No Ethanol Gas Stations List - Wrist Twisters
post #1 of 16 Old 03-10-2011, 08:51 AM Thread Starter
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Interesting site to share.
Ethanol-free gas stations in the U.S. and Canada
Sadly, none are in the Garden State.
Doc
ST-DocLizard1 is offline
post #2 of 16 Old 03-10-2011, 09:15 AM
Hmmm, something is fishy. There are listing for MN.
MN mandated 10% years ago. 20% is currently being reviewed. If it passes and your motors break the State says tough, and the manufacturers will say you shouldn't have run 20%.
All this for a fuel that accomplishes exactly nothing for the environment.
2015 Ducati Monster 1200S
FlyCatcher is offline
post #3 of 16 Old 03-10-2011, 10:19 AM
lusting over something...
james_kraska's Avatar
Except cause commodity prices to rise....
james_kraska is offline
post #4 of 16 Old 03-10-2011, 11:51 AM
schrock86's Avatar
If you look at the list it is mostly premium that is ethanol free. Thats how it is here ia IA too. You can get 87 and 91 ethanol free and 89 always has ethanol. I'm tempted to try running the 10% blend and see if it affects the stink at all
schrock86 is offline
post #5 of 16 Old 03-10-2011, 12:03 PM
Carp Killer
Wallybanger's Avatar
didn't know ethanol was bad for the engine! I'll have to keep an eye out. thanks
Wallybanger is offline
post #6 of 16 Old 03-10-2011, 12:05 PM
In WI most premium is ethanol free. MN is different. State law dictates that everything is E10. TPaw signed a bill in 2005 that all MN gas had to be E20 within 8 years. It's still at the EPA as far as I know. For now we have to suffer with E10.
I don't say suffer lightly. My push and riding mower, boat and string trimmer run like SHIT on this stuff. The car and bike seem ok but my boat....that's another story. In WI, it runs like a top. Not even a hiccup. Run E10 through the poor thing and it has trouble starting and won't idle. It has nearly stranded us several times. It starts on fast idle, but by the time I move the throttle from fast idle (N) to idle then get it in gear to go, it quits. E20 is going to be the end of it.
Wally, too much is bad for some motors. Flex-Fuel engines can run on E85 or real gas. A non Flex-Fuel car can run on E10 but may have mileage and performance issues. Small motors like on a boat or mower are affected to a larger degree. The EPA is still studying the effects of E20 on regular engines. Damage to seals is the primary concern.
http://www.newrules.org/energy/news/...thanol-mandate
http://www.npr.org/templates/story/s...toryId=4677259
post #7 of 16 Old 03-10-2011, 12:09 PM
schrock86's Avatar
Minnesota Passes 20 Percent Ethanol Mandate | The New Rules Project
Is Minnesota's Ethanol Push Good Policy or Just Politics? : NPR
oooohhhhhhhhhhhh its mandated across the board. I hope IA doesn't do that which surprises me that we haven't yet seeing how much corn there is around here. I've never had any problems with the 10% in my cars, but I've never tried it in anything else.
post #8 of 16 Old 03-10-2011, 12:21 PM
Yep, good ol Uncle Gov'ment looking out for our "well being" again. Holiday is a MN company and even their stations in WI have E10. Lots of places in WI are going all E10 as well. It's coming, but engines need to be made to run it first.
post #9 of 16 Old 03-10-2011, 04:54 PM
I've noticed a slight dip in my fuel economy in my car (from 33.5 to about 32.8) but SEEMS like it runs a bit more torquey since the change. On the niner I don't notice a huge difference since I changed to the 89 instead of 91 about the same time they added the 10% ethanol. My reading on the E85 is that ethanol produces more torque and horseies than gasoline, but at the cost of fuel economy. And there are benefits to ethanol being that it can be made form corn, which is renewable (and the corn they use isn't food supply corn, so that argument doesn't fly with me), while fossil fuels are not.
MaxwellEdison is offline
post #10 of 16 Old 03-10-2011, 05:10 PM
Batman
velodesign's Avatar
Milk is a renewable resource...so is malt liquor. All rise in price every year...
Whoever says ethanol will set us free is smoking the corn pipe, not refining it.
velodesign is offline
post #11 of 16 Old 03-10-2011, 07:15 PM
Tirone is my middle name
mattf's Avatar
they use field corn for ethanol, the kind they feed cattle with. so yes, sweet corn will not be effected but the cost of beef will be because it will cost more to feed the cattle to grow them big enough to butcher and sell to consumers.
'08 Yamaha WR290R/X
'09 KLX140L (wifes bike)
mattf is offline
post #12 of 16 Old 03-10-2011, 07:59 PM
blur
drewvir's Avatar
alcohol is bad for a couple of reasons.drag racers have run the stuff for years, but you need to run about 40% more alcohol thru the motor to get the same stoich ratio. that's why your fuel/econ. goes down on e10/e20/e-85 vs. gas. alcohol also eats rubber fuel lines and pump seals,washes the oil off the cylinder walls and dilutes the oil because it gets past the rings.
for the boaters, if your boat has a built-in tank make sure it's NOT a fiberglass tank because alcohol will eat the resin and turn it to mush which ends up in your jets/injectors.
i don't buy the e10/e20 b.s. each gal has less gas by vol. BUT you get less mpg so you use more gals.
drewvir is offline
post #13 of 16 Old 03-11-2011, 04:59 AM
Yo Schrock, my apologies. Looks like I have to eat my hat.
I did some more searching last night and found some forum chatter from last year saying that MN had "exceptions" to the E10 rule. I can't find the actual legislation or anything about the exception, but I called a Marathon near my house this morning and he confirmed they have non-oxy premium. I can only assume there are more out there. Looks like I have a new place to fill up
post #14 of 16 Old 03-11-2011, 08:06 PM
BrokeRecord
10% ethanol is like feeding a horse dry hay in the winter. It fills his belly (gas tank), but, doesn't produce horsepower ( mileage or power)!
brokerecord is offline
post #15 of 16 Old 03-11-2011, 09:55 PM
schrock86's Avatar
No Worries, I drove through MN and WI today and filled up in both, without ethanol. I was gonna ask you about it but you cleared it up already.
post #16 of 16 Old 06-18-2011, 01:15 PM
BrokeRecord
As of June 1,2011, we lost all our pure gas. Our last 4-5 stations put their signs up declaring that you will receive 10% corn, barley with every gallon of gas!
Three kicks in the butt for Al Gore!
