Stick tack off helmet shield? How? - Wrist Twisters
post #1 of 15 Old 05-08-2012, 03:42 PM Thread Starter
So I experimented with one of those fog-free add on stick things (by Oxford). Didn't do much against condensation in the winter so I took it off. It left the glue outlineo and I can't get it off.
Anyone know of any solvents or tricks to get it off? I've tried rubbing alcohol to no luck and I have a feeling goof-off might work but could eat away at the shield in the process...
post #2 of 15 Old 05-08-2012, 03:53 PM
ariannasdaddy's Avatar
tea tree oil
or melaleuca oil
http://www.ebay.ca/itm/100-Pure-Esse...item4ab326b4fc
Arte et Marte
ariannasdaddy is offline
post #3 of 15 Old 05-08-2012, 04:11 PM
Sandpaper
post #4 of 15 Old 05-08-2012, 04:13 PM
Sandpaper
Oh Yes!! That too!
What grit would you say is best?
Arte et Marte
post #5 of 15 Old 05-08-2012, 04:43 PM
Originally Posted by ariannasdaddy View Post
Oh Yes!! That too!
Tire grade should be fine as long as you follow up with armor-all
post #6 of 15 Old 05-08-2012, 04:58 PM
Oh no, not the armor all thing again..... One fuckin mistake! You guys don't forget much.
Arte et Marte
post #7 of 15 Old 05-08-2012, 05:10 PM
Soap and water might work, depending on what the glue is based on. Since alcohol didn't touch it, I'm going to assume it's water based and not alcohol based.
post #8 of 15 Old 05-08-2012, 05:25 PM Thread Starter
I tried sandpaper, worked well.
post #9 of 15 Old 05-09-2012, 12:02 AM
Lighter fluid or white gas. Naptha, basically. Zippo brand seems to work the best, won't hurt the plastic.
post #10 of 15 Old 05-09-2012, 06:21 AM
Peanut butter?
Sent from my BlackBerry 9650 using Tapatalk
Superdog is online now
post #11 of 15 Old 05-09-2012, 06:43 AM
NWTB Non Stinky 919
jeffie7's Avatar
Wd40? Just make sure your shield isn't chain grade.
jeffie7 is offline
post #12 of 15 Old 05-09-2012, 06:47 AM
Won't that cause your helmet to fill with water?
post #13 of 15 Old 05-09-2012, 06:47 AM
goo b gone. That stuff is amazing.
post #14 of 15 Old 05-09-2012, 04:04 PM Thread Starter
Used 3 in 1 oil and some elbow grease. Got it out
post #15 of 15 Old 05-09-2012, 04:24 PM
De-solv-it
It's a citrus based solvent. I've used it a lot and on painted surfaces like the tank and fenders to get sticker residue off and it works without harming the finish.
garyb900 is offline
