FZ1 Clutch noise when in neutral? - Wrist Twisters
post #1 of 5 Old 03-30-2016, 12:26 AM Thread Starter
Kyle
I'm assuming this is a normal sound, but when my bike is warm is in neutral and the clutch is engaged (lever out), it makes a slight grinding noise, and when its disengaged (lever pulled in) the sound goes away. should I be worried?
Helldiver14 is offline
post #2 of 5 Old 03-30-2016, 02:22 AM
redline919's Avatar
How many miles on it?Try adjusting the clutch cable first.
redline919 is offline
post #3 of 5 Old 03-30-2016, 08:37 AM
What you describe is very common. When in neutral roughly half the straight cut gears are turning, and the backlash necessary for operation will make noise as they turn. The noise continues when riding but is so small you can't hear it.
Bottom line: it is not a concern.
post #4 of 5 Old 03-31-2016, 10:37 PM
The Midnight Rider
SmokeDog's Avatar
Or the clutch bolts have backed out and rubbing the cover...
https://wristtwisters.com/image.php?type=sigpic&userid=3500&dateline=1256946  831
SmokeDog is offline
post #5 of 5 Old 04-01-2016, 12:48 AM
redline919's Avatar
Ha! I had that happen before to one of my old GSXRs
