Brake pad contact - Wrist Twisters
post #1 of 6 Old 02-10-2011, 04:59 PM Thread Starter
Total Awards: 17
Brake pad contact
How brake pads should be contacting rotors? Fg #1 or #2? Is there any difference and reasoning behind it?
Attachment 16191
zaq123 is offline
post #2 of 6 Old 02-10-2011, 05:24 PM
I always thought that # 2 is preferred. If # 1 is used as a design goal, tolerances could allow some pad to project pad the edge of the rotor, and over time, an overhand lip would for sure develop, and that could cause some pad hangup re brake release.
post #3 of 6 Old 02-10-2011, 05:34 PM Thread Starter
Total Awards: 17
That's exactly what I'm trying to avoid. I picked up a set of radial Beringer calipers and its pads have a small lip. I will need to reshim caliper bolts a little closer to the wheel center. I just not sure if it's going to be an issue if I push them slightly further than rotors edge. All rotors I've seen have a contact point of the pad very close to its outside edge. How critical is it to be very close? Can it be a little further in?
zaq123 is offline
post #4 of 6 Old 02-10-2011, 06:17 PM
1
Grind off most of the lip.
Get closer to final with a file.
I'd do the last bit with emery on a block, just a few thou, no heavy cut.
2
You want repeatability re calipers on/on and pads finding the same spot.
The bit of float and bolt/hole clearances gives you that.
I'd be leery of shimming in an effort to go to ragged edge of accuracy.
On going R & R will drive you nuts that way.
3
Mount up your Beringers and get a feel as to where they are landing on the rotor.I'm guessing that at worst you are chasing 1/16 inch or less.
If you have a bit of overhang, and surely there can't be more than just a wee bit, I'd simply bevel the top edge of the pad and be done with it. Then watch your pad wear rate. Once the bevel is worn to the point that overhang is starting again, give them a bit more bevel. I'll bet the pads are thin enough that an initial bevel is all you'll ever need.
post #5 of 6 Old 02-10-2011, 07:18 PM
schrock86's Avatar
^^+1 on the bevel idea.
schrock86 is offline
post #6 of 6 Old 02-10-2011, 09:13 PM
blur
drewvir's Avatar
dirty minds aside,lol
it can be in a little but you not maximizing the brake potential.
ex.(this is a strech) 320mm vs 310mm but you knew that
drewvir is offline
