Gasing up? Get off!!! - Wrist Twisters
post #1 of 21 Old 07-07-2006, 07:24 AM Thread Starter
Quitting is for Quitters!
LittleNinja's Avatar
The tank is running low so you pull into a service station next to a pump. Down goes the kickstand. The next few things you do could save your life.
Turn off your motor
If gasoline were to spill as you bring the nozzle to the tank or as a result of overflow or as you take the nozzle out of the tank, you risk setting it ablaze. You should be concerned not just about a hot engine or exhaust pipes, but also any electrical system.
Take your helmet off
If your helmet is on you cannot determine if a fire has started as easily as you can without it and, particularly if the helmet is attached to the bike with an audio system cord, you cannot evacuate the area quickly should a fire be detected.
Get OFF your motorcycle
For some reason this step seems to be ignored more often than any other. Maybe it 'looks' good. Maybe it's just too much work to get off when you're tired. Whatever, putting fuel into your tank while you're straddling the bike is dangerous! If there is a gasoline spill your crotch will get wet. Then what do you do?
Fill the tank, but not to the top
Gasoline expands as it warms up. Some gas tanks are not sealed units and if you fill them to the top they can easily leak. Some motorcycles have dual (side-by-side) tanks that are connected internally. There is a 'secret' you should know about filling these bikes - when putting gasoline into the higher tank WATCH the level in the lower one. Since you are on your side stand the bike is leaning and overflow from the higher tank will go to the lower one. Obviously, with this kind of system you cannot fill the highest tank without overfilling the lower one. This is one reason why owners of these bikes tend to sit on them when they fill up - to keep the bike vertical so they can load as much gasoline as possible. But it's obvious why you shouldn't do so (odds are good you will stop and put your side stand down before you have burned up enough gasoline to prevent leakage.)
Do not smoke within 20 feet of a gas pump
Keep your ignition switch in the OFF position any time your filler cap is off your tank. (Especially do not use your CB.)
Earlier I asked what you would do if gasoline spilled onto your crotch. Actually, I should have asked what you would do if it spilled on any part of you or your clothes. This is so important I will offer my own suggestions at this point.
DRENCH with water!
THEN take that article of clothing OFF!!
DO NOT WALK IF THERE IS GASOLINE ON YOUR CLOTHES!!!
Static electricity can easily ignite gasoline fumes.
Allow wet clothes to dry OUTSIDE. If you happen to be at home, DO NOT PUT THESE CLOTHES INTO A WASHER/DRYER!!!!
If you can smell gasoline on them there is enough to ignite.
by James Davis
-Mercedes- or you can call me YaYa
LittleNinja is offline
post #2 of 21 Old 07-07-2006, 07:27 AM
BockHawk's Avatar
Good advice, all of it, but I don't like to spend 10 minutes filling up. I'll probably continue to fill up with me on the bike in the upright position, while wearing a helmet.
2002 919 40,000 miles
BockHawk is offline
post #3 of 21 Old 07-07-2006, 07:52 AM
goodhorsey's Avatar
what bock says. even tho it goes against much of the advice given....
goodhorsey is offline
post #4 of 21 Old 07-07-2006, 08:38 AM
I put the kickstand down and get off the bike but I don't remove my helmet.
NewRedRider is offline
post #5 of 21 Old 07-07-2006, 08:49 AM
Originally Posted by LittleNinja
Turn off your motor
Guessing 99% of bikes require a key to open gas cap. Kinda hard to leave bike running & open cap too.
I get off bike, gotta stretch the legs once in a while, right?
But I usually pay at pump, so I leave lid on. If I have to go inside to pay I take it off.
h ryder is offline
post #6 of 21 Old 07-07-2006, 08:56 AM
Realist
rocktoad13's Avatar
My previous bike (Kaw Meanstreak 1600) I could remove the key while it was running...guess it was so a keychain/extra keys wouldn't scratch the tank as the ignition was on top of the tank...can't remove the key on my 9'er with it running...already tried.
Britt
'03 Dodge Ram 3500 4x4
'77 Jeep CJ-7 (sold... )
'06 Honda 919
'06 Prairie 360 4x4 ATV
'72 Volkswagen Beetle
rocktoad13 is offline
post #7 of 21 Old 07-07-2006, 09:16 AM
Wookie
ragdoll's Avatar
I stay on the bike with my helmet on so that I can keep the bike upright and fill it all the way up to the gas cap....
'02 RC-51
'10 Unicycle
ragdoll is offline
post #8 of 21 Old 07-07-2006, 10:33 AM
Me too.
And I also try to keep my left foot on the left side of the bike, and my right foot on the right side.
post #9 of 21 Old 07-07-2006, 10:46 AM
put your ad here
4manhilt's Avatar
i always felt like one of the advantages to getting off while filling up was you could give your bike the visual "once over". make sure everything is like it should be. especially when far from home.
Most problems in life can be fixed... Stupid isn't one of em'.
4manhilt is offline
post #10 of 21 Old 07-07-2006, 10:56 AM
Brain stolen again?
I tried to remove the key in my KLR650 in the garage while it was running, and it got confused, and esploded all the wheel off all of a sudden like.
Shocking....just shocking! I was lucky I wasn't filling it up.
Ohhhhhh the carnage.
"There is no place like home, there is no place like home 'click.....click.....click'
Mathew Quigley
post #11 of 21 Old 07-07-2006, 11:59 AM Thread Starter
How the hell did my safety thread turn in to some FUNNY SHIAT!!??!!!??!!
post #12 of 21 Old 07-07-2006, 12:02 PM
BockHawk's Avatar
I think lilnin is forgetting where she is.
BockHawk is offline
post #13 of 21 Old 07-07-2006, 12:06 PM Thread Starter
OH Yeah!!! I'm at WT where every thread gets deralied!!! DUH!!!!!!!!!!!
post #14 of 21 Old 07-07-2006, 12:08 PM
Speaking of derailed...
where's rsixxy & your sis?
h ryder is offline
post #15 of 21 Old 07-07-2006, 12:14 PM
BANNED!
midwest's Avatar
More like railed not derailed........... OOPsss. sorry!
I LOVE Tig Bitties!
midwest is offline
post #16 of 21 Old 07-07-2006, 12:28 PM Thread Starter
Not too sure about Rsixxy. She started up her own compnay (YAY) so she has been extremely busy.
My sis (freakin airhead) she doesn't post too much. She's not a little devil like me.
post #17 of 21 Old 07-07-2006, 01:55 PM
xmatt2strokex
Guest
Posts: n/a
I've never seen anyone stay on the bike while refueling, and I couldn't imagine doing that. I always get off. Although I am guilty of trying to fill it as much as possible. Also, "lower end" (read: Less expensive) harleys don't have locking fuel caps. I also do sometimes leave my helmet on, if I'm in a hurry, but usually I take it off so I can clean the bugs off. Also, I do the once over while I'm there.
m.
post #18 of 21 Old 07-07-2006, 04:14 PM
Brain stolen again?
OK. I want to redeem myself. Maybe it's bad bad no no, and a 50 year old guy like me should know better, but I don't give a sheat about a 50 year old guy like me so I always refuel while on the bike. It makes it infinitely easier to skip out without paying.
Mathew Quigley
post #19 of 21 Old 07-07-2006, 05:32 PM
Wookie
ragdoll's Avatar
Originally Posted by HondaJim
Me too.
You are...
'02 RC-51
'10 Unicycle
ragdoll is offline
post #20 of 21 Old 07-07-2006, 07:14 PM
...not right.
post #21 of 21 Old 07-07-2006, 08:48 PM
Hornet Grandpa!
I only refuel at the end of my commute each day, 55 miles. I'm glad to get off and get that helmet and gloves off also. Besides, my fuel point gives me a free 20 ounce soda with a fill up (even if its only 2.5 gallons) and I don't want to spill drink inside my helmet! Back on the niner and one mile to home.
I fill up in the evening so It won't make me late for work in the morning. Besides, in the Spring and Fall, a full tank of gas at 65°F from my garage feels better between my legs than a tank of cold gas for the hour I'm on the throttle!
support_six is offline
