? helmet4 eyeglasses - Wrist Twisters
post #1 of 16 Old 06-21-2009, 01:36 PM Thread Starter
FXS
Knees in the Breeze
FXS's Avatar
Never had a full faced helmet. May need one soon. Which would you suggest for someone who wears eyeglasses ?
Never pick a fight with an old man..if he's too tired to fight, he'll just shoot you.
1979 H-D Low Rider (orig owner)
2009 K 1300 S (Lava Orange...the faster color)
FXS is offline
post #2 of 16 Old 06-21-2009, 01:42 PM
iceman's Avatar
The flip up ones work great for that.
iceman is offline
post #3 of 16 Old 06-21-2009, 01:45 PM
livelaughlove
hopegrabowski's Avatar
Extraordinary Ride Wrist Twisters Event Attendance
Any goes over glasses well. Just make sure your fit is right and comfortable. The flip ups are great cause you flip the front when you stop instead of taking of the helmet off.
Hope
hopegrabowski is offline
post #4 of 16 Old 06-21-2009, 02:00 PM
Well, I have a Shoei RF1000 and I can't wear my Oakley's under them. There is not enough room between the padding and the side of my face. They just don't fit right and my glasses pop up off my nose so they are like halfway over my eyebrows instead of my eyes. It could just be the way the glasses are shaped because I didn't have the problem with a pair of Smiths, but the earpieces were shaped differently.
2526 is offline
post #5 of 16 Old 06-21-2009, 02:01 PM
Trackday Recognition Donation
I wear glasses & a full face helmet (shoei). The only helmets that my glasses didn't like were the ones that fit too tight which ain't good anyway. If you get a proper snug fit the pads are still soft enough to push glasses past.
edit: My regular glasses and my prescript sunglasses are somewhat low profile, not as wide/bulky as many of the other sunglasses out there.
gpzTurbo is offline
post #6 of 16 Old 06-21-2009, 02:12 PM
I killed Barton664
Basspiece919's Avatar
I had a HJC before my scorpion and I used to wear my M-frames with it all the time no problem
Basspiece919 is offline
post #7 of 16 Old 06-21-2009, 03:06 PM
Veteran Donation
I've used Hjc, Nolen, and now Scorpion all where glasses freindly.Used a flipp up for a bit also. It helped a little as for putting the glasses on but not as much as I had hoped it would,Not worth the weight really.
Now what you will need is a good anti-fog.I use a wax stick thing I picked up at work.Bad news is there is no info on it as for where to get more.
tvetree is offline
post #8 of 16 Old 06-21-2009, 03:56 PM
pianopraze's Avatar
I find I have no trouble with any full face helmet.
Trick: put the glasses on as if you were going to aim for the middle of your ear, not the top. A you push them in you can hook them over the top of ear as normal. If you try to put them on normally they will tend to go high and they don't fit on right.
I only use metal frames, not sure if the hard plastic frames would be different. Hope this helps
pianopraze is offline
post #9 of 16 Old 06-21-2009, 04:14 PM
nospeedlimt's Avatar
I wear a Simpson flip face (Dead white, makes me stick out like a sore thumb on rides), and gf wears AFX (NFX? Never can remember) with her non scrip sun glasses. Both work just fine, because they fit well. Try out a helmet or five at your local, friendly cycle shop with your glasses and see what works best with you.
Vash the Stampede, at your service.
nospeedlimt is offline
post #10 of 16 Old 06-21-2009, 05:22 PM
My HJC works great with my glasses, no issues.
post #11 of 16 Old 06-21-2009, 06:36 PM
Ballaholic
hornet919's Avatar
my glasses fit good in my soumy. you should be fine with anything basically as long as your not wearing enormous 80's glasses or something lol
hornet919 is offline
post #12 of 16 Old 06-21-2009, 06:39 PM
tc919er's Avatar
No problems with my Gmax helmet. I have both metal and plastic framed glasses.
"No freeman shall ever be debarred the use of arms."
---Thomas Jefferson 1776.
tc919er is offline
post #13 of 16 Old 06-21-2009, 07:02 PM
tpschil's Avatar
It all depends how tight the pads fit against the side of your head (already mentioned) and how rigid the eyeglass bows are. If they flex too much it's difficult to get the bows hooked behind the ears. I have resorted to modular full face models also. There is a down side however, more wind noise.
tpschil is offline
post #14 of 16 Old 06-21-2009, 07:39 PM
i must wear my oakleys anytime i am outside during daylight..(light sensitive i also have to have a mirrored shade even at night!!) and i have had no problems with the hjc, shoei, and now the kbc helmet i have....
the kbc is tight enough to leave marks on my cheeks *(my angelic cute cheeks)... and i have no issues at all with the glasses..
the flip face helmets i dont care for... extra weight and if i fall off and go boom facefirst i don't want a chance of that front moving and messing up my pretty face...
post #15 of 16 Old 06-21-2009, 07:44 PM
I just picked up an HJC IS-MAX.
Flip-up front style, works fine with my glasses. I don't have to remove glasses to put it on/off, and it has a drop-down sunscreen built in, so I don't have to pull over and change glasses as the sun comes in or out.
tjc1965 is offline
post #16 of 16 Old 06-22-2009, 01:02 PM
farmerjoe's Avatar
Glasses friendly, here are my experience:
Arai= excellent
Shoei=good
Dainese=ok
KBC=poor
Suomy=forget it
farmerjoe is offline
