2 stroke scooter - Wrist Twisters
post #1 of 12 Old 06-30-2007, 09:59 AM Thread Starter
Living the dream
TLR_Nate's Avatar
2 stroke scooter
I am searching for help again from my smarter friends on here.
Ang and I bought a cheap Chinese knock off scooter a couple years ago. Was problems fromt he start but after a better spark plug and some tinkering ran better. Well last year at Mid-O when we tried to start it oil just puke dout the exhaust.
Well...that would seem to mean the oil injector is bad right? We have not got around to fixing it cause been no need. But with Mid-O coming up again soon it would be nice to have transportation.
Questions...
1. Even worth fixing? Paid almost as much for shipping as complete scooter.
2. If it is the oil injector, any chance of even finding a new one? RC90 any help? Would any injector for a 2 stroke work?
I know we should have paid more to get a more reliable one but trying to save a buck. Worse case I figure we avoided renting a cart a few times and that would be break even.
Thanks for the help as always.
TLR_Nate is offline
post #2 of 12 Old 06-30-2007, 10:40 AM
Wookie
ragdoll's Avatar
Did you tear into it yet to determine what actually is wrong with it? No sense looking for hard to find parts if it's not even the issue.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #3 of 12 Old 06-30-2007, 01:42 PM
Go'n So slow I'm stopped
xrmikey's Avatar
If it is the oil injector,block it off & just pre mix the fuel before dumping it in the tank.
xrmikey is offline
post #4 of 12 Old 06-30-2007, 03:08 PM
Toll Runner
str8ghtjacket's Avatar
xrmikey beat me too it. Just premix, the chance of finding the parts you need are slim . Good luck , str8
str8ghtjacket is offline
post #5 of 12 Old 06-30-2007, 04:58 PM
Tired of Tirone
jeffspeak's Avatar
If you don't run it much, I would try and rule out the bad fuel/dirty carb stuff. If you have enough compression, both kinds, and spark, not too much can go wrong.
Good luck.
jeffspeak is offline
post #6 of 12 Old 07-01-2007, 07:09 AM Thread Starter
Living the dream
TLR_Nate's Avatar
As little as I use it I have not torn too deep into it. When I was messing with it at the track the concensus was there was an issue with the injector since every kick spewed oil out the exhaust.
I have been told before to just do premix. May have to go that route. Have to see if I can get my bussy who is better better a bike mechanics then me to come over and help.
Thanks again to all for the help!!
TLR_Nate is offline
post #7 of 12 Old 07-01-2007, 07:13 AM
Pull the plug and check it before you try anything else. 2 strokes that don't run well can foul a plug in a heartbeat, and you'll have no chance of it running, premixed or not.
post #8 of 12 Old 07-01-2007, 03:34 PM
not cro-magnon
Relic11's Avatar
Good advice! A little oily fuel in the exhaust is no big deal, especially if it isn't firing. I start every other race weekend with shiny new NGK's in all of our 2 stroke 100cc motors.
Relic11 is offline
post #9 of 12 Old 07-01-2007, 05:16 PM
I like to take pictures!
angela155's Avatar
The plug was the first thing we checked cause we've had that problem before. Thanks for the suggestion to look at it though!
angela155 is offline
post #10 of 12 Old 07-08-2007, 02:49 PM Thread Starter
Living the dream
TLR_Nate's Avatar
Here is an update. Scooter is running!!
Here is how this crazy thing works. The oil injector pump works off the rear wheel so as long as the rear wheel spins it injects oil. Crazy eh??
Everything was totally flooded. We got it cleaned out and running and want to keep using the injector. Sucker smoked and puked oil like crazy forever!!
Question...I was using pre-mix 2 cycle oil which I was not supposed to be using. Supposed to use injector oil. What is the difference and is that proably why the oil was running through so easy?
TLR_Nate is offline
post #11 of 12 Old 07-08-2007, 03:30 PM
Glad you got her running. I've only owned one 2 stroke bike (I've always had 2 stroke, pre-mix weedeaters), and the bike was injected. Put straight 2-stroke injector oil in and never had a problem.
Are you talking about oil that was already pre-mixed with gas? If so, that was your problem.
post #12 of 12 Old 07-08-2007, 06:59 PM Thread Starter
Living the dream
TLR_Nate's Avatar
Nope. Just 2 stroke motor oil that would be used for pre-mix. There is a label sort of hidden that says injector oil only. Was wondering if there is a thickness or flow difference in injector and just 2 cycle oil.
Also now knowing how the pump works lets me know to not turn the rear wheel and let oil flow in unless it is running. I can also let it idle while sitting to burn any excess off. We also turned up the idle a bit and it seems to run a lot better and stronger than before. Unreal how much oil spewed all over the place. I have some garage floor to scrub now.
Although we got a good ride in this morning before we takled the scooter. Then ripped around the neigborhood throwing smoke.
TLR_Nate is offline
