help! 9er still won't start... - Wrist Twisters
post #1 of 35 Old 10-26-2010, 06:38 PM Thread Starter
dogjaw's Avatar
left my key on, ran my battery down to nothing; tried bump starting it in 2nd gear, jumping it off from my wife's bike, finally put it on a trickle charger, which shows the battery to be 100% recharged until I disconnect the charger, then shows 75% until I leave the charger on for about five minutes, then shows 100% again. The problem is that when I turn the key on, absolutely nothing, no headlight, fuel pump whine, and definitely no start... I've checked the fuses, battery connections, etc, everything appears to be fine. Is it possible that I boogered something up trying to jump start the bike? never had any problems at all before this weekend.
dogjaw is offline
post #2 of 35 Old 10-26-2010, 06:45 PM
Brain stolen again?
Your battery has met Mr. D.
的 said I never had much use for one.
Mathew Quigley
post #3 of 35 Old 10-26-2010, 07:04 PM
Gets censored
you have zero power at all but your battery says you have juice, Id bet you have a bad connection.
Id personally track my connections from the battery back.
brian is offline
post #4 of 35 Old 10-26-2010, 07:06 PM
Clean and tighten battery terminals.
Start.
Ride hard.
Stop.
Repeat steps 2-4.
post #5 of 35 Old 10-26-2010, 07:11 PM
Hasn't there also been a problem with kill switches failing?
post #6 of 35 Old 10-26-2010, 07:14 PM
Gets censored
Yes but that wouldn't kill all power, use a test light you'll find the issue pretty quick
brian is offline
post #7 of 35 Old 10-26-2010, 07:24 PM Thread Starter
dogjaw's Avatar
no sign of corrosion on the terminals, plenty tight... what is this test light business? and someone on another forum suggested that there might be an inline fuse... I've never seen one...
dogjaw is offline
post #8 of 35 Old 10-26-2010, 07:27 PM
Many fuses. I am positive there is not one big mother that will take out everything though.
Got the battery terminals around the right way?
post #9 of 35 Old 10-26-2010, 07:29 PM
Kill switch is in the on position?
post #10 of 35 Old 10-26-2010, 07:34 PM Thread Starter
dogjaw's Avatar
yep and yep... this one has me floored.
dogjaw is offline
post #11 of 35 Old 10-26-2010, 07:40 PM
You have a different battery you can try?
post #12 of 35 Old 10-26-2010, 08:05 PM Thread Starter
dogjaw's Avatar
unfortunately not, is it possible to be showing a charge, but not having enough juice to even power the headlight?
dogjaw is offline
post #13 of 35 Old 10-26-2010, 08:17 PM
Brain stolen again?
Mrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr. Deeeeeeeeeeeeeeeeee!
Mathew Quigley
post #14 of 35 Old 10-26-2010, 08:38 PM Thread Starter
dogjaw's Avatar
now I'm truly flumoxed; jumped from my wife's Ninja directly to the battery cables on the 9, still nothing... rules out the battery, but now what?
dogjaw is offline
post #15 of 35 Old 10-26-2010, 08:50 PM
did the lights even come on when you applied jumper cables?
post #16 of 35 Old 10-26-2010, 09:03 PM Thread Starter
dogjaw's Avatar
absolutely freaking nothing
dogjaw is offline
post #17 of 35 Old 10-26-2010, 09:16 PM
Won't the battery from the ninja fit in the 9er? At least you can rule out the battery that way.
post #18 of 35 Old 10-26-2010, 09:32 PM
I think he already tried that. I blew a fuse once. But it was when I was installing new blinkers. I'd check your fuses. There should be a couple of spares under the seat next to the other fuses.
post #19 of 35 Old 10-26-2010, 09:57 PM Thread Starter
dogjaw's Avatar
i've checked every fuse, including the main 30 amp between the battery and the fusebox... there has to be something simple I'm missing, unless i fried something major when attempting to jump her off.
dogjaw is offline
post #20 of 35 Old 10-26-2010, 10:05 PM
If you totally buggered up the jump you may have fried something - but what would give a total electrical failure?
Were both bikes turned off when you connected the batteries for jumping?
post #21 of 35 Old 10-26-2010, 10:50 PM
that's what the fuse is for. no way the fuse could of not blown and something got fried in the process...
post #22 of 35 Old 10-26-2010, 11:00 PM
Some poking around is definitely needed. My friend had a 636 Ninja that mice had eaten through the wiring. Hope that's not the case, but you never know.
post #23 of 35 Old 10-26-2010, 11:19 PM
Gets censored
If you have a test light (everyone should theyre 5 bucks and very useful) Clip the ground to something then jam the probe into the positive battery cable just after the terminal if it lights up you've got juice there. Follow the cable to where it ends, check it there. If it lights up continue, also I know people have said this but your batt teminals really need to be cranked down good you may have done this but Id accualy remove them inspect the connectors clean and reinstall reeeeaaaalllllly tight.
You have no juice to nothing, start at the source (batt) and follow it to find where you are loosing it. You can also use a voltometer for this if you have one of those.
brian is offline
post #24 of 35 Old 10-27-2010, 09:43 AM
I'm sidin with Bigdaa on this one.
post #25 of 35 Old 10-27-2010, 09:53 AM
Brain stolen again?
Mrrrrrrrrrrrrrrrrrrrrrr. Deeeeeeeeeeeeeeeee
Mathew Quigley
post #26 of 35 Old 10-27-2010, 09:56 AM
Gets censored
lol, he tried to jump it with no luck so I dont think so but maybe. Would a shot ass battery stop it from powering anything on with a good jump attached?
brian is offline
post #27 of 35 Old 10-27-2010, 03:37 PM Thread Starter
dogjaw's Avatar
I finally found it... the 30 amp fuse between the battery and the fusebox. I feel like a total jackass, I checked it last night, or so I thought, about midnight while frustrated, realized today that I had checked the spare 30 amp fuse, not the one in use that was..... blown. replaced it, started right up. I may be a n idiot, but now at least I'm now a mobile idiot.
dogjaw is offline
post #28 of 35 Old 10-27-2010, 04:08 PM
Nice that's way cheaper.
post #29 of 35 Old 10-27-2010, 04:16 PM
Well, at least if it does it again, that'll be the first thing you look for.
post #30 of 35 Old 10-27-2010, 04:30 PM
Gets censored
Its a constant learning process, glad you're back on.
brian is offline
post #31 of 35 Old 10-27-2010, 05:03 PM
Chalk that one up to chit happens at midnight.
post #32 of 35 Old 10-27-2010, 06:17 PM
Brain stolen again?
Mr D was there........................in the fuze
Mathew Quigley
post #33 of 35 Old 10-27-2010, 07:07 PM
woot, knew it had to be something simple. ALWAYS is. dont feel bad. i KNOW we have all done something similar atleast once in our life...
well, for big daa it's atleast 10 times. lol.
post #34 of 35 Old 10-27-2010, 09:23 PM
Classic - at least it had a happy ending. I could not think of anything else that would totally kill the electrics like that!
Make sure you replace that spare fuse too.
post #35 of 35 Old 10-28-2010, 06:22 AM
Brain stolen again?
Better Gol darn advice than mine
Mathew Quigley
