Cbr900 exhaust can, options? - Wrist Twisters
post #1 of 4 Old 04-06-2012, 02:42 PM Thread Starter
Hey kinda of a WT noob. First time poster, short time reader. So I don't have the headers yet but before I try to find one wanted to know what my options are. If anyone could "pipe" in it be much appreciated. I'm totally cool with a redirect. Thanks.
sylentd is offline
post #2 of 4 Old 04-06-2012, 03:17 PM
Lot's of options
1) Buy a 900RR exhaust can that bolts right up.
2) Cut the flange off and find a slip-on that is around 63mm inlet (header is about 61 mm OD).
3) Buy another can you like and get your local muffler shop help you adapt it.
If you do a search on "900RR" you should find lots of good examples.
Good luck!
post #3 of 4 Old 04-06-2012, 03:43 PM Thread Starter
Hey marylandmike. Thanks for the options. Definitely has me thinking outside the box now for a solution.
sylentd is offline
post #4 of 4 Old 04-06-2012, 04:08 PM
MM is right, start with a header and work your way back. I run a GSXR Yoshi Tri-oval bolt on can, just used the gixxer flange and mated it to the 900rr mid-pipe.
