Masterlink Help - Wrist Twisters
post #1 of 8 Old 06-09-2008, 06:10 AM Thread Starter
No life like low life
Hoseclamp's Avatar
Masterlink Help
OK because of my recent encounter with a sweatshirt I replaced my chain and sprockets yesterday. I decided that I would go with a rivet style masterlink since most people on here recommend it. Ive never had a rivet style masterlink before, and dont really know what I am doing. I ordered a rivet link tool, but couldnt wait for it, so I made one at work last night. Brought it home and it worked..... a little to well. It seems I got a little zealous when tightening the bolt and broke some of the rivet off. My first question is will it be OK the way it is or should I take it off and try to install another one. My second question is the one that didnt break, is that compressed to far. Do I need to try to flatten the end to put pressure on the face of the link, or just mush it out enough that the face plate cant come off. The more I smash it the thinner and weaker it becomes, but if I just mush the end a little that allows the plate room to potentially move in and out.
Sooooo... should I put another masterlink on, and if so how far do I peen it over
Thanks!
Knees in the breeze!
Hoseclamp is offline
post #2 of 8 Old 06-09-2008, 06:26 AM
If nothing else - for piece of mind I would replace that link. With the wheel all the way forward check the master link, it should not bind when pushed up and down with your fingers.
Just curious, how did you make the rivet tool? Any pics?
post #3 of 8 Old 06-09-2008, 06:30 AM
Heavy Metal
ratdog's Avatar
yeah, i didn't look at the pics...replace it, no worries
you can get close enough w/ a ballpeen hammer but the tool makes it easier
binding comes from over compression which is why i would stay away from some of the chain tools(motion pro), i think it's rk's or did's that has a stop in it...forget now
ratdog is offline
post #4 of 8 Old 06-09-2008, 07:31 AM Thread Starter
Hoseclamp's Avatar
Just a block of mild steel with 1 1/8" slot through it 7/8 deep. Then a tapped hole. The tips of the bolts were flame hardened so that they would not mush. One bolt has a tapered end to start the spreading, the other is just barley rounded to help keep it centered. I used that one second to finish the smashing process.
So on the next one you think I should not smash it as much? The masterlink is not bound, but I am concerned about the 'structural integrity' of the peened ends being smashed to much and spread to thin. Anybody have pics of their masterlink.
post #5 of 8 Old 06-09-2008, 07:35 AM
I would replace that thing. It takes very little spread to hold the thing together. Yours is certainly beyond the limit and has pieces missing.
post #6 of 8 Old 06-09-2008, 08:30 AM
BrokeRecord
Replace
A little peace of mind goes a long way, towards doing
100s of blissful miles.
brokerecord is offline
post #7 of 8 Old 06-09-2008, 08:44 AM Thread Starter
Hoseclamp's Avatar
Thats what I want. I put a lot of miles on every year. I was more than happy with my clip style but you guy got me worrying. I just want to be sure that when I put the rivet style on it is just right. Since Ive never done it and never really looked at anyone elses I'm not sure what the end result should look like. I dont want to peen it over to much, but I also want to make sure it wont work itself off. Almost everyone I know has a belt drive, shaft drive, or a clip style so I have nothing to gauge it off of. When I go to the bike shop to pick up my ordered chain tool I will ask/look how others are. On certain things I am a perfectionist (others things I just dont care) and I want to make sure my chain is solid and not have to think about it until it needs replaced. Im weird about some things.
post #8 of 8 Old 06-09-2008, 10:55 AM
wisco919's Avatar
The 919's Service manual includes specs on how large a diameter the rivet should mushroom. Take your time and measure the diameter with a vernier caliper as you go. If you cannot find the spec for the chain you purchased, try the manufacturer.
wisco919 is offline
