do it your self oil change - Wrist Twisters
post #1 of 8 Old 01-08-2008, 12:23 PM Thread Starter
jassto's Avatar
So I drained the oil out of my Z750 before putting it away for the winter and I was wondering if anyone had any advice about how tight you should get the drain plug when you put it back in.
I know with my old dirt bike I go about a full turn past snug. (I don't have a fancy torque wrench).
jassto is offline
post #2 of 8 Old 01-08-2008, 12:36 PM
Veteran Donation
I would say the same but, a full turn after snug sounds like a lot.
I hope you put some oil back in.
tvetree is offline
post #3 of 8 Old 01-08-2008, 12:39 PM
wisco919's Avatar
Put some oil back in it after you get yourself a new crush washer, then tighten till snug. Not "lift with your legs" tight, just get the new washer to deform a bit.
wisco919 is offline
post #4 of 8 Old 01-08-2008, 12:41 PM
About a quarter turn after snug is more than enough.
dadogs is offline
post #5 of 8 Old 01-08-2008, 12:53 PM
Wookie
ragdoll's Avatar
Impact wrench for about 30 seconds.
No
'02 RC-51
'10 Unicycle
ragdoll is offline
post #6 of 8 Old 01-08-2008, 01:13 PM
1/4" past snug is the most I'd go. You do want to be able to remove it at the next oil change.
post #7 of 8 Old 01-08-2008, 01:34 PM
Be sure to use red loctite on the oil drain bolt when you put it back in.
ok, ok, don't do that either.
post #8 of 8 Old 01-08-2008, 01:45 PM
Track whore
blueblur's Avatar
Trackday Recognition
No
damn so that was my problem...
blueblur is offline
