Best fork upgrade... - Wrist Twisters
post #1 of 8 Old 08-07-2015, 12:37 AM Thread Starter
1991 honda vfr 750 2002 h
adambaron919's Avatar
Hey guys! What's the best fork upgrade for the 02' 919, something with little to no mods, Or a complete front end! Just got a new 919 for 1900!
adambaron919 is offline
post #2 of 8 Old 08-07-2015, 01:21 AM
Fork Spring Kits
Plus fresh, hi-qual fork oil
K1w1Boy is offline
post #3 of 8 Old 08-07-2015, 06:52 AM
Originally Posted by K1w1Boy View Post
Fork Spring Kits
K1' has it pegged.
Just be careful not to spring it to stiffly, as most web based selection tools or charts will guide you to do.
Be sure to properly determine the spacer length to use, re the resultant installed preload, and correct L is not as simple as OEM spring + stock spacer = new spring + new spacer.
Increased oil level is usually a good strategy as well.
post #4 of 8 Old 08-07-2015, 12:12 PM
Hands down RC51. Only two bits to mod/fab. Headlight stay and make brackets for instruments.
Couple that with an Ohlins shock and you have an awesome set up.
post #5 of 8 Old 08-07-2015, 02:13 PM
I'm pretty sure you have to modify or buy after market triples as well, right?
post #6 of 8 Old 08-08-2015, 03:10 AM
CB1000R OEM triples or, yeah, some aftermarket.
post #7 of 8 Old 08-08-2015, 10:47 AM
Pretty happy with my F4i Forks n racetec springs. Outside of doing a full tripple swap that is about the best you can do.
post #8 of 8 Old 08-15-2015, 12:36 AM
woodyeee's Avatar
My rc51 forks in standard trim do not feel as good as my old standard forks with upgraded springs and oil. I haven't had a play with any settings on the rc51 forks yet and know a service, spring/shim change and setup would benefit greatly. I'm just saying the easiest route is springs and oil change for your standard forks is best value.
woodyeee is offline
