New 12volt shiatsu massager installed on bike - Wrist Twisters
post #1 of 19 Old 04-30-2010, 10:28 PM Thread Starter
(oYo)
2000TJ's Avatar
Ok, not really. It's actually the beginnning stages of the cruise control install I contemplated a year ago on the 919....finally coming to life.
2000TJ is offline
post #2 of 19 Old 04-30-2010, 11:39 PM
intresting.... i have a very simple little thing that clamps down on the throttle tube to do the same thing. But hey thats a sexy way to go bout it.
post #3 of 19 Old 05-01-2010, 08:49 AM Thread Starter
(oYo)
2000TJ's Avatar
Yeah, I've used a throttle lock on the last 3 bikes i've owned. I've got a very nice Kaoko on this Tiger as well. Unfortunately none of them did the "same" thing.
I'm all sober now and going out to start the electrical hook ups.
2000TJ is offline
post #4 of 19 Old 05-01-2010, 09:08 AM
BrokeRecord
Over my head, but, better have a good kill switch, don't do a Toyoto ride of your life!
brokerecord is offline
post #5 of 19 Old 05-01-2010, 10:29 AM Thread Starter
(oYo)
2000TJ's Avatar
Brake and clutch switches are built into the kill circuit. There is also a reliance on ACC power and the native clutch action and kill switch to fall back on. The only thing I won't have is over-rev protection if it slips out of gear. <<< still thinking aobut that one.
2000TJ is offline
post #6 of 19 Old 05-01-2010, 02:09 PM
I can certainly understand the advantages of CC over a throttle lock....
However I would not do it. But that is me.
I like throttle locks for what I use them for.
-Temporary relief for my hand.
post #7 of 19 Old 05-01-2010, 02:12 PM
I did install a similar unit on my old AMX. It works... not as well as a factory installed unit... but for long drives in that car... it made it easier to keep it under control (cruise control was a solution after being pulled multiple times in a short peroid)
post #8 of 19 Old 05-01-2010, 05:56 PM
thats what the rev limiter is for... its not like the CC is going to be anywhere near WOT...
post #9 of 19 Old 05-01-2010, 08:31 PM
I like it, and will be VERY impressed with your challenging install if it survives your long punishing rides. My $15 throttle palm rest CC works well...but must be checked before every ride so it doesn't block the brake lever like on my last ride....
dream is offline
post #10 of 19 Old 05-01-2010, 09:43 PM Thread Starter
(oYo)
2000TJ's Avatar
agreed on both points
I'll be impressed if the thing even works. I just got back from my first test run which was a flop. She doesn't engage. It passed all of the diagnostic tests in the manual so it may be something simple. I think my cluch switch may be showing it neutral or something other than open. I'm going to go check that....
2000TJ is offline
post #11 of 19 Old 05-02-2010, 08:56 AM
Bolt on a VOM to your HB to debug... Did you silver solder all the leads? Hope you have the polarities correct to keep the operation smoke in your ECU...
dream is offline
post #12 of 19 Old 05-02-2010, 12:48 PM Thread Starter
(oYo)
2000TJ's Avatar
VOM, check
BH, what's that?
Solder, yes I always solder and heat shrink, sometimes tape on top of that
Smoke inside ECU,check
She runs fine and the servo diagnostics are still passing. I've tried every combination of DIP settings that make sense to me but it still doesn't "set".
I'm going to call the manufacturer tomorrow for some guidance.
2000TJ is offline
post #13 of 19 Old 05-02-2010, 01:22 PM
VOM, check
BH, what's that?
Cool project TJ. That bike is gonna be a touring machine when it's done. The massager aint a half bad idea too .
I think dream was telling you to bolt a VOM to your handlebars so you can troubleshoot while your riding....either that or he meant H1B in which case your gonna need a pickup truck and a quick Spanish tutorial.
post #14 of 19 Old 05-02-2010, 06:34 PM
Yes MM understood my joke about the VOM on the bars to check is a a bump shorts out the magic unqualified circuit. It is very rare to find an H1B that speaks Spanish.
Hope you flip the right bit on your CC and keep the smoke in your ECU!
dream is offline
post #15 of 19 Old 05-02-2010, 07:18 PM
I know from firsthand experience in automotive wiring that replacing the smoke if it gets out of the wires can be expensive...the kits are hard to find, it's hard to put the smoke back in, and the aftermarket smoke just doesn't ever smell quite like it should.
post #16 of 19 Old 05-02-2010, 07:31 PM Thread Starter
(oYo)
2000TJ's Avatar
I'm still stumped. I tihnk it the VSS being out of the range of the Rostra unit.
By my math the Tiger puts out 54,XXX pulses per mile whereas the Rostra will only setup for 38,XXX.
I'll ask the tech dudes tomorrow if this would prevent the unit from "setting" or only cause hunting and seeking issues in use. I think there may be a divider in my future.
2000TJ is offline
post #17 of 19 Old 05-02-2010, 08:53 PM
Can you borrow a scope and verify they are compatible? That converter could be the missing link. Keep the magic smoke in your ECU.
dream is offline
post #18 of 19 Old 05-03-2010, 10:42 AM Thread Starter
(oYo)
2000TJ's Avatar
I spoke to Rostra techncal support this morning. He agreed that my VSS is probably too far out of range. I picked up a pulse divider for $35 plus shipping and will have to wait until it arrives to determine if that's the issue. It's a shame I didn't go with the olderbAudiovox CCS-100 which is well known to work with the coil for speed control versus the ECM/VSS. I found the CCS-100 are out of production, though not impossible to source.
2000TJ is offline
post #19 of 19 Old 05-03-2010, 09:36 PM
That would be too easy, where's the fun in that?
dream is offline
