honda 919 part number 94050-10000 - Wrist Twisters
 7Likes
  • 3 Post By Mark919
  • 1 Post By mcromo44
  • 1 Post By robtharalson
  • 1 Post By K1w1Boy
  • 1 Post By Darth_Firebolt
post #1 of 10 Old 07-27-2020, 11:51 AM Thread Starter
Hey all, I bought a 919 about a month ago and noticed a bolt was missing. I got the nut and bolt ordered but I don't know if there's a specification on how tight it needs to be. I don't want to be under or over and I couldn't find anything online. Any word at all is helpful
BigMan01 is offline
post #2 of 10 Old 07-27-2020, 07:18 PM
A notion of where it is on your bike and what it does would also be helpful :-)
K1w1Boy is offline
post #3 of 10 Old 07-28-2020, 02:22 AM
Scrawny's Avatar
13 newtons i dink...!
Scrawny is offline
post #4 of 10 Old 07-28-2020, 07:54 AM
Until it goes 'click'
GU Erik is offline
post #5 of 10 Old 07-28-2020, 01:57 PM Thread Starter
Pics of location (both sides)
Here's pics of the hole from both sides, I'm not sure what it does but given that there's not many 20cm bolts on the bike I would say it's semi-important.
BigMan01 is offline
post #6 of 10 Old 07-28-2020, 03:18 PM
Canadian Blue
Mark919's Avatar
Yup, It's important.
It's the rear lower engine hanger bolt.
Per the manual it's a 10mm thread dia. with a torque of 50 Nm (37 Lbf-ft)
Manual doesn't show thread pitch, fastener grade, or bolt length.
good luck
mcromo44, GU Erik and BigMan01 like this.
Mark919 is offline
post #7 of 10 Old 07-28-2020, 07:36 PM
Considering your discovery of such a thing on an old bike that's new to you, I urge you to retorque all the critical chassis fasteners on the bike.
Who knows what else you may find!
rufftup likes this.
post #8 of 10 Old 07-28-2020, 09:44 PM
Yup, that happened to my '02. The tell was every time I changed the throttle the shift lever would move up and down, indicating that bolt had fallen out and the frame was flexing. Fortunately I had a good machine shop at my disposal and made a stud out of O1 oil hardening steel of appropriate length and tightened to 2 3/4 grunts with a nine inch breaker bar (Roughly equivalent to 50 ft/lbs). No problems since.
And, yes, the upper rear bolt needed tightening as well.
Interesting that it was on the center stand while doing all the work the new fastener would not insert into the engine boss ... it was not in line. Had to put it on the side stand to finish the job.
Darth_Firebolt likes this.
post #9 of 10 Old 07-29-2020, 12:26 AM
....I would say it's semi-important.
Consensus!!
[Don't get used to it, it can be hard to achieve round here]
K1w1Boy is offline
post #10 of 10 Old 07-31-2020, 11:17 AM
Pokemon Master
I'm going to go put some loctite on mine right now. I don't want to have to think about that bolt ever again...
rufftup likes this.
2007 919, 2013 CB500X, 2009 Buell XB12R, 20+ bicycles
Darth_Firebolt is offline
