power commander on 919... - Wrist Twisters
post #1 of 25 Old 10-09-2010, 03:28 PM Thread Starter
dogjaw's Avatar
...what's up? never been clear on the whole idea, would love to smooth out my throttle, if this is applicable. what are the pros and cons? and are there different settings for different applications?
dogjaw is offline
post #2 of 25 Old 10-09-2010, 03:37 PM
Some good info towards the end of this thread.
https://www.wristtwisters.com/f94/to-...ack-25221.html
post #3 of 25 Old 10-09-2010, 05:35 PM
rmb meant the "9er quick turn throttle?" thread, have a look there instead of the track or not to track thread.
post #4 of 25 Old 10-09-2010, 07:52 PM
That's correct, my bad...
post #5 of 25 Old 10-09-2010, 11:01 PM
What's wrong with your throttle - it should be smooth without it. No problem with my stocker.
post #6 of 25 Old 10-10-2010, 07:48 PM Thread Starter
dogjaw's Avatar
nothing wrong, just heard that a PC gave smoother delivery but am unclear what that actually means in thr real world
dogjaw is offline
post #7 of 25 Old 10-10-2010, 10:34 PM
I personally think it's more trouble than it's worth. I bought my 919 with one already installed. I'v removed it and installed it several times. When it is installed, I don't notice an increase in power, or a smoother power delivery. I do notice that my bike doesn't start emmediately like it does when the PC3 is not installed. I had it removed for a year and a half, and I installed it just for shits, and it wouldn't run unless I held the start button in. Maybe I just need to reprogram it... I just got the cable to reprogram it a few days ago, so as soon as I get off my ass I will. There's maps out there that you can load according to your setup. Stock air filter, aftermarket air filter, full exhaust, slip on's of practically all brands... In my opinion it's too expensive for a mod that will cause more headaches than happiness. If you already have great riding gear, I think the next step is great tires, then trackdays till you need more tires.
det5lonewolf is offline
post #8 of 25 Old 10-11-2010, 07:10 AM
I never could tell any difference when I took my PC off. MHO, PC doesn't do much on a 919.
Not worth the money or the trouble. Mine is plenty smooth as is.
post #9 of 25 Old 10-11-2010, 08:07 AM
That was not my experience.
Mine was terrible at low throttle openings below 2500 RPMs on a full warmed engine. As in 1st gear traffic crawling and stop and goes. It bucked, it dove, it was a pain. I learned to soften it with some clutch. At present, PCIIIusb,Yosh TRSs and custom map noted, I can go down below 1,000 and have perfect throttle control, no clutch slipping needed - even with a passenger on the back on a slight uphill grade. The bike stinks less. Even the exhaust note at idle changed, and wife even commented on that without being prompted. The dyno work torque curve was also rather revealing, lots of the stock curve lumpiness is smoothed out. Point blank, the factory mapping on a 919 absolutely sucks in comparison to what you can get by virtue of a PCIIIusb. Will the PCIII kick you in the head at 7000 RPM when you wick it from 65 % to 100 % full throttle ? No. Will it improve rideability, give you more torque, improve overall fuelling and even reduce the infamous 919 stink level ? Yes.
post #10 of 25 Old 10-11-2010, 10:30 AM
i agree with mcromo. my previous 919 had the pcIII before wrecked and it was fairly smooth. i was still working out the different maps and had issues with the engine lugging below 1500 rpm but otherwise smooth. it "felt" lumpy at times because when you crack it just right, that torque kicks in lol.
my current 919 has no pcIII (same year), and it's all over the place at lower rpms. i'm constantly using the clutch to try and feather it out but it's still fairly rough. in city traffic sucks and is my primary motivation for installing the pcIII
post #11 of 25 Old 10-18-2010, 07:13 PM
mambomonster's Avatar
In the interest of an additional data point, I installed a PCIII today. I ordered the duck lord version which came with a custom map preinstalled for a bike with stock exhaust. It took me about 2 hours to get it installed mainly because I have a Givi rack and some LED trunk wiring to move out of the way. Installation was easy and I have some pictures if anyone needs them.
I rode the bike for about 30 miles. There were zero problems with cranking or idling as mentioned in other threads. The bike runs really smooth. How much difference can I tell from stock? A little. It may be psychological but I tried a lot of different roll ons and roll offs at all RPMs and it performs well with no hesitation, jerkiness, etc. I'm no expert but it does seem to be an improvement. I mainly bought it to be ready for whatever exhaust I end up going with.
mambomonster is offline
post #12 of 25 Old 10-18-2010, 08:07 PM
Did you synchronize the PCIII to the bike's ECU Throttle Positioner ?
post #13 of 25 Old 10-18-2010, 08:23 PM
Negative. I was not aware any such thing was needed. The instructions don't mention it.
post #14 of 25 Old 10-18-2010, 08:49 PM
arctic954's Avatar
Go into the pciii-USB software with your computer plugged in to your bike......believe it's called calibrate throttle. Your pciii needs to know what 0% and 100% throttle is.
It takes minutes to do..
arctic954 is offline
post #15 of 25 Old 10-19-2010, 05:31 AM
Good info, mine will be here tomorrow.
mcromo, would you be willing to share your TRS map? LDH is loading it with his Sato map, which I will try, but would like something Yoshi specific to compare with.
2015 Ducati Monster 1200S
FlyCatcher is offline
post #16 of 25 Old 10-19-2010, 07:06 AM
For sure, and just send me a PM with an e mail address that will accept attachments and I'll send it along.
I'll also include LDH's Moriwaki based map, version 4 that is, very good map. My Yosh TRS map is fairly close to that one.
post #17 of 25 Old 10-19-2010, 07:12 AM
The "Set Throttle" tutorial is what you need. It is a swf file type.
You can get it from the PC website.
I have a pre-established info bundle put together that includes it, so if you have trouble accessing the web info, I can send it to you.
You'd be amazed at how many PCIIIs get installed and are never synchronized.
It's very important at the lower RPM and lower throttle opening conditions.
post #18 of 25 Old 10-19-2010, 07:37 AM
I got it done thanks. I had not bothered to load the software since my unit already had a map.
post #19 of 25 Old 10-19-2010, 09:30 AM
PM sent
UPS Tracking:
HODGKINS, IL, US 10/19/2010 5:00 A.M. DEPARTURE SCAN
Next stop:
My house
BIG thanks to LDH for sending it out same day. Dan Kyle rocks
Dogjaw - I have been living with a real jerky throttle response and surging at low RPM. I will be sure to do a back to back comparison once the PCIII is installed to let you know if there is any improvement.
post #20 of 25 Old 10-19-2010, 12:08 PM
PM sent
UPS Tracking:
Next stop:
My house
If by chance your PCIII is out of phase by 3 % of throttle position, and you are at an actual 2 % throttle opening at some particular RPM, you could be seeing a 5 % throttle opening amount of gas or a 0 % throttle opening amount of gas being injected. This is why synchronization is so critical. I wonder how many PCIIIs and/or maps get cursed at low RPM small throttle openings, partially or totally, for the wrong reason ?
post #21 of 25 Old 10-19-2010, 12:17 PM
You need to get a proper map for your bike. It will make ALL the difference. I think a PC and a GOOD dyno tech (yes, get your bike dyno'd - was $100 where I'm at) and hopefully they will find a good combination for your setup.
I put on another 3hp (on top of already gaining one or two here and there with other mods/exhaust, etc.) JUST by changing the map. Not by adding the PC, but by changing the MAP.
So, if I were to do it again, I would WAIT on putting on the PC until I threw her up on the Dyno. I also didn't notice a lot of difference (a bit, but not a lot) when I first put the PC on.
After the Dyno and new map, it was a whole new world.
post #22 of 25 Old 10-19-2010, 12:20 PM
Question. I did NOT do this when I installed my PCIII, but I just recently had it Dyno'ed. Would the tech have done that for me? I'm assuming he would have seen that, seen my sorry excuse of a noob at putting the PCIII on without doing it, and then just did it for me.
I did download the map to my computer, however. Is there any way I can tell that it's been done? Or does it hurt to re-do it?
Thx in advance!
post #23 of 25 Old 10-19-2010, 12:25 PM
Thx in advance!
The swf file type tutorial is called "Throttle Set".
The Tech SHOULD have done it first, but you can't count on that.
You can not tell whether it has been done unless you connect the laptop to the PCIII on the bike with the ignition key on in the run position.
post #24 of 25 Old 10-19-2010, 12:36 PM
I can do that. Plan on it tonight. Cool, thanks for the info.
also found this.
See page 5, it talks about resetting throttle position. Two clicks of a computer, roll on throttle and let go (key on, bike NOT running I'm assuming). Looks like a piece of cake.
post #25 of 25 Old 10-19-2010, 12:41 PM
EDIT FOR ABOVE POST AS I WAITED TOO LONG TO EDIT THE ORIGINAL: I should clarify, for those looking to just smooth out the throttle response, yes, I would put a PC on to help with that. I was just trying to state above that if it came down to saying "at what point did I notice a difference" I would put 15% on PCIII with downloaded map off internet, and 85% of "got the bike dyno'd and know my neck hurts". Not trying to dissuade you who would just want the PC; do it. But you'll get so much more out of it with a proper map!
