Removing a Tank Pad - Wrist Twisters
post #1 of 6 Old 02-29-2012, 05:57 AM Thread Starter
ace2222's Avatar
Removing a Tank Pad
I got a new tank pad but I need to get the old one off without taking the paint with it. Any suggestions?
ace2222 is offline
post #2 of 6 Old 02-29-2012, 06:04 AM
Heat it up with a hairdryer & slowly peel it back. Use isopropyl alcohol and a soft rag to remove any left over glue residue.
post #3 of 6 Old 02-29-2012, 08:15 AM
+1 on the hairdryer. I had put a clear one on my tank and got too many bubbles under it. Hair dryer worked great to get the old one off.
When I put the new one on, I wiped some mineral spirits on the tank where I was gonna put it, it gave me a couple of minutes of working time to move it around to get positioned right and to work any bubbles out. The mineral spirits eventually evaporates. This is what it looked like after.
post #4 of 6 Old 02-29-2012, 12:21 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
I'll go with heat also. If it is full adhesive on the back of the old one and not just adhesive strips, you may want to slide a piece of Dental Floss under the edge and work it down over the convex curvature of the tank as you apply some heat. Finish up with a light solvent that won't harm the paint/clear coat underneath to remove any residue.
Doc
ST-DocLizard1 is offline
post #5 of 6 Old 02-29-2012, 12:25 PM
Zippo lighter fluid FTW!!!
Just squirt it on the edges as you peel up, it will dissolve most sticky residues.
Won't hurt the paint and smells good, too!
post #6 of 6 Old 02-29-2012, 12:26 PM
I use a radiant heat gun.
Much better than a hair drier.
An oh my, some REALLY nasty fumes start venting from the tank when doing a big decal and pad strip job.
Do it outside, and not in your garage.
I started getting a wee bit woozzy doing my TechSpec installs on a cool day inside the garage with the door closed.
