Deer - Read and Acknowledge - Wrist Twisters
post #1 of 68 Old 09-21-2006, 12:05 PM Thread Starter
Lightbulb Deer - Read and Acknowledge
Occasionally a thread comes along that everyone should have to sign off on acknowledging they've read, understood and intend to comply. This is one of those.
An analysis of state data from Alabama showed that the most dangerous times of day for deer-related crashes are in the early evening and early morning - the most active time for deer. Be especially attentive from sunset to midnight and during the hours shortly before and after sunrise. These are the highest risk times for deer-vehicle collisions."
The most dangerous time of year is during the mating season, in November and December.
Some motorist deaths and injuries occur when drivers swerve to avoid hitting the deer and strike a fixed object, such as a tree or another vehicle. It may seem powerless, but simply applying your brakes and coming to a controlled stop (if possible) can actually help minimize damage and injuries.
If you spot a deer in the road, slow down immediately and blow your horn with one long blast to frighten it away. Don't assume there's only one deer crossing the road -- they usually travel in groups.
If an encounter with a deer is inevitable, then you should hit the brakes up until the very last moment of impact; suddenly releasing the brakes will decrease the deer’s reaction time to move.
The best defense is being alert to the danger and ride accordingly.
So, what can you do to avoid hitting an animal yourself? First, pay attention to animal crossing signs. They're probably there because other motorists have had crashes in the area. Also, obey the speed limit and don't over-drive your headlights at night - control your speed so that you will have time to react to something when it appears in your headlights. If you see a deer in the road, honk your horn -- flashing your lights might cause the animal to further fixate on your vehicle. Keep in mind that if you think you are going to hit the animal, it's often better to brake than to swerve. Swerving can confuse the animal as to which way to run and possibly result in a worse collision with a fixed object such as a tree or an oncoming vehicle.
If your vehicle strikes a deer, do not touch the animal. The frightened animal, in attempting to move, could hurt you or itself. The best procedure is to get off the road, if possible, and call the police. When you get home, contact your insurance agent or company representative and report the incident. Collision with an animal is normally covered under the comprehensive portion of your insurance policy.
To recap:
Be vigilant in early morning and evening hours, the most active time for deer.
  • Use your high-beam headlights, which reflect in the deer's eyes, to see the deer better.
  • Slow down and blow your horn with one long blast to frighten the deer away.
  • Brake firmly when you notice a deer in or near your path. Do not swerve. It can confuse the deer as to where to run. It can also cause you to lose control and hit a tree or another object.
  • Be alert and drive with caution when you are moving through a deer crossing zone.
  • Look for other deer after one has crossed the road. Deer seldom run alone.
Be careful out there my friends, deer season is almost upon us.
post #2 of 68 Old 09-21-2006, 12:09 PM
Read. I hate deer. But I like deer jerky.
post #3 of 68 Old 09-21-2006, 12:11 PM
Pretty good write up but I have issue with the keep blowing your horn part. I have watched and been in a vehicle where at a complete stop a deer has turned and ran into the vehicle because you just scared the sh#t out of it. Your best bet it to slow down if not stop and wait til the coast is clear leaving the scene slowly. If it is the lead deer the others will generally follow.
dadogs is offline
post #4 of 68 Old 09-21-2006, 12:12 PM
I'll send you some this year as long as I get one. <<bang>> <<bang>>
dadogs is offline
post #5 of 68 Old 09-21-2006, 12:14 PM
ajcombs's Avatar
Helping a Member in Need
Read
ajcombs is offline
post #6 of 68 Old 09-21-2006, 12:14 PM
Realist
rocktoad13's Avatar
Read it...live it...our area in eastern NC is particularly thick with deer...my plan this year is to thin the herd, well me and my two sons plan anyway...
Britt
'03 Dodge Ram 3500 4x4
'77 Jeep CJ-7 (sold... )
'06 Honda 919
'06 Prairie 360 4x4 ATV
'72 Volkswagen Beetle
rocktoad13 is offline
post #7 of 68 Old 09-21-2006, 12:17 PM
This because they are in rut and also varies across the U.S. do to different climates. Rut in some areas can start as early as late August.
dadogs is offline
post #8 of 68 Old 09-21-2006, 12:19 PM Thread Starter
Good feedback dadogs - reviewing the studies I sourced to compile the post I understood the horn blowing to scare away the other deer as well as the one that might be fixated on the rider.
post #9 of 68 Old 09-21-2006, 12:20 PM
The "Eagle" Has Landed
Aquila-RC51's Avatar
Should you impale a deer with your two wheeled automobile, please send all deerskin my way...
Aquila-RC51 is offline
post #10 of 68 Old 09-21-2006, 12:21 PM
I agree... darn animals are either dumb as a log or scared witless. Stop with some distance to spare if you are able to.
post #11 of 68 Old 09-21-2006, 12:39 PM
Hey, I want some too!!!!
I've not encountered a deer an the bike thankfully, usually when they are real active around here it's too cold for me! But in the Jeep I often use the horn to scare them away from the road.
angela155 is offline
post #12 of 68 Old 09-21-2006, 12:40 PM
Only if you promise to change your avatar
dadogs is offline
post #13 of 68 Old 09-21-2006, 12:41 PM
They rut early here as well. The hunters here aren't nearly as prominent as they used to be, and the evidence is all over the highways and rural roads around here. Watch out guys/gals. If you get into a situation where it is too close to evade and/or stop, aim for the ditch. Earth is alot softer and more forgiving than the asphalt.
post #14 of 68 Old 09-21-2006, 12:42 PM
I wish we had ditches here.......only potholes and trees
dadogs is offline
post #15 of 68 Old 09-21-2006, 12:58 PM
BockHawk's Avatar
Dadogs is right, I have a friend who got the side of her car dented heavily by a deer because she honked. Best bet is to leave 'em be until they're gone. The sound of the bike alone will make most deer nearly pi$$ themselves.
2002 919 40,000 miles
BockHawk is offline
post #16 of 68 Old 09-21-2006, 12:59 PM
Around here, there is usually a 5-10 foot buffer of ditch on the rural roads. Highways and towards the city is a different situation. That 5 foot buffer runs out fast though if you are in swerve and evade mode.
post #17 of 68 Old 09-21-2006, 01:12 PM Thread Starter
WIM - when you get to Jennings we'll have a deer waiting and I want you to run as fast as you can and broadside him. No clipping the knees either.
post #18 of 68 Old 09-21-2006, 01:13 PM
Without a bike he has no choice but to run.
dadogs is offline
post #19 of 68 Old 09-21-2006, 01:15 PM Thread Starter
exactly.
post #20 of 68 Old 09-21-2006, 01:28 PM
Ummm.... can I at least wear my helmet ?!?!
Dave said I can borrow his for this weekend....
post #21 of 68 Old 09-21-2006, 01:33 PM
I love deer mating season.
They are so soft and furry...
Motohead is offline
post #22 of 68 Old 09-21-2006, 01:38 PM
hmmmm, deer...
lil' redneck girl is offline
post #23 of 68 Old 09-21-2006, 01:48 PM
SportyChick's Avatar
Isn't there something on the market that you can put on bikes that's supposed to scare animals away? Whistle of some sort?
I've lived in the country most of my life where it's not unusual to see deer in your backyard. So with that said, I've been riding in the country now for years and I've had my share with animals on the road. I read the advice and I pretty well do everything already listed especially look for glowing eyes in ditches and on roads. I've never hit an animal in my vehicles or on my bikes, I've come close even kicked a racoon in the ass riding along side of it (now that was funny, he thought he could run faster then my bike but I just kicked him out of the way).
SportyChick is offline
post #24 of 68 Old 09-21-2006, 01:58 PM
Not a whistle, it's a pic of Ragdoll with his hair spiked. Mount it to the front and your good. Course RC90 and WIM will chase you from behind.
post #25 of 68 Old 09-21-2006, 02:02 PM
Only WIM would be chasing Sporty's tail. RC90 will only chase Ragdoll's tail.
post #26 of 68 Old 09-21-2006, 02:02 PM
BockHawk's Avatar
I hit a groundhog the other day. I couldn't believe it. Who hits a groundhog?!?!
BockHawk is offline
post #27 of 68 Old 09-21-2006, 02:12 PM
Obviously you. You were the bright star at the top of the family tree huh?
post #28 of 68 Old 09-21-2006, 03:53 PM
Veteran Donation
More about the whistle do they work I've seen them everywhere,but don't know anyone who uses them.
Best bet is to be on the lookout just like everyone has said.When I cross one I treat them like a cager can't be sure if either one has any sense.Give them some room.
tvetree is offline
post #29 of 68 Old 09-21-2006, 04:13 PM
I raced a turkey once! In my grand am.
Gbord is offline
post #30 of 68 Old 09-21-2006, 05:04 PM
Wookie
ragdoll's Avatar
Read.
I've hit 4 deer in my time... not fun. They stink when their insides are all over your car.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #31 of 68 Old 09-21-2006, 05:25 PM
I hit two deer in one night several years ago. They were still warm when I violated them. Ummm... That's the Cabernet talking. I've got a 2hr layover.
The funniest part, is my brother-in-law is a huge hunter and didn't get squat.
And, I want JERKY also!
RC51_CBRXX is offline
post #32 of 68 Old 09-21-2006, 05:30 PM
I will let it be known that I make the best jerky known to man (no jab intended Eazy).
dadogs is offline
post #33 of 68 Old 09-21-2006, 05:34 PM
I still have that Tequila for you. This bottle is a present.
I'm in Mexico next week and Brazil. For JERKY, I will get that rum with the glass palm tree inside the base and a bottle of Pinga!!!
post #34 of 68 Old 09-21-2006, 05:36 PM
You have a deal
I'll whip up a few pounds for ya
dadogs is offline
post #35 of 68 Old 09-21-2006, 05:40 PM
You have a deal
Deal. If you don't come through ... you will have a thong wearing spanglish speaking Ecuadorian from Miami at your door looking to warm deer violate you!
post #36 of 68 Old 09-21-2006, 05:42 PM
Oh I'll come through, been meaning to make some anyhow. Gimme a minute though while I find something in the back yard to shoot. Wait never mind, saw some road kill on the way home...possom I believe.
dadogs is offline
post #37 of 68 Old 09-21-2006, 05:46 PM
Dude, I'm asian. We eat everything!
post #38 of 68 Old 09-22-2006, 06:25 AM
Pretty good!
Bump for Jet's public service announcment!
dadogs is offline
post #39 of 68 Old 09-23-2006, 08:33 AM
As a RIDER that has hit a deer doing 65-70mph I can tell you it not fun and is VERY painful. I would concur with this;
If you see a deer or ANY animal larger than a cat, slow to a crawl. They are much, much faster than you think.
NewRedRider is offline
post #40 of 68 Old 09-24-2006, 06:51 AM
Living the dream
TLR_Nate's Avatar
I read as well and plus 1 for the jerkey. Is my avater OK? i will only share a little.
TLR_Nate is offline
