Most dangerous thing I've done in my garage? - Wrist Twisters
post #1 of 11 Old 04-17-2010, 07:45 PM Thread Starter
(oYo)
2000TJ's Avatar
I don't know why I was so damn intimidated by this rig. It must be all of the horror stories I've heard about guys mangeling their fingers while working with compressors on thier coilover Jeeps.
The Tiger comes off the island sprung for little girls....and I'm not a little girl. The new (old) spring came off a '97 CBR XX. It has permitted me to go from MAX preload to MIN and also dial out almost all of the excess damping I had plumbed in to help the over-worked spring that was in there. This is going to help alot when I get this girl back into the hills.
Most people over on Tiger1050.com agree that anyone over 170lbs will find the new Tigers under-sprung. I may be down to 245 now but will be back to 265 quickly once I get off the cardio kick and back to the weights.
2000TJ is offline
post #2 of 11 Old 04-17-2010, 09:47 PM
Had to do the front struts on my dads 04 toyota tacoma.... had to compress them a good 4 inches before they became loose... those were some HAIR RAISING MINUTES!
post #3 of 11 Old 04-18-2010, 04:46 AM
Total Awards: 17
you can never have enough Vise Grips
zaq123 is offline
post #4 of 11 Old 04-18-2010, 05:28 AM
It never ceases to amaze me, the amount of wiring a "simple" motorcycle has.
post #5 of 11 Old 04-18-2010, 07:09 AM
DualSport Transplant
The only dangerous part looks to be the hose clamps, yikes!
ALS919 is offline
post #6 of 11 Old 04-18-2010, 07:19 AM
+1! That is a darwinian award winning setup. Who recommended that?!
dream is offline
post #7 of 11 Old 04-18-2010, 08:03 AM
Fat guy on a little bike!
Byrdman's Avatar
Next time, load up the truck and head down. I have a 20ton hydraulic press that is just a smidge safer than your setup!
Jeff
Byrdman is offline
post #8 of 11 Old 04-18-2010, 10:39 AM
I had a spring compressor come off the 620lb springs I was installing on my 69 mustang one time, the spring clipped my left thumd as it rocketed across the garage floor, I was afraid to even look at my thumb thinking it was probably laying somewhere on the other side of the garage with the little coily rocket ship. Spring compressors scare the bejeebers out of me.
post #9 of 11 Old 04-18-2010, 05:15 PM Thread Starter
(oYo)
2000TJ's Avatar
Those were used to disassemble the XX shock which required zero compression to unscrew the preload dials. The clamps simply speed up the process and had very little load on them, literally 2 or 3 turns past hand tight on the screws. Using the actual compressors on the tiger shock (for both springs) was the real pain.
2000TJ is offline
post #10 of 11 Old 04-18-2010, 08:26 PM
Ahh you just posted that pix to see if we were paying attention.
Doing my cage's struts I couldn't compress it them enough with a custom tool (spring too small) so took it to a shop with a press, best money I ever spent.
dream is offline
post #11 of 11 Old 04-18-2010, 09:02 PM
The spring compressor i got at the auto parts store for my dads tacoma was actually pretty nice, instead of having hooks it had 2 u bolts that went around the spring and got bolted on to the bracket that a big ole bolt n nut ran through. Twaz unnerving to see those big bolts slightly bent during the process.
