard "long" lever blades on it and I want the brake to be short and the clutch to be long so I want to order a short clutch lever and swap the short for the long and the long for the short.
post #16 of 25 Old 08-21-2013, 09:38 AM
Haha, don't get frustrated Dan. I understand what you're asking. I have the same levers but don't have access to my bike right now. If you don't get confirmation before the end of the day I'll try and take the blades off and see if they're interchangable side to side.
post #17 of 25 Old 08-21-2013, 09:44 AM
This part
Every set of levers I've ever used, whether they were Pazzo's, stock, or crappy ebay knockoffs, were always different for each side. Lazer cuts, etchings, etc. I can't answer specifically for CRG as I've yet to own any of those. Have you tried contacting CRG directly?
Besides, if you have a RC51 m/c setup, but stock perch for clutch side, you need two different model levers anyway. What are the chances they look the same even between those two models? I had the same issue with the Pazzo's on the 919 - GSXR on the brake, 919 on the clutch, and although they looked the same on the top, they did not on the bottom (and they weren't interchangeable).
post #18 of 25 Old 08-21-2013, 10:36 AM Thread Starter
Yeah, I fired off an e-mail to CRG last night, waiting for a response. I'm still going with the replaceable blade being a universal and interchangeable or else why go to all the trouble to laser etch both the top and bottom with identical markings? makes too much sense to have a universal (short or long) blade with bike specific adaptors, but time will tell.
On a side note, I didn't realize CRG was in Watsonville, they're only about 25 miles from my front door, go locals
post #19 of 25 Old 08-21-2013, 11:06 AM Thread Starter
The official answer from CRG is , yes they're interchangeable, the only one's that aren't the same are their radial line.
post #20 of 25 Old 08-21-2013, 11:08 AM
Sweet! Bonus for CRG then - if you ever brake your clutch lever, you could always remove your front brake one to get home!
post #21 of 25 Old 08-21-2013, 11:12 AM Thread Starter
Please return the universe to full normal operating mode, nothing left to see here ma'am, move along
post #22 of 25 Old 08-21-2013, 11:15 AM
They beat me to it. I just went out to my bike and took some close-up photos to confirm that they're the same on both sides.
post #23 of 25 Old 08-21-2013, 11:23 AM Thread Starter
It didn't make any sense for them to be different, just from a manufacturing and inventory standpoint.
So I ordered a shorty clutch lever from Dennis Kirk and when it gets here I'll swap the short for the long and the long for the short and all will be well.
post #24 of 25 Old 08-21-2013, 11:28 AM
Also, once the anodized finish fades on one side, just flip them around (and over) and cook the other side for the same time!
post #25 of 25 Old 08-21-2013, 11:35 AM
I have a couple parts on my dirt bike that have crap anodizing (others parts still look great). The anodizing on the CRGs has held up great - I've had mine for about 5 years and they still look the same as when I bought them. Stay away from the Chinese knock-offs!
