Oil Change - Wrist Twisters
post #1 of 41 Old 08-04-2010, 03:07 PM Thread Starter
Oil Change
Leaving Saturday morning on a week long bike trip. Put the rack on and washed the 9er last night. Got to change the oil/filter tonight since tomorrow night is pack clothes night. My buddy from Atlanta is headed up Friday morning.
Not looking forward to an oil change at 100 degrees outside today. It's friggin' hot. The annual Street Rod Nationals are in Louisville this weekend. Hot rods broken down all over town. Did I say it's friggin' hot?
The plus side. I don't think it will take long to warm the 9er up.
post #2 of 41 Old 08-04-2010, 03:10 PM
What kind of oil are ya using?
Fram filter I hope!
post #3 of 41 Old 08-04-2010, 03:13 PM Thread Starter
Fram filter I hope!
Don't start.
post #4 of 41 Old 08-04-2010, 03:14 PM
Fram filter I hope!
LOL!!!!!
i hope hes using walmart special 5w30 with energy conserving additives!
post #5 of 41 Old 08-04-2010, 04:38 PM Thread Starter
LOL!!!!!
I think I will, then ride towards SoCal. You available for rescue?
Oil change done. Tire pressure checked. Chain lubed.
<3 days to liftoff.
post #6 of 41 Old 08-04-2010, 05:33 PM
<3 days to liftoff.
Hope you have a great trip Jim. Ride safe.
post #7 of 41 Old 08-04-2010, 05:40 PM
Have a safe trip Jim.
Professional
post #8 of 41 Old 08-04-2010, 05:49 PM
HAve a nice trip - hope you did not use that Rotella stuff!!!!!!!!
100 F - that's 38 C!!!!
I'm sitting on 10C down here - 50F
post #9 of 41 Old 08-04-2010, 06:08 PM
TAKE IT BACK.... rotella t pwns... is jaso MA certified, and is certified to beat yo momma up!
post #10 of 41 Old 08-04-2010, 06:09 PM
Rotella is actually WD-40 mixed with Peanut Oil
post #11 of 41 Old 08-04-2010, 06:38 PM
Speed Lover
XRCajun's Avatar
Man do I envy you! Have a great trip !
XRCajun is offline
post #12 of 41 Old 08-05-2010, 06:26 PM
no wonder why it tastes so good!
post #13 of 41 Old 08-05-2010, 06:28 PM Thread Starter
Luggage onboard. Final assembly tomorrow night. Ride Captain Ride.
post #14 of 41 Old 08-05-2010, 06:47 PM
Enjoy yourself, have a safe trip.
post #15 of 41 Old 08-05-2010, 07:02 PM Thread Starter
Thanks, I hope to. I've been doing annual one or two week trips with this guy for 20+ years now. We have a system down. Don't bitch, do whatever, go wherever, but the main thing is have a good time whilst there and enroute. It's worked so far, so I expect the same this trip.
post #16 of 41 Old 08-05-2010, 10:10 PM
I heard that Rotella was actually the oil from under really fat inmates man-boobs gently squeezed into containers and then refined with a touch of hair grease.
But I may be wrong.
Also I read a K&N filter will add 10mph to your top speed and decrease fuel consumption by 5% due to the nut on the front of it improving the aerodynamics of the bike.
And doing a burnout to remove 90% of the tread from your rear tyre reduces unsprung weight and improves the bikes handling.
post #17 of 41 Old 08-05-2010, 10:29 PM
But I may be wrong.
i also heard that if you spell tire tyre, your gay
post #18 of 41 Old 08-06-2010, 12:55 AM
No - you have it wrong - Tire is obviously the gay way as the 'i' looks like a penis .....
post #19 of 41 Old 08-06-2010, 01:56 AM Thread Starter
27 hours and counting. One last job bid today.
post #20 of 41 Old 08-06-2010, 03:41 AM
Don't do what I did many years ago on a Kawasaki.
The night before a trip I decided to do a oil change - and stripped the drain bolt thread! Result - ended up dropping the sump to helicoil it the next morning!
Pissed me off no end as I always used a torque wrench on that bike too!
post #21 of 41 Old 08-06-2010, 03:53 AM Thread Starter
All the work on the bike is done and test ridden two nights ago. She's awaiting final luggage transfer and a few gallons of breakfast in the morning, then it's go time.
25 hours.
Buddy departs Atlanta in 3.
post #22 of 41 Old 08-06-2010, 05:22 AM
Your not kidding about the rods being broken down. My uncle takes his 3 cars over there every year. Just about every year something on one of his cars breaks. Last year was an oil pump on his '34. The year before his '32 started sputtering badly due to a bad ignition module.
I thought about going down this year, but Saturday is our anniversary so it's shot. Sunday is wrap up day so not worth going.
Have a fun, safe trip.
post #23 of 41 Old 08-10-2010, 06:53 PM
Fram filter I hope!
Don't start.
Anything wrong with a fram oil filter? I've used them for years on my cars and motorcycles. No issues ever. Thanks!
jbanke1 is offline
post #24 of 41 Old 08-10-2010, 07:32 PM
I have never had a problem with them. Some folks do and the mere hint that you use a Fram incites a riot, I think due to having cardboard encaps.
Me, I'm a cheap bastard and use WalMart Supertech filters, but I change the oil every 2-3K miles.
This site has some info and talks about the issues with Fram, as well as a letter from Fram telling why their filters are OK.
http://motorcycleinfo.calsci.com/Fil...tml#OilFilters
I don't know anyone thats ever had their engine damaged by a bad Fram filter, but try to go on the best info I can find and still be a cheap bastard
post #25 of 41 Old 08-15-2010, 12:18 PM Thread Starter
Touchdown.
Toasted the rear tire on the Beemer. 100 degree heat + loaded with tri-cases + all backroads + slightly worn tire to start with = tire change on the road. Had to change a headlight on the run also. Factory GPS unit was intermittent. Rubber bumper came off one of the luggage cases. A little WD-40 and a good push and it went right back in the hole (insert gross remark here).
The 9er, on the other hand, performed great. Front tire is toast, forks need a rebuild, and I think I have either steering head or wheel bearing(s) going out, or both. Considering all I've done is chain and spockets I guess it's due. 34,400 miles. Probably check the brakes this winter also.
I'll wash it and put it up to rest for awhile.
As far as the trip, holy backroads. Kentucky, West Virginia and Tennessee have some great ones.
I'll post up some pics and some blurbs later after some bike work. Unless I'm snoozing.
post #26 of 41 Old 08-15-2010, 01:57 PM
Glad you had a good trip and are home safe. Looking forward to pics and blurbs.
post #27 of 41 Old 08-15-2010, 04:15 PM
blur
drewvir's Avatar
me too,but not because i'm cheap but calsci listed them as 1 of the better filters
Motorcycle Filters.
None are recommended.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
drewvir is offline
post #28 of 41 Old 08-15-2010, 04:24 PM
Ken
Community Admin
Ken's Avatar
Welcome back, Jim. Hope the trip was a great one!
2009 Honda Goldwing
Ken is offline
post #29 of 41 Old 08-15-2010, 04:40 PM
Welcome back Jim. Looking forward to pics.
post #30 of 41 Old 08-16-2010, 07:07 PM Thread Starter
New River Gorge Bridge. It's set some records. This is looking at it from the original bridge.
Up top from the observation deck. In October they close the southbound lanes and folks base jump off the bridge. You can fit one Lincoln Monument and two Statue of Libertys and still have room to spare to the bottom of the arch.
Another view with some nice rapids in the river. That's a semi crossing the bridge.
National Radio Telescope Obsovatory with the Big Daddy looking up. 2 degree lat and long dead zone for radio transmissions. You can take a tour and walk right up to the scope. No electonic devices allowed, and all vehicles behind the gates are diesel since spark plugs interfere with reception.
Another shot. There's seven telescopes here total. Some are remote controlled from universities.
Big Bend tunnel sign with the legend of John Henry.
Bikes at the John Henry statue.
The new tunnel is on the left, and the original tunnel is on the right. One mile straight thru rock built in the 1870s.
Found out that Chuck Yeager is from Hamlin, WV. This is his statue in front of his high school.
post #31 of 41 Old 08-18-2010, 02:56 AM Thread Starter
Bump. Guess my choice of title, or that nobody likes Chuck Yeager, killed my thread.
post #32 of 41 Old 08-18-2010, 03:43 AM
Ken
Community Admin
Ken's Avatar
Yeah, great pics and a trip report probably deserved a new thread
The New River Gorge pictures are awesome. And I would love to see one of those telescopes up close in person. But aside from the picture descriptions, you didn't have much to say about the trip itself - how was it? Looks like it was a one of those head-clearing trips. I'm overdue for one.
2009 Honda Goldwing
Ken is offline
post #33 of 41 Old 08-18-2010, 04:14 AM
Really nice pics Jim. I live close enough to WV that I need to go and do some exploring there. The semi on the bridge really puts the size of that thing in perspective.
post #34 of 41 Old 08-18-2010, 05:54 AM
Very nice!
Blackheart is offline
post #35 of 41 Old 08-18-2010, 06:21 AM
Speed Lover
XRCajun's Avatar
Yeah very nice!
XRCajun is offline
post #36 of 41 Old 08-25-2010, 05:34 PM
Veteran Donation
I'll admit it,I skipped it a few times.An oil thread (even started by Honda Jim) is going to go down hill fast....
Then it was oh wait He tied that to His trip..Must see Picts.
Thanks for the trip picts.
tvetree is offline
post #37 of 41 Old 08-25-2010, 05:36 PM Thread Starter
Glad you found it and much more, I'm glad you liked it. Let's ride sometime soon. Been too long.
post #38 of 41 Old 08-25-2010, 06:13 PM
do most people warm up or change there oil on a warm motor...i never did always or mostly stone cold
secondchance is offline
post #39 of 41 Old 08-25-2010, 06:41 PM
I run the engine just a bit - just enough to keep my hands warm in the winter!
post #40 of 41 Old 08-25-2010, 08:06 PM
Yeah, you should always change the oil when it's warm, runs out much faster and drains more completely than colder, thicker oil.
Superduke
R1200GS
XR650L
