A Spyder Race - Wrist Twisters
post #1 of 25 Old 08-13-2011, 06:06 AM Thread Starter
A Spyder Race
Let me start from the beginning. I was my way to work and was by myself for most of the ride when I come up to a red light and as always look into my side mirror to see if a car is behind me and going to stop. I notice a strange head light configuration in the lane next to me and then it hit me “Oh, this is one of those Snowmobiles on wheels” Sure enough the guy driving, in full gear, pulls up and on a Yellow Spyder. Light turns green and I go. Not wanting to race I take it easy in case a cop is around and the exhaust note from the delks gives off a cretin impression in the city, so I take easy. The Spyder is behind me then he does the standard “Come on then, Lets race” move. In case you don’t know what that is it is the blurp of speed to get in front of you then slow down. It is just him and I on the road, still pretty dark, so, I kick it down a gear and go. I was ahead the whole way. He shot past only when I slowed down after realizing I was doing 130 in a 55. That’s jail speed. For (A few) more horse power and torque it’s still a dog due to its looks and its weight. Better luck next time.
07919Dave is offline
post #2 of 25 Old 08-13-2011, 08:23 AM
I like contraptions. The Spyder is definitely a contraption...
It's not something I'm likely to get anytime soon, though. If I was in the market for a new goldwing, I would seriously consider it since it's very reliable and since goldwings are no longer motorcycles anyway.
The Spyder (being a contraption) should be compared to other things, like sidecar rigs, and such. compared to a sidecar, its not a dog at all. it does what it does very well, and does it comfortably. it's not stealing anything from the bike demographic, its adding a new level...sorta.
post #3 of 25 Old 08-13-2011, 09:15 AM
I like em, they look cool slithering down the road. Conor and I saw 9 of them on our last trip home from Vacaville. The touring version is a little different, not sure how I feel about that one yet
post #4 of 25 Old 08-13-2011, 12:35 PM Thread Starter
Damnit a new guy just joined up named SPYDER. Hope he doesn't see this thread
post #5 of 25 Old 08-13-2011, 06:25 PM
+1, I prefer 2 wheels for mow but later in life (much) I think these will be an option to stay in the wind, much better than a trike conversion IMHO.
post #6 of 25 Old 08-13-2011, 07:01 PM
Hippie Tinkerer
mntnceguy's Avatar
I'd take a trike any day over the spyder. I've ridden both, and while the trike is sluggish in it's cornering compared to a bike, the spyder actually leans to the outside of the curves, and you fight the darn thing all the way thru. I don't care for the feeling of the spyder wanting to lean to the outside, and your front inside tire wanting to come off the road as you corner. I did grow up in northern Michigan, and we snowmobile'd a lot, and the spyder definatly handles like a snowmobile, just w/o the fun. For instance, your lean on the syder does nothing for the way it corners, as it does on a sled, because you can't dig in to create your own banking. Try riding a sled on the dry grass in the summer, and you'll know what a spyder feels like on the street....close enough.....you get my drift. Now if they had done something to the steering system to produce the correct angle of lean in the bike while your cornering, I might have wanted a second ride....
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #7 of 25 Old 08-13-2011, 07:14 PM
Interesting analogy, I haven't ridden either, my opinion was based only on looking at both on the road. When the time comes, I guess I'll have to ride one of each.
post #8 of 25 Old 08-13-2011, 09:52 PM
(Mtnceguy and I have ridden the very same spyder)
That feeling of centrifugal force is normal for anything with more than two wheels...it's why bucket seats were developed for sports cars. the feeling is different from vehicle to vehicle of course, and under- or over-steer and body roll play into it. I thought the Spyder's suspension was relatively tight & sporty, and it does have traction control to keep the inside wheel planted. Shifting your weight to the inside will definitely help, but no, it won't cause the machine to corner "Like a motorcycle". Another thing that adds to the different feel on the Spyder is that it doesn't countersteer either...like a car.
I've been looking into sidecar outfits recently, and have gone for a couple test rides on different rigs. The Spyder would take much less getting used to than a sidecar. A sidecar has all of the handling issues that Mtnceguy mentioned, plus some extras...A sidecar outfit pulls a bit to the right on acceleration, and pulls to the left on braking. plus the car can come up into the air on right hand turns... different machines, different feel.
post #9 of 25 Old 08-14-2011, 10:36 PM Thread Starter
I noticed this inertia effect as the Spyder and I entered into a long swooping turn. This is the point I let off the throttle and he went pass. I saw his body to the outside and if I could see his face I bet it was the "Oh shit!!!" face as he was clinging to the Handel bars.
Potential danger for a small kid riding on the back for the first time? I can see it now you take a turn to fast and he goes flying off the back.
post #10 of 25 Old 08-15-2011, 12:13 AM
never liked those spyder things.... dunno how they call them a "motorcycle"
post #11 of 25 Old 08-15-2011, 05:34 AM
My dad was interested in one till I told him they are $18,000. You can get a Corolla for that much.
2015 Ducati Monster 1200S
FlyCatcher is offline
post #12 of 25 Old 08-15-2011, 08:27 AM
mambomonster's Avatar
I think they are neat and give them credit for the creativity. I understand it's kind of like a kart in that they don't lean. The MP3 from Piaggio does lean and I just read recently in CW that Can-Am has applied for patents that show leaning. Maybe a new version is on the way. I agree with FlyCatcher that they are too expensive. Plus they only get around 30 mpg.
mambomonster is offline
post #13 of 25 Old 08-15-2011, 08:35 AM
Brain stolen again?
I'm with ya, mambo. They are OK. The engine is what grabs my doodle. Love them motors!!!!!!
Mathew Quigley
post #14 of 25 Old 08-22-2011, 06:40 PM
Gonna start picking on Goldwing trikes next?
post #15 of 25 Old 08-22-2011, 07:22 PM Thread Starter
Sure! And those HD trikes too!
post #16 of 25 Old 08-22-2011, 07:23 PM
undercover919's Avatar
I like taking candy from babies too!
2003 Honda 919
undercover919 is offline
post #17 of 25 Old 08-22-2011, 08:27 PM
Personally, I wouldn't mind a Spyder. Certainly better than what they have in England...
I bet you'd never do this on a Spyder...
Rolling a Reliant Robin - Top Gear - BBC - YouTube
post #18 of 25 Old 08-22-2011, 09:19 PM Thread Starter
Great episode of Top Gear.
post #19 of 25 Old 08-23-2011, 01:34 PM
Hastatus Posterior
Farab's Avatar
I really don't mean this in a nasty manner; but I honestly fail to see any advantage of 3 wheels over 4 or 2, unless you have some sort of handicap and want that motorcycle feeling.
Otherwise, there are plenty of exciting little sportcars to choose from that's most probably more of a thrill and has superior road holding than 3 wheels.
A few examples:
Caterham:
KTM X-Bow
Farab is offline
post #20 of 25 Old 08-23-2011, 01:37 PM
I just want one of these:
post #21 of 25 Old 08-23-2011, 02:13 PM Thread Starter
^^^Great Face pealing car right there! Just ask Jermey Clarkston
post #22 of 25 Old 08-23-2011, 02:21 PM
Yeah, that:
post #23 of 25 Old 08-23-2011, 07:34 PM
ariannasdaddy's Avatar
Some people mod their niner a little differently
Three wheeled motorcycle The X-15 - YouTube
Arte et Marte
ariannasdaddy is offline
post #24 of 25 Old 08-28-2011, 10:19 AM
they have trac control for cornering ..it it could hang with you up to 130 mph its no dog..corrected speed of 105 110 mph....know a few people who own them and all are people who how some kind of problem leg back ect,,,,there 100 hp plus......i dont think one would be be able to stay close with me..dont think you had your coffee yet
secondchance is offline
post #25 of 25 Old 08-28-2011, 10:32 AM Thread Starter
We were at 40mph when he asked to go so I kicked it down and went. He was behind me the whole time till we hit 130mph. I slowed down because I didn't want to go to jail..... The TC is fine to help keep all three wheels on pavement and not sliding or in the air, but that doesn't mean you aren't going to get thrown off the bike due to inertia. You can't change the laws of Physics on that one. He sure was holding on pretty hard when he passed as I let off the throttle.
