Is it customary to run lower tire pressures in the cold? - Wrist Twisters
post #1 of 6 Old 10-20-2007, 06:55 PM Thread Starter
motorwerks919's Avatar
motorwerks919 is offline
post #2 of 6 Old 10-20-2007, 08:58 PM
pew pew pew
hob0's Avatar
i would assume the only reason people do that is because the increased surface area of tire to road from the decreased pressure would only heat up the tire faster. but i dont think the raise in temp would not raise the tire pressure to optimum performance though. am i right???
hob0 is offline
post #3 of 6 Old 10-20-2007, 11:04 PM
Corner speed sets u free
streakin919's Avatar
I always add a little more than usual, and it depends on how cold it is. I usually don't ride when it's below 40 F out here, so i add 3 lbs more than usual if it's in the 40s.
streakin919 is offline
post #4 of 6 Old 10-20-2007, 11:43 PM Thread Starter
I am curious as to why you add more?
post #5 of 6 Old 10-21-2007, 05:59 AM
Veteran Donation
I don't run anyless air,but I do check it a bit more as they seam to lose air in the colder weather.
tvetree is offline
post #6 of 6 Old 10-21-2007, 04:10 PM
plane's Avatar
Have a look at Charles' Law....
At constant pressure, the volume of a given mass of an ideal gas increases or decreases by the same factor as its temperature (in kelvin) increases or decreases.
Cheers,
Pete
Live Fast - Die Sideways
plane is offline
