Requires locksmith for the lock of my bike that is fully covered by rust - Wrist Twisters
 3Likes
  • 1 Post By filipinoaviator
  • 1 Post By marylandmike
post #1 of 13 Old 03-05-2013, 11:44 PM Thread Starter
I have my yamaha YZF 2001 and i left it locked for more than one year but 2 days ago when i was trying to start it , it was very difficult to insert key into the lock then i was that the lock is fully covered with rust now i want to replace it i have consulted with one locksmith they told me to pay $650.00 but i found it very expensive so if anyone knws a cheap locksmith kindly inform me for it.
lmoaceySus is offline
post #2 of 13 Old 03-06-2013, 04:17 AM
abadacus's Avatar
Beware possible scammer/thief
needs a locksmith for the jammed lock of my bike - Aussie Street Bikes
Originally Posted by lmoaceySus View Post
I have my bike yamaha YZF 2001 and 3 days ago i left it locked , open in a rain and yesterday when i was trying to start it while inserting the key into the lock i found that the lock is jammed and key won't turn into inside the lock. so i requires a locksmith to fix this issue if anyone have some idea of good locksmith company plzz suggest me for it.
Just as aerodynamic airplanes are simple and streamlined, a motorcycle--which manages to balance an engine and a seat between two wheels--has a mechanical integrity, with intertwining pipes, chains and springs, that is fascinating to behold - Peter Plagens
abadacus is offline
post #3 of 13 Old 03-06-2013, 05:01 AM
Seafoam deep creep. It will help break up the rust. Cover the tank and everything else.
Shit, i'd try every chemical i could buy before I paid a locksmith. Or cut it off and buy a new lock set.
If you had to, could you SAFELY apply a torch to it? In worst case scenarios, a torch will help free it up.
post #4 of 13 Old 03-06-2013, 09:31 AM
The problem here is the wafers in the lock are spring loaded to follow the cuts in the key, but the contamination in the lock is preventing them from returning to follow the profile. They are pushed out and stay there.
The best thing to do is soak the mechanism with a very lightweight oil (good 'lol WD40, or a lightweight gun oil) for a couple hours, then insert the key, try to turn it in both directions without forcing things too much, and remove it to help free up the wafers. The lowest wafers are going to be the most difficult to free up because they are only engaged when the key is fully inserted, and that's where the water (and whatever else the water brings with it) will accumulate. After 10 or so attempts add more oil and continue. It will take about a half hour or more to get things moving, but it usually works.
Good luck.
post #5 of 13 Old 03-06-2013, 12:45 PM
Rich Jura's Avatar
I have had great results with a 50/50 mix of ATF and acetone, of course keep it away from paint. I just mix it in a small 1 ounce bottle with a needle applicator.
Rich
Rich Jura is offline
post #6 of 13 Old 03-07-2013, 07:43 AM
Evolving.....Slowly
EvoLife's Avatar
Rich
This.
I had a similar problem with EvoWife's Wrangler. I dipped the key in atf and worked it in and out for a while to get it all lubed up. Works like new now.
The 50/50 mix is the best for breaking loose frozen fasteners.
"If what you are doing isn't working, don't try harder, try different."
EvoLife is offline
post #7 of 13 Old 03-07-2013, 09:24 AM
Will fly for food.
filipinoaviator's Avatar
This has been my penetrant of choice for several years. It's amazing how nanotechnology has allowed us to harness the power of a mouse's milk But on a more serious note, this stuff is awesome!
MOUSE MILK OIL from Aircraft Spruce
HeliMech likes this.
1965 PA-30 Twin Comanche
1985 Kawasaki GPZ900r
1999 Honda CBR1100XX
2005 Honda ST1300
2006 KLX250s
filipinoaviator is offline
post #8 of 13 Old 03-07-2013, 09:30 AM
Pierre-Marc
^+1 good stuff
mx463 is offline
post #9 of 13 Old 12-10-2019, 03:52 AM
You're bringing up a 6 year old thread. Most of those people aren't here anymore. This happens every so often, someone digs thru the old threads without looking at the date. It's from 2013.
post #10 of 13 Old 12-10-2019, 04:23 AM
Karl I think that dude is a scam. Those weird posts pop up from time to time. Always zero post counts. Someone deletes them before too long.
post #11 of 13 Old 12-10-2019, 05:36 AM
Yep, They are just trying to put link on this site to point to a site that they are trying to boost in Google ranking. He's dead now.
Islandboy likes this.
post #12 of 13 Old 12-11-2019, 07:55 AM
OMG, you killed him?!!! Sinister.
post #13 of 13 Old 12-11-2019, 07:59 AM
He's in that great tumbler in the sky, but still available for 24 hour service.
mcromo44 likes this.
