Garmin Quest Mount - Wrist Twisters
post #1 of 16 Old 05-27-2009, 02:04 PM Thread Starter
Garmin Quest Mount
My Uncle just gave my Dad a Garmin Quest. Dad is going to use it on his boat, but when he isn't using it, I may use it on my 919. Anyone know where I can get a mount for this? I keep seeing the cradle, mount, and wiring kit on eBay for about $25.00, but they all say you need to buy the "other" kit (most recommend the Ram Mount) to attach it to the bars.
What says you?
post #2 of 16 Old 05-27-2009, 03:18 PM
Personally I have a TomTom that uses a strong suction cup mount. Fits perfectly over my tach.
post #3 of 16 Old 05-28-2009, 06:28 AM
I use a RAM for my Magellan, clamps to the bars and is highly adjustable. I honestly think it would sustain hurricane force winds without moving.
Highly recommended.
dadogs is offline
post #4 of 16 Old 08-05-2009, 08:41 AM Thread Starter
Garmin Quest
Does anyone know if the OEM Garmin Quest/Quest II GPS mount will fit right in the center of the bars between the bar clamps?
Amazon.com: Garmin Handlebar Mount for Quest (010-10507-00): Electronics
Dad has a Quest that he inherited from his brother for his boat. He bought a second Quest off eBay for around $50 and said I can have it. I just need a mount and I prefer something a little lower profile than the RAM mount. I'll get a RAM mount if I must.
EDIT: I realize that I posted about a Quest mount a few months ago, but this is a different one...
MODS...please merge this into https://wristtwisters.com/general-str...est-mount.html
post #5 of 16 Old 08-05-2009, 09:38 AM
I had a fried motorcycle mount for a Garmin Zumo, and had to buy a new one. Found a brand new one on ebay for about 40% less than ordering from Garmin. May be worth a try.
post #6 of 16 Old 08-05-2009, 10:35 AM
(oYo)
2000TJ's Avatar
You could use the RAM craddle but fab up your own attachment to the bar if you're concerned about profile.
On my 9er I found the short RAM arm (1.5") in conjunction with the craddle and ball was a perfect height to clear the tank bag when they were both mounted. Remember you can also rotate the ball clamp around the bar to change position/height as well. By rotating the mount forward or back ~90 degreees you can impact the height of the mount by a good 2 inches or so.
2000TJ is offline
post #7 of 16 Old 08-05-2009, 01:54 PM
Originally Posted by cmurphy84 View Post
Done.
Sorry, no help on the question.
post #8 of 16 Old 08-05-2009, 02:08 PM Thread Starter
Thanks for the tip. I looked through several sites and looks like a RAM may be my best bet. It appears that I could mount it on the right side of the right clamp where the bars start to rise, then maneuver the mount so that the GPS sits in the middle of the clamps.
post #9 of 16 Old 08-06-2009, 03:36 AM
jeff1250's Avatar
That's how I have my Ram Mount set up. Works perfect. You can have the unit centered or off to the side. I use a Garmin Nuvi. The Ram cradle holds it way more securely than the supplied Garmin cradle.
jeff1250 is offline
post #10 of 16 Old 08-12-2009, 06:30 AM Thread Starter
Well...I got my Quest mounted last night. I ended up using their bicycle mount. It fit perfectly right in the middle of the bars. I had to use the Dremel to clean up the blank spot for a power connector so it didn't buzz against the clamp, but it looks and works great.
I tried to get a picture this morning but my camera battery died. My max speed this morning was 67 until I passed a semi. Then it shot up to 79.4. I like the fact that I now have a second trip and a clock. Also nice to see my actual speed instead of guessing while still keeping my odometer right.
post #11 of 16 Old 08-12-2009, 11:50 AM
GREAT IDEA!!! (Where's the Guiness Dudes..."brillant!"
One question though... power??? are you running it off the "charge" and if so, how long does it last?
GALAZIO is offline
post #12 of 16 Old 08-12-2009, 12:00 PM Thread Starter
I'm running on battery alone and do not need the backlight during the day. It's been running since 7:30 this morning and still has about 3/4 charge according to the display.
post #13 of 16 Old 08-12-2009, 02:32 PM Thread Starter
Here's some pictures...
post #14 of 16 Old 08-12-2009, 02:34 PM
ghei.....
real men don't need gps... we know where we are at all times....
damn the gene pool is getting polluted...
post #15 of 16 Old 09-09-2009, 06:07 PM
Ballaholic
hornet919's Avatar
a little late to the party but i have the same exact set up. works great for me. the quest is a pile of sh1t but other than that it will get home when im really lost and give me an accurate speed. hold a charge for 24hrs and is water proof so its good enough
hornet919 is offline
post #16 of 16 Old 09-12-2009, 07:58 AM
h8tenhogs
dukeriley's Avatar
i just made a mount for a buddy of mine at work.clear face padded back and velcros to handel bar.I have access to fabric, vinyls, and sewing machines.last week I made new seat cover for my 9.looks pretty good.:001_smile:
dukeriley is offline
