Y Pipe Removal - Wrist Twisters
post #1 of 18 Old 12-05-2011, 04:01 PM Thread Starter
Teen Wolf
Cotten Mouth Chris's Avatar
Y Pipe Removal
ive searched this forum looking for how to remove the y pipe or mid pipe of the 919 is it just as easy as pulling it or do i have to remove the whole header?
Cotten Mouth Chris is offline
post #2 of 18 Old 12-05-2011, 04:15 PM
You need to support the bike on a center stand, remove the shock mount bolt, and let the swing arm drop a little bit.
I think that's the easiest way.
If you don't have a center stand, I'm not sure.
post #3 of 18 Old 12-05-2011, 05:04 PM
With the front wheel on a stand, I put a steel rod through the centerstand holes and lifted it with a hydraulic floor jack, then removed the shock. I tried just removing the lower shock bolt, but couldn't get the Y-pipe out.
If you do this get someone to help you steady the bike.
post #4 of 18 Old 12-05-2011, 09:17 PM
"CERTIFIABLE"
Ken Phenix's Avatar
I lag screwed some pretty beefy brackets into the rafters of the man cave and have 3 cheap Harbor Freight cable hoists hanging from them - 2 for the bars or front engine mounts and 1 for the tail. I can easily suspend the whole bike and set it down on jackstands for stability.
click to enlarge (note the nylon straps to prevent scratching)
Ken Phenix is offline
post #5 of 18 Old 12-05-2011, 11:35 PM Thread Starter
Teen Wolf
i was hoping to leave the shock in ohwell guess i better buy an ohlines to replace the rear shock since im taking it out anyways hehe
post #6 of 18 Old 02-27-2015, 01:58 PM
ewmin3m's Avatar
sooooo it's not possible to remove the Y pipe without fiddling with the shock ? i wish i tried it a bit more when i cleaned everything but the y pipe... :-/
ewmin3m is offline
post #7 of 18 Old 02-27-2015, 02:21 PM
Guys, you don't have to remove the shock. A few people prefer to use a high grade hack saw to cut the Y-pipe for easy removal. Just cut and go, simple as that.
Another pro tip would be to use sand and water to scrub your tires.
post #8 of 18 Old 02-27-2015, 03:43 PM
Yeah, it's much easier if you take out at least the bottom shock bolt, and drop the swingarm (assuming you have suspended the bike by the rear subframe and secured the front at this point).
post #9 of 18 Old 02-28-2015, 12:02 AM
Geezer w9er
cyberct's Avatar
Y-pipe removal
There are a couple of worthwhile youtube videos available on y-pipe removal, one demonstration coming in the first of a four part series entitled:
The second is notable for its innovative solution involving a tall stepladder and some ratcheting straps to create a "redneck hoist" to support the motorcycle!
cyberct is offline
post #10 of 18 Old 02-28-2015, 07:37 PM
^^ Tee Hee!!!
post #11 of 18 Old 03-01-2015, 06:29 AM
Originally Posted by cyberct View Post
There are a couple of worthwhile youtube videos available on y-pipe removal, one demonstration coming in the first of a four part series entitled: Video Link: http://www.youtube.com/watch?v=M24oiym4UuQ The second is notable for its innovative solution involving a tall stepladder and some ratcheting straps to create a "redneck hoist" to support the motorcycle!
I heard the guy who made that video lives in his moms basement. He only has one testicle because he lost the other one from masturbating too hard one day. Could be rumors but I doubt it! :P
post #12 of 18 Old 03-01-2015, 07:30 AM
Claimed he was charging his phone
post #13 of 18 Old 03-01-2015, 07:35 AM
He's not just a client, he's also an investor.
post #14 of 18 Old 03-02-2015, 08:44 AM
post #15 of 18 Old 03-02-2015, 07:36 PM
post #16 of 18 Old 03-02-2015, 08:14 PM
post #17 of 18 Old 03-02-2015, 08:59 PM
I don't even want to know how you found those answers.
post #18 of 18 Old 03-03-2015, 12:10 AM
Easy
