Linksys Router? - Wrist Twisters
post #1 of 35 Old 04-29-2013, 07:33 PM Thread Starter
919 aka Hornet 900
Mr T81's Avatar
Linksys Router?
Hello WT...
I have a wireless router is my house and I think it's no longer
working properly. This started a few months back, when I click
on my internet browser icon it does not always work. 75% of the
time the internet will start, other times I have to wait half
an hour and try again. It's getting worst lately. I moved my
computer and plugged it straight into the wall and now it
works every time.
My router is a linksys about 6 or 7 years old, maybe more.
How long does a router usually last?
If I have to buy a new one, what is a good brand?
Thanks
Mr T81 is offline
post #2 of 35 Old 04-29-2013, 07:51 PM
I'm interested too... I go through routers faster than I go through underwear.
post #3 of 35 Old 04-29-2013, 07:56 PM
Its possible... they typically will go bad due to heat... its definitely not uncommon.
I wouldnt honestly go with linksys again, gone are the days where they built good stuff (like my good ole WRT54GL that has been going non stop for YEARS). I did open it up and throw a decent sized aluminum heatsink on the main chip... this will definitely help it out in the long run.
Buffalo or Asus as far as brands, and dont get caught up in fancy 100 dollar routers, you will not notice the difference.
post #4 of 35 Old 04-29-2013, 07:59 PM Thread Starter
919 aka Hornet 900
Mr T81's Avatar
How much should I expect to pay for a router?
Mr T81 is offline
post #5 of 35 Old 04-29-2013, 08:07 PM
id say 60 tops.... you can get a buffalo gigabit router with 802.11n wifi for 55.
post #6 of 35 Old 04-29-2013, 09:18 PM
If you got 4 years out of a sub $100 router, I say it's served its purpose. If you want extended range, you can spend more on a twin antenna router. Just be sure to get a B/G/N compatible, N being the latest. At $60 I believe they're all N now.
Did you try pushing the reset button on your current router? All your settings will be wiped out but if it's not working...
post #7 of 35 Old 04-29-2013, 09:18 PM
Check out newegg, go by the reviews. Find the five star routers, then do due diligence.
post #8 of 35 Old 04-30-2013, 07:42 AM
Is there something to look for specifically in noisy environments? It seems like my router is constantly channel hopping. It seems like every router I've owned will only change channels so many times before going out to lunch. A power cycle usually fixes this... but after a while, the router is usually toast.
post #9 of 35 Old 04-30-2013, 09:38 AM
What I like to do is survey the area with a program like inssider to see what's in use then manually set a channel that's furthest away from everything and or on a channel that has the lowest other signals.
FYI newegg has a nice dlink router for 55 shipped use promo code EMCXSTX72
D-Link Xtreme Gigabit Router (DIR-655) Wireless N300, USB SharePort, Gigabit - Newegg.com
post #10 of 35 Old 04-30-2013, 09:47 AM
Sixty-9er
edgecrusher4444's Avatar
I was in the same place two years ago. 7 year old linksys. Replaced with this Netgear, never been better.
Netgear, Inc WNR2000
"Grip it and Rip it!"
edgecrusher4444 is offline
post #11 of 35 Old 04-30-2013, 11:19 AM
meh i have seen many of those netgear routers come back fried... also lack of external antennas reduces wifi range quite a bit.
post #12 of 35 Old 04-30-2013, 12:05 PM
My D-Link has been chugging along for about 10 years now
post #13 of 35 Old 04-30-2013, 12:53 PM
If you have a noisy environment, consider upgrading to 5ghz instead of 2.4.
We have a baby monitor, and man, when that thing is on, our wireless sucks no matter which channel it's on, it has a wide band or something.
I used Powerline adapters to fix the PC in the kitchen and the bedroom, and got better bandwidth than I ever saw with wireless.
For phones and laptops/tablets, though, they have to be 5ghz compatible, which they may not be.
post #14 of 35 Old 05-01-2013, 08:11 PM
+1
Thinking about going to this one:
D-Link Xtreme N Dual-Band Gigabit Router (DIR-825) Wireless N600 - Newegg.com
BKRMON is offline
post #15 of 35 Old 05-01-2013, 09:05 PM Thread Starter
919 aka Hornet 900
Mr T81's Avatar
I pushed the reset button and it's been good since.
Don't know what the f**k.
Mr T81 is offline
post #16 of 35 Old 05-01-2013, 09:47 PM
Did you re-secure your router after you hit the reset button?
post #17 of 35 Old 05-01-2013, 10:35 PM
Just saved 60 bucks! Yea sometimes they lock up.
post #18 of 35 Old 05-02-2013, 06:33 PM Thread Starter
919 aka Hornet 900
Mr T81's Avatar
Did not touch anything else then the reset button.
Padlock icon is still showing when I check my network connection.
Still working...
Mr T81 is offline
post #19 of 35 Old 05-02-2013, 09:01 PM
Still working...
Might want to double check your security settings just to be sure. Typically, hitting the reset button on the router will default it to factory settings and you'll need to re-lock your wifi with a password and what not so other people don't piggyback on your bandwidth.
post #20 of 35 Old 05-03-2013, 01:43 AM
Actually, usually just tapping the reset button does nothing more than reboot the router. You have to hold it in for ten to fifteen seconds before it actually resets.
post #21 of 35 Old 05-04-2013, 11:14 AM Thread Starter
919 aka Hornet 900
Mr T81's Avatar
I just pushed the button, I did not hold it in.
Still working...
Mr T81 is offline
post #22 of 35 Old 05-04-2013, 12:06 PM
yeah a reboot here and there will solve lots of issues with most computer related stuff.
post #23 of 35 Old 05-05-2013, 02:18 PM
Good to know.
post #24 of 35 Old 05-05-2013, 03:13 PM
working in IT it usually work out as follows.
80% of the time its either not plugged in or rebooting it fixes it
10% of the time i google and find the answer
5% of the time i know the actual solution
5% of the time, IT VOODOO!
or some very similar break down.
Literally this morning my gf calls me up and says that shes not able to get to websites... i tell her go over to your router and modem, unplug it. wait 20 secs plug it back in... walla works now.
post #25 of 35 Old 02-11-2014, 05:32 PM Thread Starter
919 aka Hornet 900
Mr T81's Avatar
My old router started acting up again lately. Went out and got a new one this afternoon. I bought a D-Link, it's like night and day. If I would of known it was gonna make that much of a difference I would of bought a new one sooner
Mr T81 is offline
post #26 of 35 Old 02-11-2014, 06:23 PM
My D-Link finally died last October, I replaced it with a Buffalo AirStation dual band, so far it's been fantastic.
post #27 of 35 Old 02-11-2014, 06:27 PM Thread Starter
919 aka Hornet 900
Mr T81's Avatar
How long did your D-Link last you?
Mr T81 is offline
post #28 of 35 Old 02-11-2014, 06:54 PM
It chugged along for at least 10 years
post #29 of 35 Old 02-11-2014, 09:42 PM
NWTB Non Stinky 919
jeffie7's Avatar
Linksys makes a great router as long as you follow the instructions of restarting it every 37 hours.
jeffie7 is offline
post #30 of 35 Old 02-11-2014, 09:52 PM
Just bought a router myself... This was a good reference.
The 10 Best Wireless Routers | PCMag.com
robroten is offline
post #31 of 35 Old 02-12-2014, 10:24 AM
I have the #3 in that list , the Asus AC66U. Thing is ROCK SOLID and I get insane transfer speeds.
I can watch 8gig .mkv Blu-Ray rips over WI-FI on my projector. Just...cool.
post #32 of 35 Old 02-12-2014, 12:08 PM
lol... I just bought the same router ! Installed it yesterday...
robroten is offline
post #33 of 35 Old 02-12-2014, 12:16 PM
The ASUS was on my short list when I was looking but NewEgg had such a screaming deal on the Buffalo that I couldn't pass it up
post #34 of 35 Old 02-12-2014, 03:55 PM
I spent the entire morning screwing with a Motorola NVG589 trying to get direct UDP traffic forwarded to a port specific IP addy. Was ready to shoot every device on the LAN with a .40 cal when all the sudden it started working properly for no apparent reason whatsoever.
On the positive side the new service is hitting 21.13 Mbps
post #35 of 35 Old 02-12-2014, 04:43 PM
Consumer oriented devices are SO finicky. Our network engineer only runs Cisco routers and switches even for his home internet, . He says he prefers stability over anxiety.
